Canal de Suez 31 FINAL
Iniciado por GAE_Yanito, 21 de Marzo de 2009, 12:02:25 AM
solo es para bajar la mision despues va la info
Luego de reconocer la zona ya se sabe donde se encuentra la mansion de Alha Akbar. Se pide suma atencion al escape del mismo y su comite que pueden estar moviendo sus vehicuos a la pista alternativa para escapar en avion. Mantener alerta ante cualquier intento de este tipo y estar preparados para derribarlo en caso de que llegue a despegar
VUELOS DISPONIBLES  (chequear combustible y armamentos, los que no se ocupan no salen o vuelven de inmediato segun la base
4 F80A de G23
4 Texan de G23
4 F4U desde V1  (D17)
4 Texan desde V2 (D17)
4 F80A de Alarish
2 Texan de Alarish
4 F80A de P2
IAF
3 Ouragan CAP sobre el Monasterio
Acortado para que entre en el post.
05:00:00 GAE_Yanito is trying to occupy seat i01030(0)
[21.03.2009 4:47:06] Mission: net/coop/CANAL DE SUEZ/SUEZ_31.mis is Playing
05:00:00 Mission BEGIN
05:00:00 GAE_Yanito is trying to occupy seat 62Squadron310(0)
05:00:00 GAE_Alma is trying to occupy seat 62Squadron310(0)
05:00:00 GAE_Balker is trying to occupy seat 62Squadron220(0)
05:00:00 GAE_Alma is trying to occupy seat 62Squadron222(0)
05:00:00 GAE_Tacuara has connected
05:00:00 GAE_Castor has connected
05:00:00 GAE_Tacuara is trying to occupy seat 62Squadron201(0)
05:00:00 GAE_Charrua is trying to occupy seat 62Squadron231(0)
05:00:00 GAE_Castor has disconnected
05:00:00 GAE_Tacuara is trying to occupy seat 62Squadron200(0)
05:00:00 GAE_Alma is trying to occupy seat 62Squadron010(0)
05:00:00 GAE_Charrua is trying to occupy seat 62Squadron230(0)
05:00:00 GAE_Balker is trying to occupy seat 62Squadron011(0)
05:00:00 GAE_Tacuara is trying to occupy seat 62Squadron231(0)
05:00:00 GAE_Charrua is trying to occupy seat 62Squadron201(0)
05:00:00 GAE_Alma is trying to occupy seat 62Squadron012(0)
05:00:00 GAE_Tacuara is trying to occupy seat 62Squadron210(0)
05:00:00 GAE_Charrua is trying to occupy seat 62Squadron200(0)
05:00:00 GAE_Tacuara is trying to occupy seat 62Squadron211(0)
05:00:00 GAE_Tacuara is trying to occupy seat 62Squadron202(0)
05:00:00 GAE_Balker is trying to occupy seat 62Squadron203(0)
05:00:00 GAE_Balker is trying to occupy seat 62Squadron211(0)
05:00:00 GAE_Alma has disconnected
05:00:00 GAE_Tacuara has disconnected
05:00:00 GAE_Alma has connected
05:00:00 i01030(0) seat occupied by GAE_Yanito at 10541.571 215359.83
05:00:00 i01030 loaded weapons '90gal' fuel 75%
05:00:00 62Squadron220(0) seat occupied by GAE_Balker at 63207.266 227967.2
05:00:00 62Squadron220 loaded weapons 'LR-2x500lb' fuel 100%
05:00:00 62Squadron230(0) seat occupied by GAE_Charrua at 63282.594 228074.78
05:00:00 62Squadron230 loaded weapons '3x500' fuel 75%
05:00:00 62Squadron222(0) seat occupied by GAE_Alma at 63244.26 228020.05
05:00:00 62Squadron222 loaded weapons 'LR-2x500lb' fuel 100%
05:00:00 62Squadron231(0) seat occupied by GAE_Tacuara at 63302.426 228103.11
05:00:00 62Squadron231 loaded weapons '3x500' fuel 50%
05:00:10 62Squadron012(0) bailed out at 154523.38 12133.192
05:00:10 62Squadron303(0) bailed out at 119342.0 277759.9
05:00:16 62Squadron300(2) bailed out at 119268.25 277654.56
05:00:16 62Squadron233(1) bailed out at 63342.1 228159.75
05:00:16 62Squadron232(0) successfully bailed out at 63343.65 228103.0
05:00:16 62Squadron302(2) bailed out at 119317.43 277724.78
05:00:16 62Squadron210(0) bailed out at 119223.83 277591.12
05:00:18 62Squadron301(4) bailed out at 119292.84 277689.7
05:00:18 62Squadron300(4) bailed out at 119268.25 277654.56
05:00:18 62Squadron210(1) bailed out at 119223.83 277591.12
05:00:19 62Squadron232(1) successfully bailed out at 63360.73 228116.69
05:00:19 62Squadron211(0) successfully bailed out at 119282.38 277587.75
05:00:19 62Squadron303(1) successfully bailed out at 119381.55 277739.0
05:00:19 62Squadron211(1) successfully bailed out at 119290.22 277622.44
05:00:20 62Squadron302(4) bailed out at 119317.43 277724.78
05:00:20 62Squadron010(0) successfully bailed out at 154494.5 12045.003
05:00:20 62Squadron301(0) successfully bailed out at 119322.28 277661.
