CHIPRE 11
Iniciado por GAE_Balker, 01 de Mayo de 2009, 09:30:27 AM
CONTROL AEREO DE NICOSIA
¡Alerta!
Doce contactos menores aproximándose a la isla.
De no haber indicaciones de aeronaves de ataque propongo buscar superioridad numérica localizada, concentrando todos los vuelos en un punto dado y encarar al enemigo de a un grupo por vez, usando tacticas de pareja y cambiando de blanco como se necesario.
Teniendo en cuenta el alto grado de efectividad de las Brujas, lo mejor en este punto de la campaña sería reducir al máximo las perdidas de materialy humanas, no?
Baco, Los turcos tienen P-47, así que en un radar puede salir como blanco menor.
Así y todo, si, pienso hacer una intercepción total.
8 F-80A + 4 Sea hawks
Quién se anota de control radar?, va ser muy importante el manejo de las escuadrillas.
Me anoto para radar.
Voy a tener control total de las escuadrillas?
Cita de: GAE_Mano en 01 de Mayo de 2009, 12:30:23 PM
Si.
GAE_Tango
[02.05.2009 3:28:51] Mission: net/coop/GAE/Chipre11.mis is Playing
11:52:00 Mission BEGIN
11:52:00 GAE_Tango is trying to occupy seat UN_NN021(0)
11:52:00 GAE_Balker is trying to occupy seat UN_NN020(0)
11:52:00 GAE_Chacal is trying to occupy seat UN_NN031(0)
11:52:00 GAE_Angel is trying to occupy seat UN_NN030(0)
11:52:00 TangBlackmonkey has connected
11:52:00 TangBlackmonkey has disconnected
11:52:00 GAE_Baco is trying to occupy seat UN_NN000(0)
11:52:00 GAE_Mano is trying to occupy seat UN_NN023(0)
11:52:00 GAE_Charrua is trying to occupy seat UN_NN003(0)
11:52:00   has connected
11:52:00 GAE_Buitre has connected
11:52:00   is trying to occupy seat UN_NN022(0)
11:52:00   is trying to occupy seat UN_NN023(0)
11:52:00   is trying to occupy seat UN_NN001(0)
11:52:00   is trying to occupy seat UN_NN000(0)
11:52:00   is trying to occupy seat UN_NN002(0)
11:52:00   is trying to occupy seat UN_NN021(0)
11:52:00 GAE_Buitre is trying to occupy seat UN_NN032(0)
11:52:00   has disconnected
11:52:00   is trying to occupy seat UN_NN003(0)
11:52:00 GAE_Tacuara is trying to occupy seat UN_NN002(0)
11:52:00 GAE_Tacuara is trying to occupy seat UN_NN001(0)
11:52:00 UN_NN021(0) seat occupied by GAE_Tango at 64430.234 69278.64
11:52:00 UN_NN021 loaded weapons 'LR-LongRange' fuel 100%
11:52:00 UN_NN002(0) seat occupied by   at 55131.07 78849.49
11:52:00 UN_NN002 loaded weapons 'default' fuel 100%
11:52:00 UN_NN020(0) seat occupied by GAE_Balker at 64459.465 69265.016
11:52:00 UN_NN020 loaded weapons 'LR-LongRange' fuel 100%
11:52:00 UN_NN031(0) seat occupied by GAE_Chacal at 61867.535 73747.47
11:52:00 UN_NN031 loaded weapons 'LR-LongRange' fuel 100%
11:52:00 UN_NN030(0) seat occupied by GAE_Angel at 61867.516 73715.22
11:52:00 UN_NN030 loaded weapons 'LR-LongRange' fuel 100%
11:52:00 UN_NN003(0) seat occupied by GAE_Charrua at 55105.227 78871.17
11:52:00 UN_NN003 loaded weapons 'default' fuel 100%
11:52:00 UN_NN001(0) seat occupied by GAE_Tacuara at 55156.895 78827.79
11:52:00 UN_NN001 loaded weapons 'default' fuel 100%
11:52:00 UN_NN023(0) seat occupied by GAE_Mano at 64371.777 69305.91
11:52:00 UN_NN023 loaded weapons 'LR-LongRange' fuel 100%
