Canal de Suez 07.1
Iniciado por GAE_Yanito, 10 de Noviembre de 2008, 10:29:29 PM
Esta lista la mision de traslados y suministros
[Nov 12, 2008 1:35:18 AM] Mission: net/coop/CANAL DE SUEZ/SUEZ_07_1.mis is Playing
00:00:00 Mission BEGIN
00:00:00 Mission END
[12.11.2008 1:20:37] Mission: net/coop/sinai_7.1/SUEZ_07_1.mis is Playing
00:00:00 GAE_Yanito is trying to occupy seat gb01300(0)
00:00:00 gb01310(0) seat occupied by GAE_Angel at 180068.25 290454.5
00:00:00 gb01310 loaded weapons 'default' fuel 25%
00:00:00 gb01300(0) seat occupied by GAE_Yanito at 180110.19 290319.3
00:00:00 gb01300 loaded weapons 'default' fuel 100%
00:00:02 gb01310 turned landing lights on at 180068.27 290454.53
00:00:56 gb01310 in flight at 179511.12 289584.6
00:01:24 gb01310 turned landing lights off at 179009.31 287639.53
00:01:32 gb01300 in flight at 180896.36 291388.94
00:10:21 gb01320 removed at 204426.52 32521.076
00:13:12 gb01321 removed at 204426.2 32520.861
00:16:01 gb01322 removed at 204425.88 32520.828
00:18:44 gb01323 removed at 204425.53 32520.736
[12.11.2008 1:51:28] Mission: BLUE WON
00:34:18 gb01301 damaged on the ground at 164333.95 39655.41
00:34:18 gb01301 damaged by gb01302 at 164333.95 39655.41
00:34:18 gb01302 damaged on the ground at 164341.6 39654.895
00:34:18 gb01302 damaged by gb01301 at 164341.6 39654.895
00:34:22 gb01302(0) bailed out at 164215.73 39009.2
00:34:22 gb01301(0) bailed out at 164217.11 39005.207
00:34:23 gb01311 damaged on the ground at 166505.34 43832.0
00:34:23 gb01311 damaged by gb01312 at 166505.34 43832.0
00:34:23 gb01312 damaged on the ground at 166520.27 43829.73
00:34:28 gb01311(0) bailed out at 166508.72 43211.246
00:34:29 gb01311(1) bailed out at 166511.11 43036.285
00:34:30 gb01311(2) bailed out at 166498.55 42864.168
00:34:44 gb01311(4) was killed at 166362.06 41153.676
00:34:44 gb01311(5) was killed at 166362.06 41153.676
00:34:44 gb01311 shot down by gb01312 at 166362.06 41153.676
00:34:53 gb01302 shot down by gb01301 at 163881.48 35025.965
00:34:53 gb01301 shot down by landscape at 163964.67 34947.65
00:38:10 gb01311(0) successfully bailed out at 166822.88 41598.418
00:38:22 gb01311(2) successfully bailed out at 166120.92 41490.02
00:38:32 gb01311(1) successfully bailed out at 166271.31 41567.52
00:38:35 g01000 landed at 119017.6 277296.66
00:38:43 gb01310 turned landing lights on at 158060.2 16354.401
00:39:05 g01000 removed at 119071.63 277373.8
00:42:16 gb01301(0) successfully bailed out at 163028.42 36456.79
00:42:38 gb01302(0) successfully bailed out at 163091.03 36488.71
00:43:14 gb01310(1) was killed at 155541.55 13532.322
00:43:14 gb01310(4) was killed at 155541.55 13532.322
00:43:14 gb01310(0) was heavily wounded at 155541.55 13532.322
00:43:14 gb01310(0) was killed at 155541.55 13532.322
00:43:14 gb01310(2) was killed at 155541.55 13532.322
00:43:14 gb01310(5) was killed at 155541.55 13532.322
00:43:14 gb01310 shot down by landscape at 155541.55 13532.322
00:50:29 gb01300 landed at 154701.17 12288.369
00:50:51 Mission END
Mision: SUEZ_07_1.mis
Resultado: Desconocido
GAE_Angel...........gb01310(0)..........KIA
GAE_Yanito..........gb01300(0)..........Landed
Nick: GAE_Angel   Avion: gb01310  Asiento: (0)
AKills: 0
GKills: 0
Status: KIA
Vencido por: landscape
Nick: GAE_Yanito   Avion: gb01300  Asiento: (0)
AKills: 0
GKills: 0
Status: Landed
- traslado de Panthers
50% (se tendra que revisar el track por posible accidente de la IA o por Flak enemiga) si la causante de la perdida de dos panters fuera la IA no se consideran las bajas pero el traslado queda al 50%
Resultado 2 panthers en nueva base
- traslado de Neptunes
50% tambien hay que revisar el track , por que  un neptune aparentemente fue victima de fuego antiaereo y otro pareceria que tiene un bug en esa pista cuando aproxima.
Resultado 2 Neptunes en nueva base
#05- P2 Neptune - Fuel=25%
Despegamos de la base de beersheba con destino a P-2, la navegación era bastante tranquila, la noche clara.
Llegando a R-14 tengo AAA naval sobre el Estrecho de Tiran y lo mismo se vuelve a repetir en R-8.
Aprosimadamente en la misma zona tambien me encuentro con AAA de los blindados que se trasladan por el camino costero. Fue por aquí donde perdí un IA.
Una vez que tengo la ciudad a la vista, visualizo la base y desciendo a unos 240km/h desplegando uno punto de flaps. Ya sobre final a 215km/h y con full flaps me encontraba a 500 mts de altura ay a 300mts de la pista en final la aeronva toca el suelo sin motivo aparente y explota.#no se cuenta como muerte ya que no fue un problema del piloto#
Resultado:
3 Neptunes aterrizados IA + human
Piloto vivo - Avion operativo
TRACK http://rapidshare.com/files/163018596/7.1.ntrk.html
#14- PANTHER - Fuel=100%
Despegamos de la base de beersheba con destino a P-2, por delante estaban los neptunes, voy ganando altura y bajando potencia para  no consumir tanto.
cuando tengo el estrecha di Tinian a mis nueves veo luces de busqueda por abajo y algunas Flak que explotan al rededor mio pero sin pegarme.
Mas adelante cuando cambio la formacion 2 panthers se chocan entre si y caen, sigo con mi winman y me quedo ya sobre la pista esperando alos neptunes, en el mar habia combates lejanos.
Cuando me informan por radio que hay un accidente en la pista me dispongo a ir preparando mi aterrizaje y finalmente llego en final sin problemas.
Luego de ver el track
voy a pedir un testeo de los aterrizajes, sobre todo con los neptunes ya que en el track parece que chocara con algo  invisible entrando desde el sur, yo entre desde el norte siempre y no me paso eso.
Resultado:
2 panthers aterrizados
Piloto vivo - Avion intacto
no se contaran como bajas las perdidas en esta mision por que fueron accidentes por error del simulador. si se cuentan los aviones que quedaron como traslado, ose 2 panthers y 2 neptunes disponibles
