Canal de Suez 12.1
Iniciado por GAE_Balker, 29 de Noviembre de 2008, 11:24:37 AM
Recon en Tirán y Mediterraneo.
F9F - Default - 100%
Salimos con el GU Alma a un recon para detectar coheteras enemigas cerca de la frontera. Despegamos de Bersheeba. Nos resultó imposible descender para verificar los caminos ante la intensidad de la AAA de los contactos navales sobre la frontera. Detectados 4 contactos.  3 chicos y uno mediano. Volvemos con algunos orificios a Bersheeba sin novedad.
Avión y piloto: ok.
05:00:00 GAE_Alma is trying to occupy seat gb01000(0)
[29.11.2008 3:31:34] Mission: net/coop/GAE-Alma/SUEZ_12.1recon.mis is Playing
05:00:00 Mission BEGIN
05:00:00 GAE_Alma is trying to occupy seat gb01000(3)
05:00:00 GAE_Alma is trying to occupy seat 205Squadronmaritimenc323(0)
05:00:00 GAE_Alma is trying to occupy seat gb01002(1)
05:00:00 GAE_Alma is trying to occupy seat gb01003(0)
05:00:00 GAE_Alma is trying to occupy seat gb01003(1)
05:00:00 GAE_Alma is trying to occupy seat gb01003(3)
05:00:00 GAE_Baco has connected
05:00:00 GAE_Balker is trying to occupy seat gb01001(0)
05:00:00 GAE_Balker is trying to occupy seat 205Squadronmaritimenc323(0)
05:00:00 GAE_Baco is trying to occupy seat 205Squadronmaritimenc323(0)
05:00:00 GAE_Alma is trying to occupy seat gb01002(0)
05:00:00 GAE_Alma is trying to occupy seat gb01001(0)
05:00:00 GAE_Alma is trying to occupy seat gb01002(3)
05:00:00 GAE_Charrua is trying to occupy seat gb01001(0)
05:00:00 GAE_Charrua is trying to occupy seat gb01002(0)
05:00:00 GAE_Charrua is trying to occupy seat gb01000(0)
05:00:00 GAE_Balker is trying to occupy seat gb01300(0)
05:00:00 GAE_Alma is trying to occupy seat gb01301(0)
05:00:00 GAE_Charrua is trying to occupy seat gb01010(0)
05:00:00 GAE_Baco is trying to occupy seat 205Squadronmaritimenc320(0)
05:00:00 GAE_Charrua is trying to occupy seat gb01011(0)
05:00:00 GAE_Charrua is trying to occupy seat 205Squadronmaritimenc322(0)
05:00:00 GAE_Baco is trying to occupy seat gb01010(0)
05:00:00 GAE_Charrua is trying to occupy seat 205Squadronmaritimenc321(0)
05:00:00 gb01301(0) seat occupied by GAE_Alma at 180054.69 290240.06
05:00:00 gb01301 loaded weapons 'default' fuel 100%
05:00:00 gb01300(0) seat occupied by GAE_Balker at 180073.19 290266.47
05:00:00 gb01300 loaded weapons 'default' fuel 100%
05:00:00 gb01011(0) seat occupied by GAE_Charrua at 154504.88 12106.774
05:00:00 gb01011 loaded weapons 'default' fuel 100%
05:00:00 gb01010(0) seat occupied by GAE_Baco at 154486.38 12080.356
05:00:00 gb01010 loaded weapons 'default' fuel 25%
05:00:00 gb01003 damaged on the ground at 154467.89 12053.939
05:00:00 gb01002 damaged on the ground at 154443.3 12018.827
05:00:00 gb01001 damaged on the ground at 154418.72 11983.715
05:00:00 gb01000 damaged on the ground at 154394.12 11948.603
05:00:00 gb01013 damaged on the ground at 154541.88 12159.609
05:00:00 gb01012 damaged on the ground at 154523.38 12133.192
05:00:11 gb01013(0) bailed out at 154541.88 12159.609
05:00:11 gb01003(0) bailed out at 154467.9 12053.948
05:00:11 gb01002(0) bailed out at 154443.3 12018.843
05:00:12 gb01003(1) bailed out at 154467.9 12053.948
05:00:12 gb01002(1) bailed out at 154443.3 12018.843
05:00:12 gb01000(0) bailed out at 154394.12 11948.621
05:00:14 gb01003(2) bailed out at 154467.9 12053.948
05:00:14 gb01002(2) bailed out at 154443.3 12018.843
05:00:14 gb01000(1) bailed out at 154394.12 11948.621
05:00:14 gb01012(0) bailed out at 154523.38 12133.192
