GAEV MAGAREVA 07
Iniciado por GAE_Flak, 23 de Marzo de 2006, 01:44:39 AM
GAEV MAGAREVA 07
Inteligencia informa que las fuerzas de Magareva est?n planeando una ofensiva blindada. Para ello est?n reforzando 40 tanques IS-2 en la factoria ubicada en AM05. Nuestra misi?n consiste en un bombardeo a nivel de las instalaciones con el objeto de destruir los tanques all? aparcados.
Como el objetivo est? ubicado en cercanias del aer?dromo de Naha se puede esperar fuerte oposici?n a?rea.
08:00 horas.
Corsarios 01 y 02:
Altura de crucero: 12000 FT
Carga: estandar (default) + 100% combustible
Cobertura aire aire y defensa de los bombarderos.
Corsarios 09, 10 y 11:
Carga: 1 bombas de 1000 kg + 2 bombas de 500 kg + 100% combustible
Bombardeo a nivel de la factoria al un?sono con los B-25
B-25 05, 06 y 07:
Carga: 3 bombas de 500 kg + 100% combustible
Bombardeo a nivel de la factoria.
Seahawk 01:
Notas:
BUEN VUELO!!
Magareva 07 debriefing
Cazas
Corsario 01: GAE Balker
Corsario 02: GAE Mano
Bombarderos
B-25 05: GAE Flak
B-25 06: GAE Condor
B-25 07: GAE Charrua
Corsario 09: GAE Castor
Corsario 10: GAE Tigre
Corsario 11: GAE IA
[Mar 24, 2006 11:30:08 PM] Mission: net/coop/Magareva/MAGAREVA_07.mis is Playing
08:00:00 Mission BEGIN
08:00:00 UN_NN010(0) seat occupied by GAE_Flak at 166705.05 91476.98
08:00:00 UN_NN011(0) seat occupied by GAE_Condor at 166695.05 91489.98
08:00:00 UN_NN012(0) seat occupied by GAE_Charrua at 166705.05 91502.98
08:00:00 UN_NN301(0) seat occupied by GAE_Mano at 172995.5 95066.34
08:00:00 UN_NN300(0) seat occupied by GAE_Balker at 173009.5 95066.34
08:00:00 UN_NN020(0) seat occupied by GAE_Castor at 166692.05 91508.98
08:00:00 UN_NN021(0) seat occupied by GAE_Tigre at 166709.05 91516.98
08:00:48 UN_NN300 in flight at 173017.17 94147.76
08:00:57 UN_NN301 in flight at 173040.17 93974.0
08:00:58 UN_NN010 in flight at 166711.92 90089.805
08:01:12 UN_NN011 in flight at 166745.17 90147.01
08:01:31 UN_NN012 in flight at 166792.17 89860.11
08:02:01 UN_NN020 in flight at 166732.61 90029.0
08:02:18 UN_NN021 in flight at 166721.94 90114.055
08:17:42 IJN_H_703z010 damaged by landscape at 158318.95 27652.547
08:17:42 IJN_H_703z010(0) was killed at 158318.95 27652.547
08:17:42 IJN_H_703z010 shot down by UN_NN300 at 158318.95 27652.547
08:19:13 IJN_H_703z012 damaged by landscape at 152563.25 25742.771
08:19:13 IJN_H_703z012(0) was killed at 152563.25 25742.771
08:19:13 IJN_H_703z012 shot down by UN_NN301 at 152563.25 25742.771
08:24:42 225_Static destroyed by UN_NN020 at 105750.01 27020.08
08:24:42 226_Static destroyed by UN_NN020 at 105939.57 27139.4
08:24:44 224_Static destroyed by UN_NN021 at 106099.98 26900.12
08:24:45 221_Static destroyed by UN_NN012 at 105600.18 26899.97
08:25:52 IJN_H_703z011 damaged by UN_NN301 at 147400.9 30516.672
08:25:58 IJN_H_703z011(0) was wounded at 147057.53 30679.816
08:25:58 IJN_H_703z011(0) bailed out at 147057.53 30679.816
08:26:06 IJN_H_703z011 shot down by UN_NN301 at 146522.97 30869.393
08:27:21 IJN_H_703z011(0) successfully bailed out at 146470.25 31086.988
08:35:59 GAE_Balker has disconnected
08:38:01 IJN_H_703z000 landed at 71502.18 27708.625