05:00:25 62Squadron300(4) successfully bailed out at 119316.336 277642.0
05:00:27 62Squadron210(1) successfully bailed out at 119272.82 277607.56
05:00:27 62Squadron210(0) successfully bailed out at 119283.87 277592.34
05:00:32 441_Static destroyed by 380_Static at 33755.87 187197.81
05:00:35 62Squadron012 removed at 154523.38 12133.192
05:00:35 62Squadron211 removed at 119243.67 277619.44
05:00:40 62Squadron013 removed at 154541.88 12159.614
05:00:43 62Squadron210 removed at 119223.83 277591.12
05:01:00 g01330(0) was killed at 151293.81 193985.84
05:01:00 g01330(1) was killed at 151293.81 193985.84
05:01:00 g01330(2) was killed at 151293.81 193985.84
05:01:00 g01330(3) was killed at 151293.81 193985.84
05:01:00 g01330 shot down by landscape at 151293.81 193985.84
05:01:00 g01310(0) was killed at 151301.08 193934.72
05:01:00 g01310(1) was killed at 151301.08 193934.72
05:01:00 g01310(2) was killed at 151301.08 193934.72
05:01:00 g01310(3) was killed at 151301.08 193934.72
05:01:00 59_Chief0 destroyed by g01310 at 151298.34 193936.92
05:01:00 g01310 shot down by landscape at 151301.08 193934.72
05:01:00 g01331(0) was killed at 151377.36 193929.53
05:01:00 g01331(1) was killed at 151377.36 193929.53
05:01:00 g01331(2) was killed at 151377.36 193929.53
05:01:00 g01331(3) was killed at 151377.36 193929.53
05:01:00 g01331 shot down by landscape at 151377.36 193929.53
05:01:07 343_Static destroyed by 380_Static at 33965.23 187257.77
05:01:44 62Squadron231(1) seat occupied by GAE_Tacuara at 63299.805 228100.77
05:01:54 62Squadron231(0) seat occupied by GAE_Tacuara at 63299.312 228100.47
05:02:12 i01310 damaged on the ground at 9800.219 214301.08
05:02:14 i01310 damaged by landscape at 9765.358 214254.06
05:02:20 i01310(0) bailed out at 9708.822 214154.23
05:02:20 i01310(0) was killed at 9710.658 214149.66
05:02:30 i01311 damaged on the ground at 9799.834 214300.53
05:02:47 i01312 damaged on the ground at 9799.574 214300.17
05:02:49 i01311 damaged by i01312 at 9732.895 214221.03
05:02:49 i01312 damaged by i01311 at 9737.569 214225.2
05:02:49 i01312(0) was killed at 9735.479 214224.39
05:02:49 i01312 shot down by landscape at 9735.479 214224.39
05:02:54 i01311(0) bailed out at 9732.698 214221.34
05:02:58 i01310 removed at 9724.845 214139.12
05:03:02 i01311(0) successfully bailed out at 9731.323 214172.3
05:03:02 i01313 damaged on the ground at 9800.6455 214301.69
05:03:08 i01313 damaged by landscape at 9670.708 214135.4
05:03:13 i01313(0) bailed out at 9627.687 214088.42
05:03:20 i01311 removed at 9732.255 214222.44
05:03:22 i01313(0) successfully bailed out at 9649.861 214137.67
05:03:46 i01313 removed at 9628.102 214087.6
05:03:48 62Squadron230 in flight at 62752.25 227217.36
05:03:55 i01001 damaged on the ground at 2428.4338 228457.03
05:03:55 i01001 damaged by landscape at 2428.4338 228457.03
05:03:55 i01001(0) was wounded at 2428.4338 228457.03
05:03:55 i01001(0) was killed at 2428.4338 228457.03
05:03:55 i01001 shot down by landscape at 2428.4338 228457.03
05:04:05 62Squadron231 in flight at 62604.38 227048.25
05:04:17 i01002 damaged on the ground at 2513.1252 228576.78
05:04:17 i01002 damaged by landscape at 2513.1252 228576.78
05:04:17 i01002(0) was wounded at 2513.1252 228576.78
05:04:17 i01002(0) was heavily wounded at 2513.1252 228576.78
05:04:17 i01002(0) was killed at 2513.1252 228576.78
05:04:17 i01002 shot down by landscape at 2513.1252 228576.78
05:04:34 442_Static destroyed by 380_Static at 33812.66 187368.19
05:04:45 443_Static destroyed by 380_Static at 34108.75 187400.62
05:04:51 62Squadron220 in flight at 62525.27 226850.27
05:04:58 62Squadron222 in flight at 62201.57 226534.33
05:05:03 224_Static destroyed by 367_Static at 33889.5 183253.9
05:05:29 344_Static destroyed by 380_Static at 33936.0 186950.89
05:05:43 206_Static destroyed by 380_Static at 34099.52 186802.8
05:06:03 43_Static destroyed by 380_Static at 33615.95 187392.7
