Canal de Suez 29_1
Iniciado por GAE_Yanito, 11 de Marzo de 2009, 11:52:21 PM
[12.03.2009 0:30:43] Mission: net/coop/CANAL DE SUEZ/SUEZ_29_1.mis is Playing
05:00:00 Mission BEGIN
05:00:00 GAE_Yanito is trying to occupy seat 243Squadrontc010(0)
05:00:00 GAE_Yanito is trying to occupy seat 238Squadrontc020(0)
05:00:00 GAE_Charrua has connected
05:00:00 GAE_Alma has connected
05:00:00 GAE_Castor has connected
05:00:00 GAE_Alma is trying to occupy seat 31SquadronRAAF000(0)
05:00:00 GAE_Alma is trying to occupy seat 31SquadronRAAF031(0)
05:00:00 GAE_Alma is trying to occupy seat r01110(0)
05:00:00 GAE_Alma is trying to occupy seat r01111(0)
05:00:00 GAE_Alma is trying to occupy seat 62Squadron030(0)
05:00:00 GAE_Castor is trying to occupy seat 31SquadronRAAF000(0)
05:00:00 GAE_Alma is trying to occupy seat 31SquadronRAAF001(0)
05:00:00 GAE_Castor is trying to occupy seat r01111(0)
05:00:00 GAE_Castor is trying to occupy seat r01110(0)
05:00:00 GAE_Castor is trying to occupy seat 62Squadron030(0)
05:00:00 GAE_Castor is trying to occupy seat 238Squadrontc022(0)
05:00:00 GAE_Castor is trying to occupy seat 243Squadrontc010(0)
05:00:00 GAE_Castor is trying to occupy seat 238Squadrontc030(0)
05:00:00 GAE_Charrua is trying to occupy seat 62Squadron000(0)
05:00:00 GAE_Charrua is trying to occupy seat 31SquadronRAAF020(0)
05:00:00 GAE_Daron has connected
05:00:00 GAE_Daron has disconnected
05:00:00 238Squadrontc020(0) seat occupied by GAE_Yanito at 81887.89 79238.18
05:00:00 238Squadrontc020 loaded weapons '5xCargoA' fuel 25%
05:00:00 31SquadronRAAF020(0) seat occupied by GAE_Charrua at 119302.34 277703.25
05:00:00 31SquadronRAAF020 loaded weapons 'default' fuel 100%
05:00:00 243Squadrontc010(0) seat occupied by GAE_Castor at 81856.96 79231.76
05:00:00 243Squadrontc010 loaded weapons '5xCargoA' fuel 25%
05:00:00 62Squadron030(0) seat occupied by GAE_Alma at 37037.51 148355.33
05:00:00 62Squadron030 loaded weapons 'default' fuel 100%
05:00:00 31SquadronRAAF000 damaged on the ground at 119272.92 277466.56
05:00:00 31SquadronRAAF001 damaged on the ground at 119254.43 277440.16
05:00:11 31SquadronRAAF001(0) bailed out at 119254.43 277440.16
05:00:11 31SquadronRAAF000(0) bailed out at 119272.92 277466.56
05:00:19 31SquadronRAAF001(0) successfully bailed out at 119209.97 277443.53
05:00:20 31SquadronRAAF000(0) successfully bailed out at 119221.44 277484.34
05:00:36 31SquadronRAAF000 removed at 119272.92 277466.56
05:00:36 31SquadronRAAF001 removed at 119254.43 277440.16
05:00:56 62Squadron030 in flight at 37060.51 149727.0
05:01:11 31SquadronRAAF020 in flight at 118682.15 276710.22
05:01:44 243Squadrontc010 in flight at 82084.04 77495.07
05:03:45 238Squadrontc020 in flight at 82020.445 77547.6
05:08:01 16_Static destroyed by 85_Chief0 at 63673.1 229054.02
05:08:19 28_Static destroyed by 84_Chief0 at 63825.04 228901.06
05:08:45 19_Static destroyed by 84_Chief0 at 63610.45 229106.38
05:08:56 30_Static destroyed by 84_Chief0 at 63892.38 228897.02
05:09:04 84_Chief0 destroyed by 21_Static at 64093.39 229262.58
05:09:04 20_Static destroyed by 84_Chief0 at 63751.41 229023.95
05:09:12 14_Static destroyed by 85_Chief0 at 63666.56 229110.44
05:09:26 23_Static destroyed by 85_Chief0 at 63820.68 228967.4
05:09:52 31_Static destroyed by 85_Chief0 at 63903.76 228834.84
