Canal de Suez 27
Iniciado por GAE_Yanito, 27 de Febrero de 2009, 11:33:07 PM
[28.02.2009 4:02:23] Mission: net/coop/CANAL DE SUEZ/SUEZ_27_sur.mis is Playing
18:00:00 Mission BEGIN
18:00:00 GAE_Balker is trying to occupy seat 240Squadronmaritime110(0)
18:00:00 g01020(0) seat occupied by GAE_Yanito at 8942.103 237759.61
18:00:00 g01020 loaded weapons '2x1000' fuel 100%
18:00:00 240Squadronmaritime110(0) seat occupied by GAE_Balker at 72926.46 95462.73
18:00:00 240Squadronmaritime110 loaded weapons '2x5008xhvargp' fuel 75%
18:00:00 240Squadronmaritime121(0) seat occupied by GAE_Angel at 74111.42 95347.01
18:00:00 240Squadronmaritime121 loaded weapons '2x5008xhvargp' fuel 75%
18:00:00 240Squadronmaritime112(0) seat occupied by GAE_Charrua at 72936.43 95458.53
18:00:00 240Squadronmaritime112 loaded weapons '2x5008xhvargp' fuel 50%
18:00:00 240Squadronmaritime111(0) seat occupied by GAE_Alma at 72938.125 95470.45
18:00:00 240Squadronmaritime111 loaded weapons '2x5008xhvargp' fuel 75%
18:00:00 240Squadronmaritime122(0) seat occupied by Castor at 74109.8 95335.08
18:00:00 240Squadronmaritime122 loaded weapons '2x5008xhvargp' fuel 75%
18:01:02 240Squadronmaritime110 in flight at 72112.91 96770.04
18:01:10 240Squadronmaritime111 in flight at 71980.92 96962.36
18:01:18 240Squadronmaritime112 in flight at 71979.52 96930.89
18:01:43 g01020 in flight at 7876.978 236429.53
18:01:51 240Squadronmaritime122 in flight at 72737.55 97358.27
18:01:51 240Squadronmaritime121 in flight at 72296.27 97341.87
18:06:56 7_Chief destroyed by 18_Static at 39862.12 132940.42
18:13:02 240Squadronmaritime120 removed at 66828.72 106163.54
18:15:26 1_Chief destroyed by 31_Chief at 56849.23 115924.695
18:18:00 97_Static destroyed by 67_Chief at 90783.98 64596.52
18:18:00 98_Static destroyed by 67_Chief at 90798.89 64621.7
18:18:00 108_Static destroyed by 67_Chief at 90772.22 64618.78
18:18:00 96_Static destroyed by 67_Chief at 90785.65 64610.62
18:18:21 g01011(0) was killed by 3SquadronRAAF102 at 50868.02 105723.15
18:18:27 g01010 damaged by 3SquadronRAAF102 at 52016.39 104755.6
18:18:32 g01010(0) bailed out at 52524.543 104319.22
18:18:38 g01011 damaged by landscape at 52468.562 104947.73
18:18:38 g01011 shot down by 3SquadronRAAF102 at 52468.562 104947.73
18:18:41 g01010 shot down by 3SquadronRAAF102 at 53363.74 103644.25
18:19:00 g01013 damaged by 3SquadronRAAF100 at 54868.406 104068.06
18:19:11 g01013(0) was killed at 56332.586 103980.44
18:19:11 g01013 shot down by 3SquadronRAAF100 at 56332.586 103980.44
18:19:24 g01012 damaged by 3SquadronRAAF100 at 59265.625 104426.36
18:19:24 g01012(0) was killed by 3SquadronRAAF100 at 59278.883 104428.73
18:19:38 g01012 shot down by 3SquadronRAAF100 at 59972.31 104668.914
18:19:44 105_Static destroyed by 67_Chief at 90765.07 64620.51
18:20:42 g01010(0) successfully bailed out at 53226.87 103675.61