05:07:24 439_Static destroyed by 380_Static at 33549.01 186646.2
05:07:26 440_Static destroyed by 380_Static at 33918.12 186629.97
05:07:59 437_Static destroyed by 55_Chief at 33743.71 186812.48
05:08:10 62Squadron001 removed at 34939.5 166305.56
05:08:29 438_Static destroyed by 380_Static at 33934.34 186459.62
05:09:07 436_Static destroyed by 380_Static at 33731.54 186492.06
05:09:17 62Squadron200 removed at 33885.617 166514.12
05:09:44 0_Static destroyed by 380_Static at 34043.11 187151.31
05:09:44 315_Static destroyed by 380_Static at 33830.96 186158.66
05:09:53 93_Static destroyed by 380_Static at 32761.18 187589.1
05:09:59 347_Static destroyed by 380_Static at 32425.74 186828.78
05:10:10 62Squadron323 damaged by i01020 at 139039.83 77323.36
05:10:15 62Squadron323(0) bailed out at 139094.31 76959.13
05:10:16 62Squadron323(1) bailed out at 139104.25 76858.05
05:10:17 i01030 in flight at 11231.697 216058.94
05:10:27 96_Static destroyed by 380_Static at 32674.04 188292.92
05:10:30 345_Static destroyed by 380_Static at 32192.3 188893.31
05:10:30 62Squadron003 removed at 34779.164 167072.45
05:10:36 62Squadron323 shot down by i01020 at 138752.36 75475.625
05:10:48 346_Static destroyed by 380_Static at 31674.34 188368.06
05:10:59 225_Static destroyed by 380_Static at 37294.54 190877.33
05:11:01 227_Static destroyed by 380_Static at 37311.29 190899.44
05:11:27 226_Static destroyed by 380_Static at 37289.6 190902.27
05:11:53 2_Chief4 destroyed by 380_Static at 32300.0 192413.69
05:12:06 186_Static destroyed by 380_Static at 34937.28 192191.75
05:12:20 62Squadron202 removed at 33671.08 167457.9
05:13:05 62Squadron000 removed at 34638.953 167853.58
05:13:25 62Squadron231(1) seat occupied by GAE_Tacuara at 82030.336 196132.06
05:13:29 62Squadron231(0) seat occupied by GAE_Tacuara at 82182.33 195898.75
05:13:36 62Squadron320(0) was killed at 141872.34 62709.766
05:13:36 62Squadron320(1) was killed at 141872.34 62709.766
05:13:36 62Squadron320 shot down by landscape at 141872.34 62709.766
05:13:36 62Squadron322(0) was killed at 141792.1 62706.426
05:13:36 62Squadron322(1) was killed at 141792.1 62706.426
05:13:36 62Squadron322 shot down by landscape at 141792.1 62706.426
05:13:36 62Squadron323(1) successfully bailed out at 139423.02 75831.93
05:13:37 62Squadron321 damaged by landscape at 141837.7 62684.297
05:13:37 62Squadron321(0) was killed at 141837.7 62684.297
05:13:37 62Squadron321(1) was killed at 141837.7 62684.297
05:13:37 62Squadron321 shot down by i01020 at 141837.7 62684.297
05:13:40 62Squadron323(0) successfully bailed out at 139463.88 75910.61
05:13:45 62Squadron330 damaged by landscape at 141883.8 62713.14
05:13:45 62Squadron330(0) was killed at 141883.8 62713.14
05:13:45 62Squadron330(1) was killed at 141883.8 62713.14
05:13:45 62Squadron330 shot down by landscape at 141883.8 62713.14
05:13:45 62Squadron332(0) was killed at 141802.39 62712.57
05:13:45 62Squadron332(1) was killed at 141802.39 62712.57
05:13:45 62Squadron332 shot down by landscape at 141802.39 62712.57
05:13:46 62Squadron333(0) was killed at 141743.2 62669.94
05:13:46 62Squadron333(1) was killed at 141743.2 62669.94
05:13:46 62Squadron333 shot down by landscape at 141743.2 62669.94
05:14:44 71_Chief1 destroyed by 380_Static at 33500.0 191017.86
05:15:12 71_Chief0 destroyed by 380_Static at 33500.0 190925.58
05:15:34 62Squadron331(0) was killed at 143164.25 55526.7
05:15:34 62Squadron331(1) was killed at 143164.25 55526.7
05:15:34 62Squadron331 shot down by landscape at 143164.25 55526.7
05:15:45 62Squadron203 removed at 33457.953 168434.11
05:15:51 62Squadron002 removed at 34501.324 168630.12
05:15:59 7_Chief2 destroyed by 380_Static at 31820.516 194579.55
05:16:09 62Squadron230(1) seat occupied by GAE_Charrua at 89275.79 184739.08
05:16:13 62Squadron230(0) seat occupied by GAE_Charrua at 89477.266 184459.39
05:16:35 70_Chief0 destroyed by 71_Chief1 at 33500.0 190958.66
