Beta Sikorsky_HRS3 & Sikorsky_H19D ( Version Internacional-GAEv ) 1.05
Iniciado por GAE_Charrua, 12 de Agosto de 2010, 04:34:33 PM
Cita de: Flakiten en 11 de Agosto de 2010, 03:03:50 PM
[BETA] Sikorsky HRS3 & H19D version 1.05
Sikorsky HRS3 & H19D Chickasaw
Beta tester 1.05
This is a helicopter MOD for IL2 Sturmovik (c).
SAS~Sani has managed to make a flight model that is very close to real. Not the total flight characteristics of a helicopter, I know but, considering the limitations of the simulator, it is the best helicopter flight model I've tried. I am a helicopter pilot so I know something about it.
Notes:
1). The Sikorsky HRS-3 MOD has an auto stability system that makes flying the helicopter easier.
2). The real Sikorsky S-55 has a clutch between the engine and the rotor gear box. The pilot could engage and disengage the rotors. We don´t have this function in Il2 so I put an Clutch system that disengages the rotors if your throttle is set below 10%.
3). The floats are for emergency water landings. They are activated using the "arrestor hook" key and can be used one time only.
4). The "cabin door" key only opens the main cargo door.
5). You have 3 view positions. Normal in the right side or the cabin, head out using "toggle seat position" key and co-pilot view using "toggle gunsight" key.
6). Auto-rotation flight has been achieved but not the flare manouver. I don´t know if "flare manouver" is the correct term in engish, I´m talking about the manouver to reduce speed and stop descent near the ground. So you may do a small landing run.
7). If you got a full cabin/ammo load you must reduce the fuel load. The sikorsky S-55 was a power limited helicopter (radial engine).
8). AI has not yet learned how to fly helicopters.
9). If you use Quick Mission, try to start the flight on the ground/runway.
INSTALATION:
1). Open the Sikorsky_55_Helicopters_v1.5.rar file
2). Put the Sikorsky_HRS3_v1.5 & Sikorsky_H19D_v1.00 folders on your MODS folder
3). You must have the last SAS buttons installed - This model do not use DiffFM at this stage.
4). Open your air.ini file and paste the next entries:
H19D            air.H19D 1                      NOINFO  usa01 SUMMER
HRS3            air.HRS3 1                      NOINFO  usa01 SUMMER
5). Enjoy it
DOWNLOAD version 1.05: >>> DOWNLOAD from Mediafire
Updates:
Update 1.01 - Aug 12, 2010
Quote
Asymmetric lift added. If you exceed the VNE (165kph) the helicopter will turn to the left. The shift will be more violent as the speed increases. To avoid it set speed below the VNE. (thanks Sani)
Update 1.02 - Aug 14, 2010
Quote
Vanishing parts problem solved, also some console errors have been corrected (thanks Loku)
Update 1.03 - Aug 19, 2010
Quote
MDS carrier spawn problems solved (I think )
Update 1.04 - Aug 19, 2010
Quote
MDS carrier spawn problems solved (Sure)
Update 1.05 - Aug 29, 2010
Quote
Few FM corrections - H19D model added
Credits:
SAS~Sani: Helicopter class/FM development.
Flakiten: 3D model, sound, skins and class files.
Loku: 3D model advice.
Mario71: FM model advice.
If I forget someone let me know.
DOWNLOAD SKIN TEMPLATE: DOWNLOAD from Mediafire
DOWNLOAD SKINS: (you may create the HRS3 & H19D skin folders) DOWNLOAD from Mediafire
S!
Cita de: GAE_Flak en 12 de Agosto de 2010, 06:14:07 PM
La versión 1.01 solo agrega el efecto de sustentación asimétrica cuando se sobrepasa la VNE (165km/h).
SKINS ARMADA ARGENTINA PARA SIKORSKY S-55
Un S.58, derivado posterior del S-55.También sirvió en la Armada Argentina. Era el protagonista de una serie de TV de los 80 que se llamaba "Muelle 56"
alado
Muchas gracias Don Flak por traernos esta maravilla al sim.
Saludos amigos
Cita de: alado en 13 de Agosto de 2010, 10:08:23 PM
Saludos amigos
Siempre lo digo Sr. Alado: Usted es un caballero.
Cita de: GAE_Balker en 14 de Agosto de 2010, 03:02:50 AM
¿DiffFM MOD?  ::)
Eso es para no tener incompatibilidades de bottons, creo que dentro de la misma carpeta del avion , le ponene una especie de bottons personalizado para el avion y esto hace de interconeccion con eso y el sim.
Flak le podrias meter a la version sin armamento una luz de busqueda? Como la del Neptuno pero para abajo y adelante, que se activ con landing Lights?. Estraia bueno para busqueda y salvamento o para un monton de cosas mas.
Otra coas. Che con Force Feedbak, la palanca pega empujones con la velocidad sincronizados con el rotor. No se si se podra hacer algo o ono, pero para que sepas nomas...
1). Tema faro búsqueda. ¿Te has dado cuenta la visión hacia adelante que tiene el helicóptero? Me parece que sería medio al dope, no porque no ilumine si no porque no vas a ver lo que ilumina.
2). Force feedback. No tengo asi que ni idea. De todas maneras caé en cuenta que esto es un hack del FM normal del il2. Hay todo un verso de instrucciones en java para que vuele asi. No se si se podrá mejorar.
Slds.
NP!
Che no me anda la vista hacia abajo, a vos si? me habra bajado mal? lo rraor es qu eno me andovo  ni con la 0.1 ni con la 0.2
Actualice el 1º post con la versión 1.02 y puse las skins argentinas en el mismo post.
Algunos detalles que encontre.
Atentos todos cuando hagan la instalacion de la version 1.02, la carpeta cambia de nombre, cosa que no pasaba con la 1.01 ya que mantenia el nombre.
Por lo tanto recuerden borrar por completo el Sikorsky y realicen la instalacion desde cero.
Lo de salir desde el aire en los portaaviones es algo que me nacio con la version 1.02 cuando instalo la 1.01 no me sucede, ya hice el cambio 4 veces y las cuatro veces el error persiste con la 1.02 salgo del aire desde los porta con cualquier aeronave.
La prueba la estoy haciendo con el mapa que usamos de host el dia que dio a luz este hermoso aparato.
Por ahora voy a mantener la version 1.01 ya que no me genera conflictos con el ZUTI.