18:20:42 g01010(0) was captured at 53226.87 103675.61
18:31:37 20_Static destroyed by 52_Chief at 62078.23 107358.55
18:39:10 326_Static destroyed by 61_Chief at 94953.19 58452.09
18:40:41 g01020 landed at 27978.844 192552.75
18:42:58 240Squadronmaritime122 landed at 56343.883 120582.55
18:43:33 240Squadronmaritime121 landed at 56606.53 121465.44
18:46:09 3SquadronRAAF102(0) was killed by g01031 at 117529.445 261780.39
18:46:38 3SquadronRAAF102 damaged by landscape at 118912.46 263310.03
18:46:38 3SquadronRAAF102 shot down by g01031 at 118912.46 263310.03
18:46:43 GAE_Angel has disconnected
18:47:19 Castor has disconnected
18:50:06 3SquadronRAAF100 landed at 118971.6 277230.94
18:50:36 3SquadronRAAF100 removed at 119009.77 277285.44
18:52:48 3SquadronRAAF101 landed at 118986.76 277252.47
18:53:18 3SquadronRAAF101 removed at 119009.79 277285.38
18:54:54 3SquadronRAAF103 landed at 119000.04 277271.44
18:55:24 3SquadronRAAF103 removed at 119010.03 277285.7
18:58:14 28_Static destroyed by 240Squadronmaritime112 at 52441.79 108636.44
19:00:23 240Squadronmaritime111 damaged by landscape at 56276.34 121985.88
19:00:26 240Squadronmaritime111 landed at 56274.24 121995.87
19:00:26 240Squadronmaritime111 damaged on the ground at 56274.24 121995.87
19:03:02 240Squadronmaritime112 turned wingtip smokes on at 60125.617 119056.29
19:03:07 240Squadronmaritime112 turned wingtip smokes off at 59784.133 118815.01
19:11:32 240Squadronmaritime110 landed at 56240.84 122019.03
19:12:03 240Squadronmaritime112 damaged by landscape at 56263.062 120722.77
19:12:06 240Squadronmaritime112(0) was killed at 56220.523 120807.96
19:12:06 240Squadronmaritime112 shot down by 32_Chief at 56220.523 120807.96
19:12:38 GAE_Alma has disconnected
19:12:47 Mission END
Corsario + 75% jugo + 2 bombas de 500 Lbs y cohetes.
Salgo del V1 como lider de la primera sección de Corsarios. Sobre la cubierta somos informados de los cambios de planes: debemos realizar un ataque rápido sobre las bases enemigas en C20, A24 y B22. Quedo en la cabina mientras el personal cambia la configuración del aparato colocando bombas y cohetes. Con el OK del oficial de cubierta emprendemos la misión.
Vamos divididos en 2 vuelos: yo, el TF Charrua y el GU Alma por un lado y el CC Angel con el TF Castor por el otro.
Coordinados iniciamos los ataques causando graves destrozos en C20, B22 y A24.
Emprendemos el regreso y cuando estamos por apontar vemos un contacto naval enemigo al que nuestro grupo de portaviones dispara. Identificamos como un submarino enemigo. Hago una pasada exitosa con cohetes y el TF Charru lo hunde en la segunda.
Con el V1 detenido logro apontar pero el TF Charru no puede bajar el tren de aterrizaje por daños producidos por la AAA y se mata en un intento de poner el Corsario de panza en cubierta.
AGK: mínimo 2 hangares mayores.