05:16:37 70_Chief1 destroyed by 380_Static at 33500.0 190958.31
05:17:09 105_Chief0 destroyed by 16_Chief0 at 138549.77 257369.22
05:19:08 8_Chief0 destroyed by 364_Static at 151142.0 188808.33
05:19:20 62Squadron231(1) seat occupied by GAE_Tacuara at 100746.445 172377.08
05:19:21 62Squadron231(0) seat occupied by GAE_Tacuara at 100835.16 172259.84
05:19:21 3_Chief4 destroyed by 380_Static at 32103.39 194296.61
05:19:21 3_Chief3 destroyed by 380_Static at 32092.713 194307.22
05:19:51 i01301 damaged on the ground at 34151.83 175499.83
05:20:30 i01300(0) was heavily wounded at 30528.707 176630.64
05:20:30 i01300 damaged on the ground at 30528.707 176630.64
05:20:30 i01300(0) was killed by 366_Static at 30528.707 176630.64
05:20:30 i01300 damaged by 366_Static at 30528.707 176630.64
05:20:57 3_Chief2 destroyed by 380_Static at 31803.852 194606.81
05:20:59 i01300 shot down by 366_Static at 28421.951 177709.94
05:21:01 3_Chief1 destroyed by 380_Static at 31786.914 194622.9
05:22:14 62Squadron231(1) seat occupied by GAE_Tacuara at 110104.23 159978.14
05:22:19 62Squadron231(0) seat occupied by GAE_Tacuara at 110374.52 159589.78
05:22:44 i01301 damaged by 365_Static at 27581.709 184097.53
05:22:44 i01301(0) was killed at 27581.709 184097.53
05:22:44 i01301 shot down by 365_Static at 27581.709 184097.53
05:23:16 i01303 damaged on the ground at 29305.191 175748.0
05:23:16 i01303 damaged by 363_Static at 29305.191 175748.0
05:23:21 i01303(0) bailed out at 29100.232 175435.38
05:23:21 i01323(0) was killed at 35647.92 160704.05
05:23:21 i01323 shot down by landscape at 35647.92 160704.05
05:23:27 i01322 damaged by landscape at 35067.543 162039.45
05:23:27 i01322(0) was killed at 35067.543 162039.45
05:23:27 i01322 shot down by landscape at 35067.543 162039.45
05:23:30 i01321(0) was wounded at 34526.754 163083.94
05:23:30 i01321(0) was killed at 34526.754 163083.94
05:23:30 i01321 shot down by landscape at 34526.754 163083.94
05:23:36 i01320(0) was wounded at 34065.51 164194.28
05:23:36 i01320(0) was killed at 34065.51 164194.28
05:23:36 i01320 shot down by landscape at 34065.51 164194.28
05:24:01 i01303 shot down by 363_Static at 28946.693 175222.17
05:24:07 i01303(0) has chute destroyed by 55_Chief at 28634.566 174572.12
05:24:26 i01003 removed at 8710.6 237428.94
05:24:31 i01303(0) was killed at 28563.516 174493.84
05:24:58 i01010 damaged by 365_Static at 35833.26 172221.52
05:25:02 i01010(0) bailed out at 35971.387 172677.3
05:25:17 i01331 damaged on the ground at 133554.23 114952.7
05:25:17 i01331 damaged by 62Squadron312 at 133554.23 114952.7
05:25:17 i01331(0) was killed by 62Squadron312 at 133557.6 114951.95
05:25:38 i01331 shot down by 62Squadron312 at 135820.83 114005.805
05:26:03 i01010 shot down by 365_Static at 36004.598 174761.73
05:26:04 i01332(0) was wounded at 135201.33 122418.61
05:26:40 i01010(0) has chute destroyed by 365_Static at 36854.35 174434.25
05:27:01 i01000 removed at 8710.906 237429.36
05:27:06 i01010(0) was killed at 36888.625 174469.81
05:27:28 62Squadron231(1) seat occupied by GAE_Tacuara at 125797.664 137557.64
05:27:30 62Squadron231(0) seat occupied by GAE_Tacuara at 125862.57 137490.94
05:28:00 i01330 damaged on the ground at 134269.86 128504.24
05:28:00 i01330 damaged by 62Squadron221 at 134269.86 128504.24
05:28:05 i01330(0) was wounded at 133443.6 128502.49
05:28:13 i01330(0) was heavily wounded at 132364.08 128333.445
05:28:13 i01330(0) bailed out at 132364.08 128333.445
05:28:38 i01330 shot down by 62Squadron221 at 129835.6 128749.34
05:29:31 62Squadron230(1) seat occupied by GAE_Charrua at 130881.98 132243.4
05:30:25 62Squadron231(0) seat occupied by GAE_Tacuara at 133808.69 127239.9
05:31:41 i01030 damaged by landscape at 131035.76 131976.19
05:31:41 i01030(0) was killed at 131034.06 131979.83
05:31:41 i01030 shot down by landscape at 131034.06 131979.83