11:52:00 UN_NN032(0) seat occupied by GAE_Buitre at 61867.527 73779.72
11:52:00 UN_NN032 loaded weapons 'LR-LongRange' fuel 100%
11:52:00 UN_NN000(0) seat occupied by GAE_Baco at 55182.754 78806.125
11:52:00 UN_NN000 loaded weapons 'default' fuel 100%
11:53:31 UN_NN030 in flight at 61836.316 72233.125
11:53:32 UN_NN020 in flight at 66175.46 68468.26
11:53:41 g01230 damaged on the ground at 62212.85 211185.19
11:53:41 g01230(0) was wounded at 62212.85 211185.19
11:53:41 g01230(0) was heavily wounded at 62212.85 211185.19
11:53:41 g01230(0) was killed at 62212.85 211185.19
11:53:41 g01230 shot down by landscape at 62212.85 211185.19
11:53:47 UN_NN021 in flight at 66301.52 68412.18
11:53:58 g01231 damaged on the ground at 62212.965 211185.4
11:53:58 g01231(0) was wounded at 62212.965 211185.4
11:53:58 g01231(0) was killed at 62212.965 211185.4
11:53:58 g01231 shot down by landscape at 62212.965 211185.4
11:54:04 UN_NN001 in flight at 56505.504 77715.58
11:54:09 UN_NN000 in flight at 57679.46 76616.02
11:54:16 UN_NN031 in flight at 62318.094 70906.0
11:54:20 UN_NN032 in flight at 62139.99 71267.57
11:54:27 UN_NN002 in flight at 56817.758 77475.875
11:55:04 UN_NN003 in flight at 56816.777 77468.46
11:57:10 UN_NN002 turned wingtip smokes on at 61080.34 83989.87
11:57:10 UN_NN002 turned wingtip smokes off at 61031.797 84017.56
12:07:26 g01111 damaged by UN_NN020 at 65656.195 93753.34
12:07:26 g01111 damaged on the ground at 65656.195 93753.34
12:07:31 g01111(0) bailed out at 65633.83 92894.02
12:07:37 g01110 damaged by UN_NN021 at 65522.67 91373.79
12:07:37 g01110 damaged on the ground at 65522.67 91373.79
12:07:43 g01110(0) bailed out at 65487.867 90614.21
12:07:59 g01111 shot down by UN_NN020 at 67385.86 89210.04
12:08:21 g01110 shot down by UN_NN021 at 66991.63 84610.945
12:09:45 g01100(0) was heavily wounded at 62020.55 127968.125
12:09:53 g01100 damaged on the ground at 62635.992 128164.67
12:09:53 g01100(0) was killed at 62635.992 128164.67
12:10:04 g01100 damaged by landscape at 63536.316 128471.49
12:10:04 g01100 shot down by UN_NN032 at 63536.316 128471.49
12:11:57 UN_NN032 turned wingtip smokes on at 58091.31 127333.74
12:11:59 UN_NN032 turned wingtip smokes off at 58229.848 127369.24
12:13:46 13_Static destroyed by g01200 at 62147.92 81460.19
12:13:46 14_Static destroyed by g01200 at 62150.01 81463.48
12:13:55 g01110(0) successfully bailed out at 65070.504 88416.96
12:13:55 g01110(0) was captured at 65070.504 88416.96
12:14:24 g01111(0) successfully bailed out at 65943.4 90625.54
12:14:24 g01111(0) was captured at 65943.4 90625.54
12:14:26 UN_NN031(0) was wounded at 63090.65 101685.92
12:14:26 UN_NN031(0) was killed at 63090.65 101685.92
12:14:26 UN_NN031 shot down by g01210 at 63090.65 101685.92
12:15:50 UN_NN023 in flight at 66321.83 68323.99
12:16:46 g01211 damaged on the ground at 69227.414 104671.62
12:16:46 g01211 damaged by landscape at 69230.56 104672.25
12:16:46 g01211(0) was wounded at 69230.56 104672.25
12:16:46 g01211(0) was killed at 69230.56 104672.25
12:16:46 g01211 shot down by UN_NN032 at 69230.56 104672.25