05:00:14 gb01000(2) bailed out at 154394.12 11948.62
05:00:16 gb01003(4) bailed out at 154467.9 12053.948
05:00:16 gb01002(4) bailed out at 154443.3 12018.845
05:00:18 gb01001(0) bailed out at 154418.72 11983.73
05:00:18 gb01000(4) bailed out at 154394.12 11948.605
05:00:19 gb01002(1) successfully bailed out at 154451.34 11982.839
05:00:19 gb01001(1) bailed out at 154418.72 11983.73
05:00:20 gb01013(0) successfully bailed out at 154569.81 12117.821
05:00:21 gb01000(0) successfully bailed out at 154428.64 11918.917
05:00:21 gb01012(0) successfully bailed out at 154557.14 12123.325
05:00:22 gb01003(2) successfully bailed out at 154514.73 12056.297
05:00:22 gb01002(2) successfully bailed out at 154462.75 11979.663
05:00:22 gb01000(1) successfully bailed out at 154424.8 11915.028
05:00:22 gb01003(1) successfully bailed out at 154509.7 12018.393
05:00:22 gb01001(2) bailed out at 154418.72 11983.73
05:00:22 gb01003(0) successfully bailed out at 154493.84 11993.577
05:00:22 gb01002(0) successfully bailed out at 154473.69 11960.742
05:00:23 gb01000(4) successfully bailed out at 154429.42 11950.411
05:00:25 gb01001(4) bailed out at 154418.72 11983.73
05:00:25 gb01001(0) successfully bailed out at 154427.38 11942.543
05:00:25 gb01000(2) successfully bailed out at 154460.12 11951.225
05:00:25 gb01003(4) successfully bailed out at 154501.45 12004.604
05:00:27 gb01002(4) successfully bailed out at 154486.38 11970.857
05:00:29 gb01001(1) successfully bailed out at 154451.52 11933.206
05:00:33 gb01001(2) successfully bailed out at 154484.75 11988.978
05:00:35 gb01001(4) successfully bailed out at 154429.86 11919.971
05:00:36 gb01003 removed at 154467.9 12053.948
05:00:36 gb01013 removed at 154541.86 12159.62
05:00:36 gb01002 removed at 154443.3 12018.845
05:00:38 gb01000 removed at 154394.12 11948.605
05:00:40 gb01012 removed at 154523.38 12133.192
05:00:44 gb01001 removed at 154418.72 11983.73
05:01:00 33_Static destroyed by 2_Chief0 at 149600.55 273695.28
05:01:31 gb01300 in flight at 180873.34 291436.06
05:01:42 gb01010 in flight at 153917.7 11159.575
05:01:56 gb01301 in flight at 180812.6 291404.56
05:02:14 gb01011 in flight at 153693.69 10877.367
05:06:21 198_Static destroyed by 40_Chief at 153901.2 11738.82
05:07:46 368_Static destroyed by 40_Chief at 154537.14 11014.21
05:08:00 gb01320 damaged on the ground at 180079.28 290275.2
05:08:00 gb01321 damaged on the ground at 180054.69 290240.06
05:08:08 gb01320(0) bailed out at 180079.27 290275.16
05:08:10 gb01320(1) bailed out at 180079.27 290275.16
05:08:12 gb01320(2) bailed out at 180079.27 290275.16
05:08:15 gb01320(4) bailed out at 180079.27 290275.16
05:08:17 gb01320(0) successfully bailed out at 180057.8 290321.53
05:08:19 gb01320(1) successfully bailed out at 180025.84 290274.3
05:08:19 gb01321(0) bailed out at 180054.69 290240.06
05:08:21 gb01321(1) bailed out at 180054.69 290240.06
05:08:23 gb01321(2) bailed out at 180054.69 290240.06
05:08:23 gb01320(2) successfully bailed out at 180028.33 290314.28
05:08:23 gb01320(4) successfully bailed out at 180046.95 290313.3
05:08:25 gb01321(4) bailed out at 180054.69 290240.06
05:08:27 gb01321(0) successfully bailed out at 180017.25 290254.16
05:08:30 gb01321(1) successfully bailed out at 180026.06 290293.22
05:08:32 gb01321(2) successfully bailed out at 180029.77 290297.8
05:08:35 gb01320 removed at 180079.27 290275.16
05:08:36 gb01321(4) successfully bailed out at 180000.3 290274.6
05:08:45 gb01321 removed at 180054.69 290240.06