05:31:56 i01332 damaged on the ground at 104563.38 152597.22
05:32:42 i01330(0) successfully bailed out at 130697.49 129541.97
05:33:31 i01332(0) bailed out at 100325.96 156259.86
05:33:37 i01332(0) successfully bailed out at 100300.19 156235.5
05:34:02 238_Static crashed at 138175.75 110409.31
05:34:26 i01332 shot down by 62Squadron310 at 100325.96 156259.86
05:34:55 62Squadron231 damaged by 11_Static at 138796.17 111000.836
05:35:00 62Squadron231(0) bailed out at 138639.72 110487.4
05:35:02 62Squadron231(0) was killed in his chute by 62Squadron231 at 138613.98 110410.94
05:35:02 62Squadron231(1) was killed at 138614.95 110408.016
05:35:02 62Squadron231 shot down by 11_Static at 138614.95 110408.016
05:35:45 184_Static destroyed by 422_Static at 151292.1 187090.75
05:35:50 356_Static destroyed by 62Squadron230 at 137356.34 110005.96
05:35:50 341_Static destroyed by 62Squadron230 at 137340.88 110056.79
05:35:50 361_Static destroyed by 62Squadron230 at 137295.84 110039.22
05:39:00 62Squadron201 damaged on the ground at 28936.805 175380.22
05:39:00 62Squadron201 damaged by landscape at 28936.805 175380.22
05:39:00 62Squadron201(0) was heavily wounded at 28990.104 175445.0
05:39:00 62Squadron201(0) was killed at 28990.104 175445.0
05:39:00 62Squadron201(1) was killed at 28990.104 175445.0
05:39:00 62Squadron201 shot down by landscape at 28990.104 175445.0
05:44:21 i01011 landed at 10644.269 215311.03
05:44:50 i01011 removed at 10578.89 215217.6
05:45:30 GAE_Tacuara has disconnected
05:50:27 37_Chief0 destroyed by 380_Static at 38635.656 181164.39
05:51:07 39_Chief0 destroyed by 380_Static at 38840.895 180958.9
05:52:09 35_Chief0 destroyed by 380_Static at 38558.043 181242.2
05:54:48 i01302 damaged on the ground at 9609.058 214028.61
05:54:55 i01302(0) bailed out at 9616.843 214040.67
05:55:04 i01302 removed at 9617.2295 214041.11
05:55:06 i01302(0) successfully bailed out at 9579.769 214092.2
05:55:17 g01320(1) was killed by 62Squadron222 at 45751.07 146478.2
05:56:58 g01320(0) was heavily wounded at 41865.535 149913.58
05:57:00 g01320 damaged on the ground at 41751.918 149976.39
05:57:06 g01320(0) was killed at 41585.33 150124.06
05:58:34 g01320 damaged by landscape at 42068.01 150302.11
05:58:34 g01320 shot down by 62Squadron222 at 42068.01 150302.11
[21.03.2009 6:00:31] Mission: RED WON
06:05:03 62Squadron222 damaged by landscape at 33584.973 173769.48
06:05:04 62Squadron222 landed at 33584.15 173776.83
06:05:04 62Squadron222 damaged on the ground at 33584.15 173776.83
06:05:11 62Squadron222(0) bailed out at 33584.48 173776.92
06:05:11 62Squadron222(0) successfully bailed out at 33584.863 173776.42
06:05:20 62Squadron222 shot down by landscape at 33584.484 173776.97
06:06:12 i01020 landed at 9353.777 213657.14
06:06:42 i01020 removed at 9562.67 213957.3
06:09:38 62Squadron311 landed at 179777.12 290038.66
06:10:08 62Squadron311 removed at 179870.55 290172.22
06:10:54 34_Chief3 destroyed by 380_Static at 37638.555 182161.44
06:11:01 62Squadron221 removed at 63201.98 227960.27
06:11:46 62Squadron312 landed at 179787.14 290052.97
06:12:12 62Squadron223 removed at 63201.965 227960.25
06:12:15 62Squadron312 removed at 179870.62 290172.3
06:12:36 62Squadron230 landed at 33555.65 173716.94
06:12:36 62Squadron230 damaged on the ground at 33555.65 173716.94
06:12:52 62Squadron230(0) bailed out at 33555.688 173717.0
06:12:52 62Squadron230(0) successfully bailed out at 33555.992 173716.88
06:12:52 62Squadron230(0) was captured at 33555.992 173716.88
06:12:54 62Squadron230(1) bailed out at 33555.695 173717.0
06:12:54 62Squadron230(1) successfully bailed out at 33556.81 173717.98
06:12:54 62Squadron230(1) was captured at 33556.81 173717.98
06:13:14 62Squadron230 shot down by 5_Chief2 at 33556.062 173717.6
06:14:26 62Squadron220 landed at 63502.152 228773.86
06:14:42 62Squadron310 landed at 179765.12 290021.66
06:14:50 Mission END
F80A - Tanques suplementarios - 100 % jugo.