05:09:55 32_Static destroyed by 85_Chief0 at 63967.55 228824.66
05:10:02 38_Static destroyed by 85_Chief0 at 63991.43 228756.9
05:10:04 62Squadron000 removed at 38072.945 157078.56
05:10:16 85_Static destroyed by 85_Chief0 at 64264.85 228379.69
05:10:32 31SquadronRAAF030 removed at 118943.09 277186.12
05:10:46 86_Static destroyed by 85_Chief0 at 63300.82 229002.03
05:11:03 21_Static destroyed by 85_Chief0 at 63748.63 228967.77
05:12:08 132_Static destroyed by 85_Chief0 at 63370.71 227644.52
05:12:49 131_Static destroyed by 85_Chief0 at 63348.74 227613.73
05:13:53 31SquadronRAAF020 turned wingtip smokes on at 85536.62 289763.56
05:13:55 31SquadronRAAF020 turned wingtip smokes off at 85498.77 289819.44
05:13:58 31SquadronRAAF020 turned wingtip smokes on at 85372.52 290024.88
05:13:58 31SquadronRAAF020 turned wingtip smokes off at 85337.51 290092.34
05:14:06 31SquadronRAAF031 removed at 118943.195 277186.25
05:15:23 105_Chief0 destroyed by 16_Chief0 at 138549.48 257369.11
05:17:51 85_Chief0 destroyed by 94_Chief1 at 63720.55 229274.6
05:18:35 2_Chief2 destroyed by 94_Chief2 at 63906.01 229110.05
05:18:56 8_Chief2 destroyed by 280_Static at 151164.9 188792.62
05:19:23 62Squadron030 damaged by 14_Chief at 38067.574 157894.75
05:19:23 62Squadron030(0) was killed at 38065.047 157937.61
05:19:23 62Squadron030 shot down by 14_Chief at 38065.047 157937.61
05:20:54 2_Chief1 destroyed by 94_Chief0 at 63908.426 229099.17
05:21:07 r01111 removed at 119220.05 277586.3
05:21:29 43_Chief1 destroyed by 94_Chief0 at 63938.99 229061.64
05:22:16 GAE_Alma has disconnected
05:22:42 94_Chief2 destroyed by 2_Chief0 at 64043.88 229420.64
05:23:16 r01110 removed at 119220.02 277586.28
05:23:19 94_Chief1 destroyed by 2_Chief0 at 64039.656 229411.25
05:23:34 94_Chief0 destroyed by 43_Chief0 at 64058.2 229404.33
05:23:40 49_Chief1 destroyed by 424_Static at 151311.6 190226.36
05:23:56 94_Chief3 destroyed by 2_Chief0 at 64018.887 229413.73
05:24:26 31SquadronRAAF020 landed at 110442.7 281412.12
05:24:26 31SquadronRAAF020 damaged on the ground at 110442.7 281412.12
05:24:53 62Squadron031 removed at 37060.76 158267.73
05:25:59 r01112 removed at 119220.016 277586.25
05:26:53 31SquadronRAAF020(0) bailed out at 110442.69 281412.12
05:26:56 31SquadronRAAF020(1) bailed out at 110442.69 281412.12
05:27:02 31SquadronRAAF020(1) successfully bailed out at 110478.43 281423.44
05:27:02 31SquadronRAAF020(1) was captured at 110478.43 281423.44
05:27:02 31SquadronRAAF020(0) successfully bailed out at 110469.41 281448.94
05:28:31 238Squadrontc030 removed at 154530.05 11947.976
05:29:59 31SquadronRAAF020 crashed at 110442.69 281412.12
05:30:01 GAE_Charrua has disconnected
05:33:45 184_Static destroyed by 265_Static at 151292.1 187090.75
05:38:56 g01010 removed at 63593.438 228323.83
05:39:14 50_Chief1 destroyed by 423_Static at 151182.78 190190.45
05:40:00 g01030(0) was killed at 173801.75 27446.008
05:40:00 g01030(1) was killed at 173801.75 27446.008
05:40:00 g01030(2) was killed at 173801.75 27446.008
05:40:00 g01030(3) was killed at 173801.75 27446.008
05:40:00 g01030 shot down by landscape at 173801.75 27446.008
05:41:34 8_Chief1 destroyed by 4_Static at 151153.36 188800.55
05:42:11 9_Chief1 destroyed by 280_Static at 151535.02 188779.02