12:16:53 UN_NN032 damaged by landscape at 67592.2 103514.76
12:16:53 UN_NN032(0) was killed at 67592.2 103514.76
12:16:53 UN_NN032 shot down by landscape at 67592.2 103514.76
12:18:54 UN_NN030(0) was wounded at 64885.4 78673.6
12:18:54 UN_NN030(0) was killed at 64885.4 78673.6
12:18:54 UN_NN030 shot down by g01130 at 64885.4 78673.6
12:19:14 GAE_Angel has disconnected
12:19:34 UN_NN001(0) was killed at 68850.43 79447.21
12:19:34 UN_NN001 shot down by landscape at 68850.43 79447.21
12:20:08 GAE_Tacuara has disconnected
12:20:59 UN_NN000(0) was killed at 75668.516 88105.26
12:20:59 UN_NN000 shot down by landscape at 75668.516 88105.26
12:21:11 GAE_Buitre has disconnected
12:21:42 g01130 damaged on the ground at 71931.79 87497.1
12:21:42 g01130 damaged by landscape at 71923.47 87498.484
12:21:42 g01130(0) was killed at 71923.47 87498.484
12:21:42 g01130 shot down by UN_NN020 at 71923.47 87498.484
12:22:33 GAE_Baco has disconnected
12:24:11 UN_NN020 damaged by g01210 at 60510.195 77634.55
12:24:11 g01210 damaged on the ground at 60513.27 77631.32
12:24:11 g01210 damaged by UN_NN020 at 60513.27 77631.32
12:24:11 UN_NN020(0) was wounded at 60506.332 77648.83
12:24:11 UN_NN020(0) was killed at 60506.332 77648.83
12:24:11 UN_NN020 shot down by g01210 at 60506.332 77648.83
12:24:11 g01210(0) was wounded at 60490.15 77735.07
12:24:11 g01210(0) was killed at 60490.15 77735.07
12:24:11 g01210 crashed at 60490.15 77735.07
12:26:11 g01120 damaged on the ground at 53071.203 85051.9
12:26:11 g01120 damaged by NONAME at 53071.203 85051.9
12:26:11 12_Static destroyed by g01120 at 53070.07 85047.64
12:26:11 g01120(0) was killed at 53071.234 85048.06
12:26:11 g01120 crashed at 53071.234 85048.06
12:26:11 10_Static destroyed by g01120 at 53070.93 85050.35
12:29:35 UN_NN003 landed at 55456.742 78597.695
12:32:37 UN_NN002 turned wingtip smokes on at 100578.43 179717.52
12:33:19 UN_NN002 turned wingtip smokes off at 106993.375 174200.86
12:35:54 GAE_Charrua has disconnected
12:38:19 UN_NN021 landed at 61929.31 73228.84
12:38:41 UN_NN023 landed at 55881.582 78234.05
12:39:28 Mission END
GAE_Tango
Guardiamarina
La mision se acaba cuando el gancho agarra el cable!
GAE_Tango
F80 jugo 100%
Salgo como numeral de la escuadrilla lidarada por Balker, nos trabamos en combate y rapidamente despachamos a una pareja de sabres sorprendiendolos por detras.
En el combate posterior, le disparo unas rafagas a un P47, y veo como Balker lo derriba, mas tarde un sabre colisiona contra Balker y veo como es derribado asi que eso fue todo puse rumbo a la base.
AAK: 1
AGK:0
Avion: Aterrizado, ok
GAE_Tango
Guardiamarina
Avión: Hunter Sea Hawk, Default, 100%
Salgo En la escuadrilla liderada por el TF Baco para hacer CAP al norte de Chipre. Nos posicionamos en la vertical y tratamos de llegar a 6000mts. Luego de un rato el radar nos avisa de presencias hostiles. No logro ver ningún blanco. Me voy desplazando por linea de costa hacia el SE, hasta que en determinado momento el avión inicia un tonel y se cae como ladrillo, sin darme la oportunidad de saltar, después de eso, la muerte.