08:38:01 IJN_H_703z000 damaged on the ground at 71502.18 27708.625
08:38:06 IJN_H_703z000(0) bailed out at 71502.18 27708.625
08:38:16 IJN_H_703z000(0) successfully bailed out at 71526.766 27767.855
08:39:01 IJN_H_703z000 crashed at 71502.18 27708.625
08:41:53 UN_NN010 landed at 166690.03 90035.73
08:42:43 UN_NN010(3) seat occupied by GAE_Flak at 166689.39 90007.91
08:43:44 UN_NN011 landed at 166700.75 90035.0
08:46:24 UN_NN012 landed at 166698.53 90070.47
08:48:08 UN_NN021 landed at 166718.38 90713.375
08:48:08 UN_NN021 damaged on the ground at 166718.38 90713.375
08:48:15 UN_NN021(0) bailed out at 166718.55 90713.37
08:48:24 UN_NN021(0) successfully bailed out at 166758.36 90680.77
08:49:03 UN_NN301 landed at 173005.14 87001.445
08:49:33 UN_NN020 landed at 166696.27 90368.945
08:49:47 Mission END
State: Landed at Airfield
Hit Bombs:    3
Enemy AAA Kill: 2
Enemy AAA Kill: 1
Hit Bombs:    3
Enemy AAA Kill: 1
Enemy Aircraft Kill: 2
State: Left the Game
Enemy Aircraft Kill: 1
Aviones:
F4U - N? 1 - TC Balker: 1 AAK (Disco).
F4U - N? 2 - GU Mano: 2 AAK (Apontado).
Relato:
Salimos del V1 con misi?n de escolta de una formaci?n mixta de B-25 y Corsarios. El blanco, una f?brica en AM05. La navegaci?n sin novedad, haciendo "S" sobre los B-25. Sobre el segundo WP se detectan 3 cazas La-11 en aproximaci?n. Le doy la orden al GU Mano de que permanezca junto a los B-25 mientras me dirijo a los enemigos para romper la primera pasada. Los sobrepaso, giro por derecha y engancho al primero. El GU Mano los ve venir e informa que rompe. Le ordeno entrar en combate. Logro impactos a distancia sobre el primer La, que aborta el ataque. M?s tarde se sabr? que el piloto tuvo que saltar. Mientras busco otro blanco recibo impactos y pico para sacarmelo de encima. El GU Mano me lo saca y termina derrib?ndolo. Nos reunimos con los bombers en el camino de regreso. De repente, no recuerdo m?s nada...(disco)  ;)
Informo a la Jefatura del GAE del correcto y disciplinado desempe?o del GU Mano en esta misi?n.
Prolijo vuelo en general y que volvimos todos!!!!!!
Posterior al despegue se forman los B-25 y m?s atr?s, los pesados Corsair con Tigre y un IA completabamos el grupo de ataque.
Con una impecable navegaci?n a cargo de Flak y con la tambi?n prolija cobertura a cargo de Balker y su punto Mano pusimos rumbo al objetivo.
En el tramos final, aparecieron unos cazas enemigos que fueron contrarrestados x la CAP.
Ya sobre el mismo pudimos reci?n los corsair arrimarnos a la formaci?n principal y largamos las bombas al unisono con ellos.
Posterior volvimos a la base y aterrizamos sin novedad.
Mucho no puedo agregar , lo unico para destacar es la perfecta navegacion, lugo del ataque nos dirigimos a casa sin mas novedades.
Aterrizamso y nos dirigimos a la cantina a pagarle una cerveza al TN, por traenos de vuelta.
Las fotos vienen despues las estan revelando. ;)
Corregido, no creo poder pagar la diferencia con mi magro sueldo  :P
Si se refiere a mi, adem?s de la cerveza, me va a tener que pagar la diferencia de sueldo.
Fotos Reveladas  ;D
Thanks to ImageShack for Free Image Hosting
