Mar de Java 15 20/12/52
Iniciado por GAE_Castor, 19 de Diciembre de 2010, 09:22:09 PM
MISION 15
A transportar:
Cantidades a confirmar
Vuelo1
F4U5 traslado, 50% combustible, avión limpio.
Decolé de Palembang con rumbo 20/45. Aponté sin novedad.
Avion: ok, apontado
F4U5, 50% combutible, avion limpio.
Avion: hélice rota, ala izquierda destruida.
F4U-5 Corsario - 40% Fuel
Texan - 50% Fuel
F4U5 Corsario - 50% Fuel
Traslado de Palembang al V2
3er Vuelo:
Texan - 50% Fuel
Traslado de Palembang al V1
[21.12.2010 3:09:59] Mission: net/dogfight/GAEV/JAVA 13.mis is Playing
[3:09:59] Mission BEGIN
[3:10:13] GAE_Ceteu has connected
[3:10:23] GAE_Chape:H19D(0) seat occupied by GAE_Chape at 312239.8 341357.25
[3:10:23] GAE_Chape:H19D loaded weapons '02x.50cal.MG+24x2.75.Rocket' fuel 50%
[3:10:25] GAE_Cuervo has connected
[3:12:18] GAE_Pepper:F4U5_Corsario(0) seat occupied by GAE_Pepper at 312220.47 341422.03
[3:12:18] GAE_Pepper:F4U5_Corsario loaded weapons 'none' fuel 50%
[3:12:40] GAE_Popeye:F4U5_Corsario(0) seat occupied by GAE_Popeye at 312241.62 341276.8
[3:12:40] GAE_Popeye:F4U5_Corsario loaded weapons 'none' fuel 50%
[3:12:54] GAE_Alma:F4U5_Corsario(0) seat occupied by GAE_Alma at 312240.72 341197.25
[3:12:54] GAE_Alma:F4U5_Corsario loaded weapons 'none' fuel 20%
[3:13:33] GAE_Cuervo:F4U5_Corsario(0) seat occupied by GAE_Cuervo at 312238.56 341585.22
[3:13:37] GAE_Ceteu:F4U5_Corsario(0) seat occupied by GAE_Ceteu at 312239.03 341530.44
[3:13:37] GAE_Ceteu:F4U5_Corsario loaded weapons 'default' fuel 60%
[3:13:42] GAE_Cuervo:F4U5_Corsario loaded weapons 'default' fuel 60%
[3:14:07] IN_NN00{IN_NN000;FW-200C-3U4;2}(2) was killed at 312297.0 343096.12
[3:14:07] IN_NN00{IN_NN000;FW-200C-3U4;2}(0) was killed at 312297.0 343096.12
[3:14:07] IN_NN00{IN_NN000;FW-200C-3U4;2}(1) was killed at 312297.0 343096.12
[3:14:07] IN_NN00{IN_NN000;FW-200C-3U4;2}(3) was killed at 312297.0 343096.12
[3:14:07] IN_NN00{IN_NN000;FW-200C-3U4;2}(4) was killed at 312297.0 343096.12
[3:14:07] IN_NN00{IN_NN000;FW-200C-3U4;2}(5) was killed at 312297.0 343096.12
[3:14:07] IN_NN00{IN_NN000;FW-200C-3U4;2}(6) was killed at 312297.0 343096.12
[3:14:07] IN_NN00{IN_NN000;FW-200C-3U4;2}(7) was killed at 312297.0 343096.12
[3:14:07] IN_NN00{IN_NN000;FW-200C-3U4;2}(8) was killed at 312297.0 343096.12
[3:14:07] IN_NN00{IN_NN000;FW-200C-3U4;2} shot down by landscape at 312297.0 343096.12
[3:14:31] GAE_Mano has connected
[3:15:14] GAE_Pepper:F4U5_Corsario in flight at 312398.72 341211.62
[3:16:34] GAE_Castor has connected
[3:16:34] GAE_Mano:F4U5_Corsario(0) seat occupied by GAE_Mano at 312239.47 341638.44
[3:16:34] GAE_Mano:F4U5_Corsario loaded weapons 'default' fuel 50%