Vuelvo a salir de lider de los F80A junto al GU Alma. Esta vez la misión no es de reconocimiento. Debemos encontrar al lider egipcio en su HQ y matarlo. Salimos desde G23 escoltando al grupo de ataque: 2 T6. Ponemos rumbo al objetivo y al llegar encontramos una CAP israelí que combate con cazas enemigos. Después de largos minutos Alma y yo nos separamos y escuchamos como los T6 llegan al blanco. Vemos AAA, nos reunimos sobre el objetivo y escuchamos como el TF Charrúa y el GU Tacuara se lanzan sobre el blanco. Sin embargo, inteligencia informa que el lider egipcio ya se había ido del lugar en una avioneta. Ponemos rumbo al canal de Suez para intentar interceptarlo mientras pedimos coordenadas al operador de radar del V1. La información que recibimos es tan precisa que lo encontramos y el GU Alma lo derriba. Ya sin jugo, mi numeral intenta un apotaje en el V1 y yo pongo rumbo a G23, al que llego sin novedad.
Piloto: ok.
Avión: ok.
"Esta vez puedo salir de la cabina sin ayuda. Me siento bastante mejor que anoche. A medio camino de la sala de Operaciones viene a mi encuentro un jóven GU que me informa que logramos matar al gobernante egipcio y que todas las emisoras de El Cairo no dejan de hablar de otra cosa. Dentro de la sala todos ríen y se felicitan. A nadie ya le importan los mapas y las cartas aéreas ni mantener el orden sobre la mesa de situación. A nadie le importa tampoco atender el teléfono rojo del Estado Mayor, que empieza a sonar.
Alguien abre una botella de vino y arroja el contenido a los presentes como si se tratara del ganador de una carrera. Los israelíes sintonizan una pequeña radio y escuchan en su propio idioma que el enemigo abandona sus armas y comienza a rendirse en masa.
Una jóven del personal civil israelí me sonríe, me alcanza una tasa llena de vino y me besa en la mejilla. Ya ésto es demasiado ¡Hasta yo mismo empiezo a reír!
Mientras tanto, el teléfono rojo sigue sonando.
Me acerco, dejo el casco sobre la mesa y atiendo:
- Operaciones, habla el TF Balker.
- ¡Gracias a Dios está vivo! - gritan desde el otro lado de la línea -  ¡Aquí en P2 pensamos que los habían matado a todos! ¿Cómo está el resto?
- El TF Charrúa y el GU Alma están a bordo del V1. El GU Tacuara...
Durante un par de segundos nos quedamos en silencio mientras a mi alrededor el personal no dejaba de festejar la victoria.
- Vea, Balker - retomaron la conversación desde P2 - la verdad que todo fue una sorpresa. Cuando recibimos los primeros informes que hablaban de que habían equivocado el blanco y bombardearon una abadía pensamos que la habían cagado...
Pero ya no pude escuchar más... ¿no se había bombardeado el castillo al fin de cuentas...? ¡¡¡Una abadía!!!...¿Cuántos inocentes...?
Ahora sí ya tenía demasiado... dejé el tubo a un costado, le quité una botella de vino a un cabo y abandoné la improvisada fiesta en Operaciones como alma que se lleva el diablo. Cuando estuve en el casino de oficiales, rompí el pico contra una mesa e intenté bajármela de un trago ante la aterrorizada mirada de dos mujeres del personal de limpieza".