find 6 human pilots in mission:
Hyper Name       | plane code    | seat
GAE_Yanito       | g01020   | 0
GAE_Balker       | 240Squadronmaritime110   | 0
GAE_Angel       | 240Squadronmaritime121   | 0
GAE_Charrua       | 240Squadronmaritime112   | 0
GAE_Alma       | 240Squadronmaritime111   | 0
Castor       | 240Squadronmaritime122   | 0
==== Actions for pilot GAE_Yanito: ====
18:00:00 GAE_Yanito takes seat: g01020(0) - 8942.103 237759.61
18:00:00 GAE_Yanito loads wep: '2x1000'  fuel: 100%
18:40:41 GAE_Yanito lands - 27978.844 192552.75
-------- SUMMARY for GAE_Yanito:
Akills: 0 | Gkills: 0  | State: Landed
==== Actions for pilot GAE_Balker: ====
18:00:00 GAE_Balker takes seat: 240Squadronmaritime110(0) - 72926.46 95462.73
18:00:00 GAE_Balker loads wep: '2x5008xhvargp'  fuel: 75%
19:11:32 GAE_Balker lands - 56240.84 122019.03
-------- SUMMARY for GAE_Balker:
==== Actions for pilot GAE_Angel: ====
18:00:00 GAE_Angel takes seat: 240Squadronmaritime121(0) - 74111.42 95347.01
18:00:00 GAE_Angel loads wep: '2x5008xhvargp'  fuel: 75%
18:43:33 GAE_Angel lands - 56606.53 121465.44
18:46:43 GAE_Angel has disconected
-------- SUMMARY for GAE_Angel:
==== Actions for pilot GAE_Charrua: ====
18:00:00 GAE_Charrua takes seat: 240Squadronmaritime112(0) - 72936.43 95458.53
18:00:00 GAE_Charrua loads wep: '2x5008xhvargp'  fuel: 50%
18:58:14 GAE_Charrua destroy to 28_Static - 52441.79 108636.44
19:03:02 GAE_Charrua turns smoke On - 60125.617 119056.29
19:03:07 GAE_Charrua turns smoke Off- 59784.133 118815.01
19:12:03 GAE_Charrua damaged by landscape - 56263.062 120722.77
19:12:06 GAE_Charrua was killed  - 56220.523 120807.96
19:12:06 GAE_Charrua was shoot down by 32_Chief - 56220.523 120807.96
-------- SUMMARY for GAE_Charrua:
Akills: 0 | Gkills: 1  | State: Damaged KIA
==== Actions for pilot GAE_Alma: ====
18:00:00 GAE_Alma takes seat: 240Squadronmaritime111(0) - 72938.125 95470.45
18:00:00 GAE_Alma loads wep: '2x5008xhvargp'  fuel: 75%
19:00:23 GAE_Alma damaged by landscape - 56276.34 121985.88
19:00:26 GAE_Alma lands - 56274.24 121995.87
19:00:26 GAE_Alma diches - 56274.24 121995.87
19:12:38 GAE_Alma has disconected
-------- SUMMARY for GAE_Alma:
Akills: 0 | Gkills: 0  | State: Damaged Landed (emerg)
==== Actions for pilot Castor: ====
18:00:00 Castor takes seat: 240Squadronmaritime122(0) - 74109.8 95335.08
18:00:00 Castor loads wep: '2x5008xhvargp'  fuel: 75%
18:42:58 Castor lands - 56343.883 120582.55
18:47:19 Castor has disconected
-------- SUMMARY for Castor:
This exe file was created with the evaluation version of Perl2Exe.
For more information visit http://www.indigostar.com
(The full version does not display this message with a 2 second delay.)
Tempest + 100% jugo + 2 bombas de 1000 Lbs.
Despego de B22 y pongo rumbo 180 para buscar contactos navales. Luego de unos cuantos minutos veo combates muy distantes en el agua y me dirijo a esa zona.
Me alejo rapidamente hacia el norte para evitar la AAA y ver si hay algun avion enemigo por los alrededores, solo veo estelas de reactores muy arriba y al parecer en combate, creo que me detectaron pero su velocidad era muy alta para poder entrerme comodamente y logro escaparme. Ya sobre la base no veo nada para que me quede volando y aterrizo sin problemas
AGK: pegaron en un barco (espero informe)
Fecha: Feb 1963 (primer quincena)
Teniendo la ingrata y terrible tarea de dejar que mi piel se dore producto de un sol abrazador y el reflejo de un calmo mar ingrato... se me acerca un oficial, me encara, se presenta ante mi y me dice:
¨- Mucho stress?¨
¨- y... si, la verdad que no me recupero con el derrocamiento de Frondizi....¨
¨- ahh...veo, pero ya pasó casi un año (29-3-62)¨ me replica.