[3:16:49] GAE_Cuervo:F4U5_Corsario in flight at 312487.5 340799.56
[3:17:07] GAE_Alma:F4U5_Corsario in flight at 312491.38 341197.6
[3:17:51] GAE_Mano{GAE_Mano_0;GAE_Mano:F4U5_Corsario;2} damaged on the ground at 312307.7 341842.3
[3:17:57] GAE_Mano:F4U5_Corsario removed at 312305.56 341869.84
[3:17:57] GAE_Mano entered refly menu
[3:17:59] GAE_Mano:F4U5_Corsario(0) seat occupied by GAE_Mano at 312239.47 341638.44
[3:17:59] GAE_Mano:F4U5_Corsario loaded weapons 'default' fuel 50%
[3:18:08] GAE_Ceteu:F4U5_Corsario in flight at 312457.16 341151.53
[3:19:09] GAE_Popeye:F4U5_Corsario in flight at 312403.94 341043.8
[3:19:40] GAE_Castor:F4U5_Corsario(0) seat occupied by GAE_Castor at 312228.97 341129.47
[3:19:41] GAE_Castor:F4U5_Corsario loaded weapons 'default' fuel 40%
[3:20:14] GAE_Mano:F4U5_Corsario in flight at 312406.38 341135.44
[3:23:16] GAE_Castor:F4U5_Corsario in flight at 312491.16 341045.8
[3:28:25] GAE_Cuervo{GAE_Cuervo_0;GAE_Cuervo:F4U5_Corsario;2} landed at 359565.75 408262.16
[3:28:30] GAE_Cuervo:F4U5_Corsario removed at 359657.84 408255.5
[3:28:30] GAE_Cuervo entered refly menu
[3:29:16] GAE_Pepper{GAE_Pepper_0;GAE_Pepper:F4U5_Corsario;2} landed at 369950.56 417744.4
[3:29:48] GAE_Cuervo:F4U5_Corsario(0) seat occupied by GAE_Cuervo at 312238.56 341585.22
[3:29:48] GAE_Cuervo:F4U5_Corsario loaded weapons 'default' fuel 60%
[3:29:54] GAE_Pepper:F4U5_Corsario removed at 370572.3 417698.4
[3:29:54] GAE_Pepper entered refly menu
[3:30:05] GAE_Pepper:F4U5_Corsario(0) seat occupied by GAE_Pepper at 312220.47 341422.03
[3:30:05] GAE_Pepper:F4U5_Corsario loaded weapons 'none' fuel 50%
[3:31:49] GAE_Popeye{GAE_Popeye_0;GAE_Popeye:F4U5_Corsario;2} landed at 362931.5 408016.8
[3:31:56] GAE_Popeye:F4U5_Corsario removed at 363048.62 408008.4
[3:31:56] GAE_Popeye entered refly menu
[3:32:46] GAE_Cuervo:F4U5_Corsario in flight at 312516.28 340809.4
[3:33:37] GAE_Pepper:F4U5_Corsario in flight at 312430.84 341096.84
[3:34:23] GAE_Popeye:F4U5_Corsario(0) seat occupied by GAE_Popeye at 312241.62 341276.8
[3:34:23] GAE_Popeye:F4U5_Corsario loaded weapons 'none' fuel 50%
[3:34:45] GAE_Ceteu{GAE_Ceteu_0;GAE_Ceteu:F4U5_Corsario;2} damaged by 1_Chief at 375454.97 417323.5
[3:34:49] GAE_Ceteu{GAE_Ceteu_0;GAE_Ceteu:F4U5_Corsario;2}(0) was killed at 375524.03 417315.25
[3:34:49] GAE_Ceteu{GAE_Ceteu_0;GAE_Ceteu:F4U5_Corsario;2} shot down by 1_Chief at 375524.03 417315.25
[3:35:22] GAE_Mano{GAE_Mano_0;GAE_Mano:F4U5_Corsario;2} damaged by 1_Chief at 375924.25 417289.97
[3:35:27] GAE_Mano{GAE_Mano_0;GAE_Mano:F4U5_Corsario;2} landed at 376041.25 417266.94
[3:35:27] GAE_Mano{GAE_Mano_0;GAE_Mano:F4U5_Corsario;2} damaged on the ground at 376041.25 417266.94
