Guia del nuevo Parche 4.09 de IL2
Iniciado por GAE_Charrua, 22 de Septiembre de 2009, 01:36:55 PM
A leer muchachos  ;D
http://forum.1cpublishing.eu/showthread.php?t=9977
Cita de: mkubani;103787Hello all,
On behalf of Daidalos Team and with cooperation with Oleg and Maddox Games, I would like to inform you that the work on the 4.09 patch has been finished. Meanwhile the patch is made available for download, we would like to ask you to take your time and please read the following Readme and Guide we have prepared.
Thank you for your patience.
I would appreciate if people could set up few mirror downloads for the Guide. Thank you.
4.09 Readme (Light) - English, Russian, German, French:
http://files.games.1c.ru/il2pict/4.09_Readme.doc
4.09 full PDF Guide (50MB) - English only:
http://files.games.1c.ru/il2pict/4.09_Guide.pdf
http://www.megaupload.com/?d=PQPEJHAP
Citar4.09 README
Warning: The current version 4.09m is not compatible with the previous versions of the sim when playing over the network (Online). Both the server and client must have the appropriate versions in order to connect.
Maps - final versions of
Bessarabia
Iasi
Odessa
MTO
MTO Light
Slovakia Summer
Slovakia Summer Light
Slovakia Winter
Slovakia Winter Light
New Planes
Avia B-534-IV (flyable)
CW-21 (AI only)
Fokker D.XXI - 5 versions (Only SARJA 3 Early and Late flyable)
Fiat G.55 Series I (early and late - AI only)
I-15bis (AI only)
I-16 Type 5 + Ski version (flyable)
I-16 Type 6 + Ski version (flyable)
Letov S-328 (AI only)
Re.2000 (AI only)
SM.79 (flyable)
Cockpits
MC.200 series 7 and series 7 FB flyable (new cockpit)
MC.200 series 3 (improved original cockpit)
Ground objects
MBV-2 and MBV-2 (flak version) trains have new models + all guns are functional
Other
Quick Mission Builder with new features
Updated new default skin pack
Parachutes are not AAA target anymore
Navigational lights turned off during flight by AI planes
Pylon/bomb racks weight fixed -> better climb and takeoff performance for planes armed with external ordnance
Corrections in Flight Models (by Maddox Games)
MC-200 increased airframe drag-> reduced speed
P-11c corrected rudder roll response. Previously left rudder was inducing right roll and vice versa.
Ta-152C wing area corrected from Fw 190D-9 values (~1.2m²) -> slightly improved turn performance
DB-603L critical altitude increased from 9200m to 10200m.
Changes in Graphics (by Maddox Games)
Increased buffer size for stationary objects (buildings etc.) to prevent freezes under some circumstances.
Colors of water corrected for Water=2,3,4 modes. Now when looking down it is no more black/dark blue.
Optimized Shaders for Nvidia 8X00 series video cards.
Added a new mode for increased visibility distance. Visibility increased from 36 km to 72km under "Clear" and
"Good" weather conditions.
Note: This mode is not optimized for performance: (freezes and low fps are possible on low-end systems).
This new feature is available only in "Perfect" game graphics mode.
Also, there is a possibility to have problems with clouds and their shadows at far distances, due to some engine limitations.
Modify your conf.ini string in the [Render_OpenGL] section to use this mode:
LandGeom=3 (new mode is ON)
LandGeom=2 (back to normal mode)
Daidalos Team would like to thank all external beta testers from the following virtual squadrons for their hard work: Letka 13, 6° Stormo Virtuale, 102nd-YU, 352nd VFG, Kraken, and Sean Trestrail
Traduccion Google
Citar4,09 README
Advertencia: La versión actual 4.09m no es compatible con las versiones anteriores de la tarjeta SIM al jugar en la red (en línea). Tanto el servidor y el cliente debe tener las versiones adecuadas a fin de conectar.