¨- Es que todo esto es muy fuerte¨ mientras me golpeo el pecho...
Me miró con cara de que tenía ganas de partirme la cabeza con un palo. Abre su saco, y de un bolsillo interno saca un sobre el cual me entrega, sin otra palabra, se da la vuelta y se retira en la misma forma en que vino.
Observo el sobre, y veo que es de la ARA con un sello que dice ¨Reservado - entrega urgente¨.
Lo abro, lo leo, y creo que el stress se me fue de golpe. La cosa era sencilla, o me presento a cumplir mis obligaciones o un paredón de fusilamiento, iba a practicar tiro al blanco conmigo.....
Luego de pensarlo por un largo tiempo, creo que alrededor de un milisegundo, sentía que tenía alta médica.
Al día siguiente me presento en mi cuartel, donde se me entregan mis instrucciones:
_Con caracter de urgencia debía embarcarme en un transporte, el cual iba a reabastecer con repuestos, municiones y víveres entre otras cosas al grupo de tareas de la armada en operaciones en la zona cercana al canal de Suez.
La situación es delicada y hay escacés de pilotos.
Pasados unas 2 semanas de navegación, veo por la borda que se acerca una lancha rápida, y al ponerse a la par, suben 2 oficiales, que informan que el área no es segura para la navegación, y que la gente debía continuar con ellos.
Unas cuantas personas y yo, somos embarcados. Luego de un par de horas, la escuadra naval se va agrandando en el horizonte, el movimiento es incesante, un ir de venir de aviones patrullas, aviones, escoltas, en fin, esto de guerra en serio. Nada se deja al azar.
Una ves abordo me encuentro con antiguos compañeros que ya se dirigían a una misión, unos me miraban contentos, otros con cara de donde me había metido, por el pasillo escucho, esta misión safaste, pero la próxima venís.....
Me acomodo en mi camarote de primera clase de 2 x 1, me siento en mi litera, cierro los ojos y toda una serie de recuerdos y emociones inundan mi ser. No pasan ni 1 minuto que ya me vienen a patear la puerta y que de imediato me aliste, se planifico una nuevo misión, y en vista de mi falta de acción, se me da la orden que valla hacer cabina para familiarizarme con mi antiguo camarada, el F4U #71-.
La verdad que ni un trapo le pasaron en todo este tiempo, no se como no se pegaron los aros, pedí permiso para una puesta en marcha, pero no hubo caso, tuve que pedir que me cambien todas las bujías, estaban empastadas a full.
Me dan el ok. Primer arranque, no pasa nada, segundo.... nada....así haste el sexto, que todo el barco salió corriendo pensando que había explotado un avión..... el humo fue increible, ese olor me devolvió la vida, a pesar de todo el tiempo que no estuvimos juntos, mi viejo #71 daba muestras de fidelidad. Termino los chequeos operativos, me bajo y ordeno que sea alistado y obviamente lavado.
De nuevo en la sala de brief, se me da un muy breve pantallazo de la situación reinante. En eso oigo que se aproximan naves, eran mis compañeros que volvían de otra misión.
Si mucho tiempo para el reencuentro, se nos da el brief de una nueva misión, sobre la marcha se cambian objetivos, los armeros cumplen su trabajo con celeridad, y en poco tiempo me encuentro en cubierta sobre mi Corsario, el mismo estaba al 75% de jugo, 2 pepas de 500 lbs y 8 cohetes. Se me asigna a Angel como líder y la base de C20 como objetivo.
Despegamos y nos dirijimos con rumbo NNO por sobre la margen este del canal hasta nuestro objetivo, durante nuestro vuelo, nos cruzamos con barcos enemigos que practicaron algo de AAA, que por suerte no consiguieron más que molestarnos un poco.
Ya cerca del objetivo, quedo en una posición bastante incómoda al sobrevolar un puerto, empezando un carnaval de fuegos artificiales alrededor de mi aparato. El volar irregularmente para dificultar la precisión de la antiarea, da como efecto no deseado, perder a mi líder.