[3:35:30] GAE_Mano:F4U5_Corsario(0) bailed out at 376041.25 417266.97
[3:35:31] GAE_Mano:F4U5_Corsario(0) successfully bailed out at 376032.8 417267.78
[3:35:31] ParatrooperLogging 1532518(0) touchdown in X: 376032.60492974 Y: 417267.772208938 (water) drop by GAE_Mano_0
[3:35:43] GAE_Mano:F4U5_Corsario removed at 376040.94 417267.03
[3:35:47] GAE_Mano has disconnected
[3:36:45] GAE_Alma{GAE_Alma_0;GAE_Alma:F4U5_Corsario;2} landed at 377411.7 417186.88
[3:36:55] GAE_Alma:F4U5_Corsario removed at 377585.28 417174.0
[3:36:55] GAE_Alma entered refly menu
[3:36:57] GAE_Alma:F4U5_Corsario(0) seat occupied by GAE_Alma at 312240.72 341197.25
[3:36:57] GAE_Alma:F4U5_Corsario loaded weapons 'none' fuel 20%
[3:38:05] GAE_Castor{GAE_Castor_0;GAE_Castor:F4U5_Corsario;2} landed at 378766.8 417093.03
[3:38:07] GAE_Alma:F4U5_Corsario removed at 312256.84 341196.25
[3:38:07] GAE_Alma entered refly menu
[3:38:20] GAE_Alma:SNJ5_Texan(0) seat occupied by GAE_Alma at 312240.72 341197.25
[3:38:20] GAE_Alma:SNJ5_Texan loaded weapons 'None' fuel 20%
[3:38:21] GAE_Alma:SNJ5_Texan removed at 312240.72 341197.25
[3:38:21] GAE_Alma entered refly menu
[3:38:25] GAE_Castor:F4U5_Corsario removed at 379105.22 417067.97
[3:38:25] GAE_Castor entered refly menu
[3:38:28] GAE_Alma:SNJ5_Texan(0) seat occupied by GAE_Alma at 312240.72 341197.25
[3:38:28] GAE_Alma:SNJ5_Texan loaded weapons 'None' fuel 20%
[3:38:52] GAE_Castor:SNJ5_Texan(0) seat occupied by GAE_Castor at 312228.97 341129.47
[3:38:52] GAE_Castor:SNJ5_Texan loaded weapons 'None' fuel 50%
[3:39:38] GAE_Ceteu has disconnected
[3:41:04] GAE_Popeye:F4U5_Corsario in flight at 312420.06 341182.88
[3:41:38] GAE_Alma:SNJ5_Texan in flight at 312530.47 341136.8
[3:42:20] GAE_Castor:SNJ5_Texan in flight at 312463.38 341301.22
[3:42:47] B-29(3) was wounded at 312283.25 343297.62
[3:42:47] IN_NN01{IN_NN010;B-29;2}(3) was killed at 312283.25 343297.62
[3:42:47] IN_NN01{IN_NN010;B-29;2}(0) was killed at 312283.25 343297.62
[3:42:47] IN_NN01{IN_NN010;B-29;2}(1) was killed at 312283.25 343297.62
[3:42:47] IN_NN01{IN_NN010;B-29;2}(2) was killed at 312283.25 343297.62
[3:42:47] IN_NN01{IN_NN010;B-29;2}(4) was killed at 312283.25 343297.62
[3:42:47] IN_NN01{IN_NN010;B-29;2}(5) was killed at 312283.25 343297.62
[3:42:47] IN_NN01{IN_NN010;B-29;2} shot down by landscape at 312283.25 343297.62
[3:45:07] GAE_Cuervo{GAE_Cuervo_0;GAE_Cuervo:F4U5_Corsario;2} landed at 376247.44 407063.75
[3:45:11] GAE_Cuervo:F4U5_Corsario removed at 376323.6 407058.28
[3:45:11] GAE_Cuervo entered refly menu
[3:45:49] GAE_Cuervo:SNJ5_Texan(0) seat occupied by GAE_Cuervo at 312238.56 341585.22
[3:45:49] GAE_Cuervo:SNJ5_Texan loaded weapons 'default' fuel 50%