find 5 human pilots in mission:
Hyper Name       | plane code    | seat
GAE_Yanito       | i01030   | 0
GAE_Balker       | 62Squadron220   | 0
GAE_Charrua       | 62Squadron230   | 0
GAE_Alma       | 62Squadron222   | 0
GAE_Tacuara       | 62Squadron231   | 0
==== Actions for pilot GAE_Yanito: ====
05:00:00 GAE_Yanito takes seat: i01030(0) - 10541.571 215359.83
05:00:00 GAE_Yanito loads wep: '90gal'  fuel: 75%
05:31:41 GAE_Yanito damaged by landscape - 131035.76 131976.19
05:31:41 GAE_Yanito was killed  - 131034.06 131979.83
05:31:41 GAE_Yanito was shoot down by landscape - 131034.06 131979.83
-------- SUMMARY for GAE_Yanito:
Akills: 0 | Gkills: 0  | State: Damaged KIA
==== Actions for pilot GAE_Balker: ====
05:00:00 GAE_Balker takes seat: 62Squadron220(0) - 63207.266 227967.2
05:00:00 GAE_Balker loads wep: 'LR-2x500lb'  fuel: 100%
06:14:26 GAE_Balker lands - 63502.152 228773.86
-------- SUMMARY for GAE_Balker:
Akills: 0 | Gkills: 0  | State: Landed
==== Actions for pilot GAE_Charrua: ====
05:00:00 GAE_Charrua takes seat: 62Squadron230(0) - 63282.594 228074.78
05:00:00 GAE_Charrua loads wep: '3x500'  fuel: 75%
05:16:09 GAE_Charrua takes seat: 62Squadron230(1) - 89275.79 184739.08
05:16:13 GAE_Charrua takes seat: 62Squadron230(0) - 89477.266 184459.39
05:29:31 GAE_Charrua takes seat: 62Squadron230(1) - 130881.98 132243.4
05:35:50 GAE_Charrua destroy to 356_Static - 137356.34 110005.96
05:35:50 GAE_Charrua destroy to 341_Static - 137340.88 110056.79
05:35:50 GAE_Charrua destroy to 361_Static - 137295.84 110039.22
06:12:36 GAE_Charrua lands - 33555.65 173716.94
06:12:36 GAE_Charrua diches - 33555.65 173716.94
06:12:54 GAE_Charrua bailed - 33555.695 173717.0
06:12:54 GAE_Charrua bailed ok  - 33556.81 173717.98
06:12:54 GAE_Charrua CAPT  - 33556.81 173717.98
06:13:14 GAE_Charrua was shoot down by 5_Chief2 - 33556.062 173717.6
-------- SUMMARY for GAE_Charrua:
Akills: 0 | Gkills: 3  | State: Landed (emerg) Bailed ok captured
==== Actions for pilot GAE_Alma: ====
05:00:00 GAE_Alma has disconected
05:00:00 GAE_Alma takes seat: 62Squadron222(0) - 63244.26 228020.05
05:00:00 GAE_Alma loads wep: 'LR-2x500lb'  fuel: 100%
05:55:17 GAE_Alma Kill to g01320(1) - 45751.07 146478.2
05:58:34 GAE_Alma downs to g01320 - 42068.01 150302.11
06:05:03 GAE_Alma damaged by landscape - 33584.973 173769.48
06:05:04 GAE_Alma lands - 33584.15 173776.83
06:05:04 GAE_Alma diches - 33584.15 173776.83
06:05:11 GAE_Alma bailed - 33584.48 173776.92
06:05:11 GAE_Alma bailed ok  - 33584.863 173776.42
06:05:20 GAE_Alma was shoot down by landscape - 33584.484 173776.97
-------- SUMMARY for GAE_Alma:
Akills: 1 | Gkills: 0  | State: Disco Damaged Landed (emerg) Bailed ok
==== Actions for pilot GAE_Tacuara: ====
05:00:00 GAE_Tacuara has disconected
05:00:00 GAE_Tacuara takes seat: 62Squadron231(0) - 63302.426 228103.11
05:00:00 GAE_Tacuara loads wep: '3x500'  fuel: 50%
05:01:44 GAE_Tacuara takes seat: 62Squadron231(1) - 63299.805 228100.77
05:01:54 GAE_Tacuara takes seat: 62Squadron231(0) - 63299.312 228100.47
05:13:25 GAE_Tacuara takes seat: 62Squadron231(1) - 82030.336 196132.06
05:13:29 GAE_Tacuara takes seat: 62Squadron231(0) - 82182.33 195898.75
05:19:20 GAE_Tacuara takes seat: 62Squadron231(1) - 100746.445 172377.08
05:19:21 GAE_Tacuara takes seat: 62Squadron231(0) - 100835.16 172259.84
05:22:14 GAE_Tacuara takes seat: 62Squadron231(1) - 110104.23 159978.14
05:22:19 GAE_Tacuara takes seat: 62Squadron231(0) - 110374.52 159589.78
05:27:28 GAE_Tacuara takes seat: 62Squadron231(1) - 125797.664 137557.64
05:27:30 GAE_Tacuara takes seat: 62Squadron231(0) - 125862.57 137490.94
05:30:25 GAE_Tacuara takes seat: 62Squadron231(0) - 133808.69 127239.9
05:34:55 GAE_Tacuara damaged by 11_Static - 138796.17 111000.836
05:35:00 GAE_Tacuara bailed - 138639.72 110487.4
05:35:02 GAE_Tacuara killed in his chute by 62Squadron231 - 138613.98 110410.94
05:35:02 GAE_Tacuara was shoot down by 11_Static - 138614.95 110408.016
05:45:30 GAE_Tacuara has disconected
-------- SUMMARY for GAE_Tacuara:
Akills: 0 | Gkills: 0  | State: Disco Damaged Bailed KIA
This exe file was created with the evaluation version of Perl2Exe.