Lo escucho que pica y hago lo mismo, para ganar más velocidad y escapar rapidamente de la zona.
Veo la zona de mi objetivo y eligo un conjunto cualquiera de hangares, faltando unos 700 metros antes de lanzar mis bombas, veo que los hangares explotan!!!, con tantos hangares por demoler, justo elijo los mismo que Angel. Sigo de largo y al hacer 180 para retomar el ataque una AAA de la base acierta varios disparos. Sin problemas, elijo otra ves unos hangares y descargo mis bombas, me alejo y otra AAA acierta nuevamente, la máquina sigue respondiendo sin problemas. Por radio escucho la incapacidad de lograr daños con los cohetes, así que elijo un hangar cualquiera y compruebo, disparando la salva completa, que tenían razón. Depaso veo que mis bombas destruyeron 2 hangares más.
Comunico lo sucedido con mi jefe y nos vamos de la zona, donde nuevamente somos impactados por AAA, el chequeo visual de las máquina no da ningún tipo de pérdidas. Ponemos rumbo de regreso, encontramos nuestra isla flotante y aterrizo en el V2.
AGK: 2 hangares.
Despego del V1 (o V2??) como lider de la ultima seccion de Corsarios en la que se me asigna al TF_Castor que salia hace muy poco del neuropsiquiatrico aparentemente recuperado y apto para volver a la accion....
Luego de releer las ordenes impartidas, nos dirigimos a los F4 y se nos da la orden de salida.
Volamos con rumbo de costa hacia el norte, noroeste.
Nos cruzamos con fuego AAA de la flota que navegaba el estrecho y al poco tiempo ya estabamos sobre nuestro objetivo.
Nos dirigimos en orden a los blancos entrando a los hangaras orientados de sur a norte y en mi caso dañando dos hangares. Lamentablemente mis cohetes fallaron, pero Castor me informa que nada de daño producian los mismos sobre nuestros target.
Dispongo volver a casa con algo daño leve sobre el fuselaje, igual para Castor.
Navegamos en sentido contrario y al poco tiempor estabamos aterrizados, Castor en el V2 y yo en el V1 (ahi estan las mejore mujeres de la ARA  :P)
Resultado:
AGK= 2 Hangares
Avion: Operativo - Piloto vivo
Salgo del V1 en la primera sección de Corsarios liderada por el Tte Balker y el Tte Charrua completando la formacion.
Nos dirigimos haca el norte siguiendo la costa hasta llegar a nuestro objetivo donde realizamos sendas pasadas descargando las bombas de 500 libras. Yo logro destruir 2 hangares  y daño a un tercero al descargar los 8 cohetes sobre el.
Emprendemos el regreso y nos topamos con un submarino en superficie el cual es hundido por el Tte Charrua, quien lamentablemente pierde la vida al intentar apontar con el avion averiado.
Por mi parte intento varias veces apontar, pero al estar el V1 detenido y con baja visibilidad por la hora, tengo que abortar, hasta que por fin lo logro pero dañanado el tren de aterrizaje de mi corsario.
Avión: ok (daños leves)
AGK: 2 hangares grandes y uno averiado (no se rompen con 8 HVAR????!!!)
INFORME DE BAJAS
GAE
1 F4U-C
IDF-IAF
EGIPTO
4 Tempest
4 Hangares
1 submarino
2 buque
La fuerza  aerea Israelita  logro repeler a tiempo a un escuadron completo de Tempest cargados de bombas, seguramente atacarian a la flota, aun asi uno logro llegar y le dio a un crucero, no se sabe si seguira en combate ese buque. El ataque a las bases enemigas fue bueno y peligroso, lograron pasar por una brecha que no estaba muy protegida. El puerto no sufrio ataques y la Flota se enfrento a un grupo de buques que se encontraron muy de cerca, dañando a los 4 buques de cabecera. 2 enemigos pasaron y se encontraran con la fuerza de portaviones y sus escoltas el resto fue hundido por minas,  fuego naval y ataques aereos.