[3:48:22] GAE_Cuervo:SNJ5_Texan in flight at 312490.28 341038.25
[3:48:47] GAE_Pepper{GAE_Pepper_0;GAE_Pepper:F4U5_Corsario;2} landed at 389406.2 416304.5
[3:49:06] GAE_Pepper:F4U5_Corsario removed at 389724.66 416280.97
[3:49:06] GAE_Pepper entered refly menu
[3:50:32] GAE_Pepper:SNJ5_Texan(0) seat occupied by GAE_Pepper at 312220.47 341422.03
[3:50:32] GAE_Pepper:SNJ5_Texan loaded weapons 'None' fuel 50%
[3:52:59] GAE_Pepper:SNJ5_Texan in flight at 312443.22 341151.75
[3:53:53] GAE_Popeye{GAE_Popeye_0;GAE_Popeye:F4U5_Corsario;2} damaged by landscape at 384957.8 406437.72
[3:53:54] GAE_Popeye{GAE_Popeye_0;GAE_Popeye:F4U5_Corsario;2} landed at 384980.62 406435.25
[3:53:54] GAE_Popeye{GAE_Popeye_0;GAE_Popeye:F4U5_Corsario;2} damaged on the ground at 384980.62 406435.25
[3:54:18] GAE_Popeye:F4U5_Corsario removed at 385386.72 406406.03
[3:54:22] GAE_Popeye has disconnected
[4:02:39] GAE_Castor:SNJ5_Texan(1) seat occupied by GAE_Castor at 393903.6 405904.7
[4:02:43] GAE_Alma{GAE_Alma_0;GAE_Alma:SNJ5_Texan;2} landed at 393725.47 405802.53
[4:02:47] GAE_Castor:SNJ5_Texan(0) seat occupied by GAE_Castor at 393801.22 406440.88
[4:02:54] GAE_Alma:SNJ5_Texan removed at 393912.66 405789.06
[4:02:54] GAE_Alma entered refly menu
[4:03:04] GAE_Alma:SNJ5_Texan(0) seat occupied by GAE_Alma at 312240.72 341197.25
[4:03:04] GAE_Alma:SNJ5_Texan loaded weapons 'None' fuel 20%
[4:05:18] GAE_Alma:SNJ5_Texan in flight at 312496.84 341099.06
[4:05:55] GAE_Castor{GAE_Castor_0;GAE_Castor:SNJ5_Texan;2} landed at 396902.97 405576.34
[4:06:09] GAE_Castor:SNJ5_Texan removed at 397144.97 405558.94
[4:06:19] GAE_Castor has disconnected
[4:09:41] GAE_Cuervo{GAE_Cuervo_0;GAE_Cuervo:SNJ5_Texan;2} landed at 400698.44 405301.7
[4:09:53] GAE_Cuervo:SNJ5_Texan removed at 400899.8 405287.2
[4:09:53] GAE_Cuervo entered refly menu
[4:11:43] GAE_Cuervo:SNJ5_Texan(0) seat occupied by GAE_Cuervo at 312238.56 341585.22
[4:11:43] GAE_Cuervo:SNJ5_Texan loaded weapons 'default' fuel 50%
[4:14:19] GAE_Pepper{GAE_Pepper_0;GAE_Pepper:SNJ5_Texan;2} landed at 405251.47 404979.53
[4:14:56] GAE_Pepper:SNJ5_Texan removed at 405868.2 404935.2
[4:14:56] GAE_Pepper entered refly menu
[4:15:02] GAE_Pepper has disconnected
[4:22:37] GAE_Chape:H19D removed at 312239.78 341357.22
[4:22:37] GAE_Chape entered refly menu
[4:23:37] GAE_Chape:F4U5_Corsario(0) seat occupied by GAE_Chape at 420623.06 408995.62
[4:23:37] GAE_Chape:F4U5_Corsario loaded weapons '08xHVAR+02x1000Lbs_Bomb' fuel 100%
[4:25:30] GAE_Chape:F4U5_Corsario in flight at 421685.12 406731.53
[4:29:20] GAE_Cuervo:SNJ5_Texan in flight at 312488.16 341131.56
[4:30:31] GAE_Alma{GAE_Alma_0;GAE_Alma:SNJ5_Texan;2} landed at 419483.34 401007.4