05:42:17 g01011 damaged on the ground at 63593.44 228323.84
05:42:17 g01011 damaged by 68_Chief2 at 63593.44 228323.84
05:42:21 g01011 removed at 63593.926 228324.27
05:45:00 g01100(0) was killed at 173802.98 27449.896
05:45:00 g01100(1) was killed at 173802.98 27449.896
05:45:00 g01100(2) was killed at 173802.98 27449.896
05:45:00 g01100(3) was killed at 173802.98 27449.896
05:45:00 g01100 shot down by 2_Static at 173802.98 27449.896
05:45:38 g01012 damaged on the ground at 63593.37 228323.73
05:45:38 g01012 damaged by 2_Chief0 at 63593.37 228323.73
05:45:43 g01012(0) bailed out at 63593.367 228323.73
05:45:44 g01012(1) bailed out at 63593.367 228323.73
05:45:48 g01012 removed at 63593.367 228323.73
05:45:51 g01012(1) successfully bailed out at 63612.37 228373.02
05:45:53 g01012(0) successfully bailed out at 63619.93 228380.47
05:46:37 243Squadrontc010 landed at 119812.04 278388.56
05:48:51 50_Chief0 destroyed by 423_Static at 151173.28 190181.58
05:48:58 g01013 damaged on the ground at 63617.4 228358.12
05:49:12 g01013(0) bailed out at 63592.656 228323.03
05:49:12 g01013(1) bailed out at 63592.656 228323.03
05:49:18 g01013(0) successfully bailed out at 63614.945 228360.39
05:49:19 g01013 removed at 63592.656 228323.03
05:49:23 g01013(1) successfully bailed out at 63578.555 228386.88
05:49:45 g01020 removed at 27804.55 192478.42
05:50:01 GAE_Castor has disconnected
05:51:45 g01000 removed at 63593.344 228323.9
05:52:18 g01021 removed at 27804.547 192478.4
05:52:57 9_Chief0 destroyed by 265_Static at 151544.03 188789.72
05:54:18 g01001 removed at 63593.28 228323.81
05:55:54 238Squadrontc022 damaged on the ground at 178998.77 288891.94
05:55:54 238Squadrontc021 damaged on the ground at 179410.72 289379.0
05:56:34 238Squadrontc023 damaged on the ground at 182220.94 288634.47
05:56:38 238Squadrontc023(0) bailed out at 182487.69 288675.5
05:56:40 238Squadrontc023(1) bailed out at 182545.31 288677.38
05:56:40 238Squadrontc023(0) was killed at 182546.8 288681.1
05:56:40 238Squadrontc023(1) was killed at 182585.84 288678.6
05:56:42 238Squadrontc023 damaged by landscape at 182622.55 288672.9
05:56:44 238Squadrontc020 landed at 180580.92 291184.1
05:56:48 238Squadrontc023 shot down by landscape at 182765.9 288652.9
05:57:08 243Squadrontc011 removed at 118940.445 277186.78
06:00:27 243Squadrontc013 removed at 118940.484 277186.84
[06:02:16] Mission END
find 4 human pilots in mission:
Hyper Name       | plane code    | seat
GAE_Yanito       | 238Squadrontc020   | 0
GAE_Charrua       | 31SquadronRAAF020   | 0
GAE_Castor       | 243Squadrontc010   | 0
GAE_Alma       | 62Squadron030   | 0
==== Actions for pilot GAE_Yanito: ====
05:00:00 GAE_Yanito takes seat: 238Squadrontc020(0) - 81887.89 79238.18
05:00:00 GAE_Yanito loads wep: '5xCargoA'  fuel: 25%
05:56:44 GAE_Yanito lands - 180580.92 291184.1
-------- SUMMARY for GAE_Yanito:
Akills: 0 | Gkills: 0  | State: Landed
==== Actions for pilot GAE_Charrua: ====
05:00:00 GAE_Charrua takes seat: 31SquadronRAAF020(0) - 119302.34 277703.25
05:00:00 GAE_Charrua loads wep: 'default'  fuel: 100%
05:13:53 GAE_Charrua turns smoke On - 85536.62 289763.56
05:13:55 GAE_Charrua turns smoke Off- 85498.77 289819.44
05:13:58 GAE_Charrua turns smoke On - 85372.52 290024.88