Mapas - versiones finales de
Besarabia
Iasi
Odessa
Objetivo a medio plazo
Objetivo a medio plazo de luz
Verano Eslovaquia
Eslovaquia Summer Light
Invierno Eslovaquia
Eslovaquia Winter Light
Nuevos aviones
Avia B-534-IV (puede volar)
CW-21 (AI solamente)
Fokker D. XXI - 5 versiones (Sólo SARJA 3 vespertinas y nocturnas Flyable)
Fiat G.55 Serie I (temprana y tardía - AI solamente)
I-15 bis (AI solamente)
I-16 Tipo 5 + versión de esquí (puede volar)
I-16 Tipo 6 + versión de esquí (puede volar)
Letov S-328 (AI solamente)
Re.2000 (AI solamente)
SM.79 (puede volar)
Cabinas
MC.200 serie 7 y serie 7 FB Flyable (nueva cabina)
Serie MC.200 3 (mejora de la cabina original)
Objetos de baja
La APV-2 y la APV-2 (versión de prueba de balas), los trenes han de nuevos modelos + todas las armas son funcionales
Otro
Rápido Creador de misiones con nuevas características
Actualizado el nuevo paquete de skin por defecto
Paracaídas no se meta AAA más
Apagado las luces de navegación durante el vuelo por aviones de AI
Pylon / bastidores bomba peso fijo -> escalar mejor y el rendimiento de despegue de aviones armados con artefactos externos
Correcciones en los modelos de vuelo (por Maddox Games)
MC-200 resistencia aerodinámica del fuselaje mayor velocidad> reducido
P-11C corregido respuesta rollo de timón. Previamente a la izquierda del timón fue inducir rollo derecha y viceversa.
Ta-152C área del ala corregido de Fw 190D-9 valores (~ 1,2 m ²) -> mejorado ligeramente su vez el rendimiento
DB-603L de altitud crítica aumentó de 9200M a 10200m.
Los cambios en la gráfica (por Maddox Games)
El aumento de tamaño de búfer de objetos fijos (edificios, etc) para evitar que se congela en algunas circunstancias.
Colores de agua corregido por el Agua = 2,3,4 modos. Ahora, al mirar hacia abajo no es más azul / negro oscuro.
Shaders optimizados para las tarjetas de vídeo Nvidia 8x00 series.
Añadido un nuevo modo para la distancia mayor visibilidad. Mayor visibilidad de 36 km a 72 kilometros bajo "Borrar" y
"Bueno" las condiciones meteorológicas.
Nota: Este modo no está optimizado para el rendimiento: (se congela y fps bajos son posibles en los sistemas de gama baja).
Esta nueva función está disponible sólo en "Perfect" modo de gráficos del juego.
Además, existe la posibilidad de tener problemas con las nubes y sus sombras, a distancias mucho, debido a algunas limitaciones del motor.
Modifique la cadena de conf.ini en la sección [Render_OpenGL] para utilizar este modo:
LandGeom = 3 (nuevo modo está en ON)
LandGeom = 2 (volver al modo normal)
Daidalos equipo le gustaría agradecer a todos los beta testers externos de los escuadrones virtuales siguientes por su arduo trabajo: letka 13, 6 ° Stormo Virtuale, YU-102a, 352a VFG, Kraken, y Sean Trestrail
Traduccion by GAEv ;D
Flak:
Citar"Pylon/bomb racks weight fixed -> better climb and takeoff performance for planes armed with external ordnance"
Esto no solucionaría el tema de el peso excesivo de los cohetes?
Citar"CW-21 (AI solamente)"
NOOOOOOO lo qu equeria ese avion volableeee!!!!!!
Cita de: GAE_Baco en 22 de Septiembre de 2009, 02:34:31 PM
Supongo que media hora después de la salida del MOD lo vas a tener crakeado para volar con otra cabina como pasó con los anteriores.
Pero tengo queesperar media hora.... ;D
Y despues tengo que proponerlo para el Estandard del GAE..  ;D ;D  ;D
lei que dan muchas mas opciones para el creador de misiones, como "desencadenadores" de eventos que pueden hacer las misiones mucho mas dinamicas. se va a actualizar durante la campaña o vamos a esperar a que termine?.
trate de averiguar pero no consegui nada concreto, saben si los mods vana  seguir andando con la nueva version?.
saludos.
Esto está planeado para parches subsiguientes Chape, así como el radar y otras sorpresas mas...
Yo que?    ???
Me parece que iba para Gaucho  ::)
Correctisimo Sr. Chape, mil disculpas, el mensaje hiba para Gaucho...