[4:30:58] GAE_Alma:SNJ5_Texan removed at 419661.4 400634.9
[4:30:58] GAE_Alma entered refly menu
[4:30:59] GAE_Alma:SNJ5_Texan(0) seat occupied by GAE_Alma at 312240.72 341197.25
[4:30:59] GAE_Alma:SNJ5_Texan loaded weapons 'None' fuel 20%
[4:32:45] GAE_Alma:SNJ5_Texan in flight at 312473.5 341046.88
[4:39:00] 0_Chief damaged by GAE_Chape{GAE_Chape_0;GAE_Chape:F4U5_Corsario;2} at 422794.88 394077.88
[4:39:00] GAE_Chape:F4U5_Corsario(0) was heavily wounded at 422744.06 394184.06
[4:39:00] GAE_Chape{GAE_Chape_0;GAE_Chape:F4U5_Corsario;2}(0) was killed at 422744.06 394184.06
[4:39:00] GAE_Chape{GAE_Chape_0;GAE_Chape:F4U5_Corsario;2} shot down by 0_Chief at 422744.06 394184.06
[4:51:28] cc0103{cc01030;A6M2;1} damaged on the ground at 333429.84 153409.77
[4:51:28] cc0103{cc01032;A6M2;1} damaged on the ground at 333410.03 153450.47
[4:51:28] cc0103{cc01031;A6M2;1} damaged on the ground at 333291.0 153458.2
[4:51:28] cc0103{cc01033;A6M2;1} damaged on the ground at 333408.72 153515.36
[4:52:56] GAE_Cuervo{GAE_Cuervo_0;GAE_Cuervo:SNJ5_Texan;2} landed at 427418.94 384399.7
[4:53:12] GAE_Cuervo:SNJ5_Texan removed at 427497.03 384236.3
[4:53:12] GAE_Cuervo entered refly menu
[4:58:31] GAE_Alma{GAE_Alma_0;GAE_Alma:SNJ5_Texan;2} landed at 428277.06 381891.25
[4:58:31] GAE_Alma{GAE_Alma_0;GAE_Alma:SNJ5_Texan;2} damaged on the ground at 428277.06 381891.25
[4:58:41] GAE_Alma:SNJ5_Texan(0) bailed out at 428276.84 381891.4
[4:58:42] GAE_Alma:SNJ5_Texan(0) successfully bailed out at 428283.16 381894.94
[4:58:42] ParatrooperLogging 6523705(0) touchdown in X: 428283.3136596828 Y: 381895.0396253728 (water) drop by GAE_Alma_0
[4:58:43] GAE_Alma:SNJ5_Texan(1) bailed out at 428276.84 381891.4
[4:58:44] ParatrooperLogging 6525235(1) touchdown in X: 428280.7162994084 Y: 381897.6817465052 (water) drop by GAE_Alma_0
[4:58:44] GAE_Alma:SNJ5_Texan(1) successfully bailed out at 428280.72 381897.7
[4:59:14] GAE_Alma:SNJ5_Texan removed at 428276.5 381891.7
[4:59:17] GAE_Alma has disconnected
[4:59:30] Mission END
F4U5 Corsario - default 60% Fuel
F4U5 Corsario - default - 60% Fuel
3er Vuelo:
Texan - default - 50% Fuel
4to Vuelo:
1º Vuelo.
Corsario - 60% Fuel - Default.
Traslado de Palembang al V2 de un Corsario que termina nefastamente cuando al enganchar, sospechando como siempre que no había ocurrido, doy potencia y me remonto enganchado como barrilete cayendo contra la isla. Bye bye life...
F4U5 Corsario - default 50% Fuel
3er Vuelo:
4to Vuelo:
Traslado de Palembang al V1. Llegando a pocos cientos de metros del V1 el motor deja de funcionar sin previo aviso. Planeo tratando de llegar al V1 pero debo amerizar a escasos 50 mts del porta.
Avión: Hundido