For more information visit http://www.indigostar.com
(The full version does not display this message with a 2 second delay.)
Spitfire - Tanques suplementarios - 75 % jugo.
Sabia que podia ser mi ultimo vuelo, las cosas no se estaban dando ultimamente y nuestras tropas estaban dejando las armas,  yo ahi solo con mi spitfire intentando poner rumbo al castillo, las piernas me temblaban y tarde varios minutos en salir, el vuelo solitario me daba escalofrios, a lo lejos se veia un fuerte combate en el mar, lo paso de largo y sigo, luego de volar por un buen tramo sin novedades , escucho por radio que hay actividad en la zona y ahi nomas veo estelas de reactores, varias y no se a cual seguir, opto por una que  me queda en posicion y veo la silueta de 2  F-80 pasando por mi trompa, trato de girar mas cerrado y disparo una rafaga, el  avion se dio cuenta que lo seguia y pica para perderme, yo lo sigo al maximo de velocidad que podia aguantar mi aeronave. Estamos a pocos metros del suelo cuando de repente oprimo un boton del tablero que me hace perder el control unos segundos y termino en la arena hecho una bola de fuego.
Piloto: muerto.
Sali como número 2 de la escuadrilla liderada por el TF Charrua.  La navegación al blanco fué larga y lenta, dado que los Texan iban bastante cargados. Cuando por fin dimos con el blanco la cosa se tornó muy confunsa.  Costaba mucho distinguir que era que cosa, y encima de todo la AAA estaba durísima. Evidentemente protegían algo importante. Cuando por fin estoy seguro de cual es el objetivo trato de lanzarme con mi Texan, pero soy alcanzado por por una rafaga que aparentemente me parte un ala, y termino destruido sobre la arena.
AGK=0
AAK=0
Avión Destruido.
Piloto= Muy muerto.
TF Charrua Texan  '3x500'  fuel: 75%
Son las 5 de la mañana en el desierto nunca deja de hacer calor, me toca salir de líder , con el fiel GU Tacuara , ponemos rumbo directo a target, la misión es difícil para solo dos pilotos y dos cazas de escolta, la navegacion es es larga , la escolta se adelanta para ver si no se nos escapa el enemigo.
A unos 5 minutos del target los cazas no pueden actuar de ataque y tienen que empezar a actuar de cazas el enemigo ya esta ahí......
Mientras que nuestros cazas se juegan sus vidas en combate llegamos a la zona de ataque , nuestra misión es bombardear la mansión de un alto jefe y tratar de eliminarlo.
La AAA es tremenda el GU llega primero ya que nos separamos en el camino y quedo yo como 2 , nos ponemos a buscar la maldita mansión , solo veo una edificacion importante , el calor es insoportable, la AAA es feros , le ordeno al GU que ataque el targe que le evalué rentable, ya que es imposible estar mucho tiempo ahí.
Se lanza al blanco y por radio escucho que le rompen un ala y que caeeeeeeeee............... la impotencia es muy grande un valiente ha muerto , tomo altura y estoy dispuesto a vengarlo me lanzo sobre una edificacion muy bien custodiado con mucha AAA , pongo de cabeza el avión y me tiro en picada a unos 500 metros lanzo las bombas y escapo haciendo evasivas mi lanzamiento da en el blanco se ve un incendio importante en el lugar.
Por radio nos informan que un avión de porte muy pequeño había despegado de la zona , la información había llegado tarde, y se dirige hacia la costa rumbo a suez , todos los aviones en el aire se tienen que dirigir al encuentro de dicho contacto.
Llegando a la costa , los cazas dan con el contacto y logran abatirlo.....................
Me dirijo al porta que que estaba mas cerca que de la base, cuando logro encontrarlo, ya que la bruma era muy densa, hago una mala aproximacion , vengo muy alto pero igual encaro, siento el ruido del gancho y lo dejo correr pensando que el cable ya lo sostiene , pero el avión sigue su rumbo al agua, caigo , logro salir , soy rescatado inmediatamente por el portaaviones y me llevan a la enfermería , también esta Alma que había intentado un aterrizaje también fallido.....
Avión perdido
AGK 3
Piloto Vivo
Admin