Salgo de numeral de Baco, para hacer cap sobre Chipre , nos ponemos a 4500m y sobre mazaki nos avisa el radar de contactos enemigos, logro ver un contacto que persigue a uno de los nuestro , lo persigo y me asegesco, en varias pasadas le descargo todo el armamento, ahí empieza mi odisea, como ayudar sin arma , le empiezo a forma al enemigo para contrariarlo y molestarlo , hasta que vienen los nuestros, se acerca Tacuara , y se lo dejo , me formo a la seis y le tira, otra ves me pongo cerca, y sigo molestando, pero no logran derriba. Veo un especie de choque ,  del cual sale Tacuara en caída sin ver bien que paso,  después me encuentro solo y pido a base información, me indican que contactos enemigos se acerca a los radares, me voy al encuentro para molestar ya que sin armas mucho no podía hacer.
No logro ver los enemigos , después de dar unas vueltas y con dos compañeros en vuelo , la situación estaba controlada aterrizo , sin novedades aparcando mi avión en el hangar.
AGK:0
Avion:  ok
F80 - 100% jugo - tanques y armamento default
Salgo al momento del primer derrivo, ya que al inicio de la mision maniobro como radar.
En el aire solo quedan dos contactos, un P47 y un sabre.
En una pasada logro dañar un P47 el que es terminado de rematar por un camarada.
Al tener tanques llenos quedo orbitando sobre la isla hasta que la amenaza pase.
Como ultimo miembro en el aire logro aterrizar sin novedades.
AAK=0
Avion=ok
Piloto=ok
F80A - 100% jugo - Tanques suplementarios.
Salgo de lider, con el GU Tango como numeral. Nos dirigimos al sector asignado por el control de tierra hasta que somos vectoreados hacia el Oeste de la isla. En trayecto vemos 2 reactores con rumbo sur hacia Chipre. Nos colamos por sus 6 e identifico como Sabres. Veo al lider que hace un ascenso y vuelve a entrar e formación. En una pasada que no duró más de 5 segundos, con el GU Tango derribamos a los 2.
Una vez completado el movimiento requerido por el control de tierra, detectamos combates a baja altura. Junto a otros comenzamos a perseguir a un P47 turco. Le hago una primer pasada logrando impactos y a la segunda logro arrancarle un timón de profundidad. El turco entra en picada, no puede recuperar y cae en el mar.
Volvemos sobre la vertical de la pista y nos informan de 1 contacto alto. Escucho que dicen que pica, intento un giro por izquierda pero mi avión explota. El estallido del aparato hace a su vez explotar al enemigo, llevándomelo a la tumba.
AAK: 2 (1 Sabre y 1 P47)
Avión: destruído.
Salgo como punto de la formacion liderada por angel. Nos dirigimos con rumbo norte al territorio enemigo tratando de divisar contactos enemigos, lejos de la costa y poder darles casa desde alli. Luego de unos minutos de vuelo veo un contacto volar a baja altura. Inicio la picada y me pongo a sus 6 logrando pinchar el tanque. Momento en el cual veo que larga la carga. En eso creo que chacal tambien le hace un pasada. Y finalmente en mi segunda corrida le explota el radiador y se enciende fuego. Segundos mas tarde confirmo el blanco abatido. Un thunderbolt P47. De regreso a la base en ayuda el lider informa estar combatiendo con 3 F84. Busco ganar altura y me encuentro con 2 F84. Le doy casa a uno y cuando estoy virando en calesita con el otro entro en black out y no logro recuperar mas. En pocos segundo me encuentro sentado en una nube y todo mojado.
AAK: 2 (1 F84 y 1 P47)
Avión: destruído.
Derribos:
Turcos: 3 P47, 2 Sabre, 4 F84. (Total: 9).
Propios: 5 F80A, 2 Sea Hawk. (Total: 7).
Track: http://rapidshare.com/files/228329828/Trakchipre11.zip.html