05:13:58 GAE_Charrua turns smoke Off- 85337.51 290092.34
05:24:26 GAE_Charrua lands - 110442.7 281412.12
05:24:26 GAE_Charrua diches - 110442.7 281412.12
05:26:53 GAE_Charrua bailed - 110442.69 281412.12
05:27:02 GAE_Charrua bailed ok  - 110469.41 281448.94
05:29:59 GAE_Charrua crashed - 110442.69 281412.12
05:30:01 GAE_Charrua has disconected
-------- SUMMARY for GAE_Charrua:
Akills: 0 | Gkills: 0  | State: Landed (emerg) Bailed ok Crashed
==== Actions for pilot GAE_Castor: ====
05:00:00 GAE_Castor takes seat: 243Squadrontc010(0) - 81856.96 79231.76
05:00:00 GAE_Castor loads wep: '5xCargoA'  fuel: 25%
05:46:37 GAE_Castor lands - 119812.04 278388.56
05:50:01 GAE_Castor has disconected
-------- SUMMARY for GAE_Castor:
==== Actions for pilot GAE_Alma: ====
05:00:00 GAE_Alma takes seat: 62Squadron030(0) - 37037.51 148355.33
05:00:00 GAE_Alma loads wep: 'default'  fuel: 100%
05:19:23 GAE_Alma damaged by 14_Chief - 38067.574 157894.75
05:19:23 GAE_Alma was killed  - 38065.047 157937.61
05:19:23 GAE_Alma was shoot down by 14_Chief - 38065.047 157937.61
05:22:16 GAE_Alma has disconected
-------- SUMMARY for GAE_Alma:
Akills: 0 | Gkills: 0  | State: Damaged KIA
This exe file was created with the evaluation version of Perl2Exe.
For more information visit http://www.indigostar.com
(The full version does not display this message with a 2 second delay.)
Suministro #1-C47(4) - 25% + 5 Cargo.
Despego de la pista armada por las tropas en tierra junto a la ruta (il8) a mi lado estaba el grupo de Cator que tenia destino en Alarish. Salimos y me formo por atras para poner rumbo a Bersheeba, sigo el  radiofaro y me preparo unos mates con mi copiloto.
Luego de un buen rato vemos  combates a lo lejos por la zona de N26 mas o menos. El sol ya estaba casi completo y la bruma matutina no dejaba ver con claridad y de repente estoy  muy  proximo a la pista , informo por radio y  maniobro para  final directa. Carga entregada 100% piloto y aeronaves OK, Castor tambien entrego con exito en Alarish.
Piloto:OK
AVION:OK
Bersheeba suministrada
- Pasen la info que tengan sobre el recon de las defensas de G24.
- Posición del buque de aprovisionamiento en Suez.
- Charru: ¿ese es el buque que cañonea por el norte? Pasame posición.
Gracias ;)
Salgo con rumbo a J29 en busca de el buque que mantienen en jaque a la base de Arish ,  lo encuento al cabo de un 10 minutos rumbo 270 llengo por la costa .
Sencuentra al norte de unas islas en J29 mas o menos (marcado en el mapa que subi)
Luego de recibr algun golpe por asercarme tanto , me dirijo a rescatar a GU Alma , luego de encontrar la zona donde podia estar , intento aterrizar en la ruta que bordea la costa , cuando se esta por detener el avion una de las rueda se introduce en un poso y el avion capota , quedando 100% recuperable.
Detras de unas rocas sale el GU y nos ponemos a resgurado ya el barco empieza a cañonar.
Mandamos un aviso a la base de Arish y nos envian una grua para dar vuelta el avion remolcarlo a la base.
Lo mío fue un tranquilo vuelo con 4 C-47, los cuales reabastecieron la base de Al´Arish.
Perdón por la desaparicion repentina. Se corto Internet por un rato.
Si, aca también ocurre...
Cita de: GAE_Baco en 12 de Marzo de 2009, 11:52:50 AM
Con Bush no pasaba, jajajajajajaj jajajajaja