05:09:09 45_Chief2 destroyed by 45_Chief1 at 152310.98 14545.617
05:11:36 205Squadronmaritimenc320 removed at 203662.73 32237.766
05:12:41 18_Chief destroyed by 32_Chief at 132112.08 6725.3857
05:13:24 205Squadronmaritimenc321 removed at 203115.1 32044.635
05:15:18 205Squadronmaritimenc322 removed at 203618.4 32222.129
05:17:43 242_Static destroyed by 56_Chief at 152512.2 15910.99
05:17:49 205Squadronmaritimenc323 removed at 203971.72 32346.088
05:19:01 16_Chief2 destroyed by 239_Static at 151300.0 191517.19
05:19:08 16_Chief3 destroyed by 239_Static at 151295.81 191526.45
05:19:14 16_Chief8 destroyed by 16_Chief9 at 151300.0 191574.27
05:19:25 g01030 landed at 119525.016 277826.7
05:19:39 16_Chief6 destroyed by 16_Chief9 at 151300.0 191532.03
05:19:53 16_Chief7 destroyed by 16_Chief9 at 151294.97 191522.25
05:19:55 g01030 removed at 119453.875 277725.0
05:20:08 gb01010 damaged by landscape at 164560.38 20208.688
05:20:09 gb01010 landed at 164540.42 20198.158
05:20:09 gb01010 damaged on the ground at 164540.42 20198.158
05:21:40 16_Chief5 destroyed by 239_Static at 151297.38 190788.89
05:21:55 16_Chief4 destroyed by 239_Static at 151297.06 190775.89
05:22:01 g01031 landed at 119526.73 277829.1
05:22:29 239_Static destroyed by 16_Chief9 at 151158.38 189873.44
05:22:31 g01031 removed at 119454.086 277725.25
05:24:46 g01032 landed at 119529.375 277832.88
05:24:47 15_Chief1 destroyed by 15_Chief3 at 151282.47 190872.97
05:25:16 g01032 removed at 119454.164 277725.34
05:25:30 189_Static destroyed by 15_Chief3 at 151059.9 189874.6
05:26:25 154_Static destroyed by 15_Chief0 at 150905.88 189880.5
05:26:31 gb01010 shot down by landscape at 164540.42 20198.154
05:26:34 GAE_Baco has disconnected
05:26:51 186_Static destroyed by 15_Chief3 at 150970.52 189873.55
05:27:43 gb01011 landed at 154826.48 12398.188
05:30:48 gb01301 landed at 180413.2 290706.75
05:33:13 gb01300 landed at 179941.03 290340.1
05:33:57 Mission END
Recon
Salimos con el TF Baco  en  un recon para detectar contactos navales. El sin detectar mucho , a mitad de camino el TF Baco tiene una perdida de combustible teniendo que descender en un camino al este de la base.
Aterrizo sin novedades  y doy aviso del percance del TF.
Avión y piloto:Operativos
Tras ser designado lider de una patruya d ereconocimiento dle estrecho de tiran, salimos con rumbo norte, identificando inmediatamente un crucero y varias frasgatas/destructores, en el mismo cuando se encendio la lauz de combustible e inmediatamente se me apago el motor. logre aterrizar en un camino costero con leves daños a mi aparato, peor sin terminar la mision.
AAK-0
AGK-0
Avion dañado pero lejos de la base. Piloto vivo.
find 4 human pilots in mission:
Hyper Name       | plane code    | seat
GAE_Alma       | gb01301   | 0
GAE_Balker       | gb01300   | 0
GAE_Charrua       | gb01011   | 0
GAE_Baco       | gb01010   | 0
==== Actions for pilot GAE_Alma: ====
05:00:00 GAE_Alma takes seat: gb01301(0) - 180054.69 290240.06
05:00:00 GAE_Alma loads wep: 'default'  fuel: 100%
05:30:48 GAE_Alma lands - 180413.2 290706.75
-------- SUMMARY for GAE_Alma:
Akills: 0 | Gkills: 0  | State: Landed
==== Actions for pilot GAE_Balker: ====
05:00:00 GAE_Balker takes seat: gb01300(0) - 180073.19 290266.47
05:00:00 GAE_Balker loads wep: 'default'  fuel: 100%
05:33:13 GAE_Balker lands - 179941.03 290340.1
-------- SUMMARY for GAE_Balker:
==== Actions for pilot GAE_Charrua: ====
05:00:00 GAE_Charrua takes seat: gb01011(0) - 154504.88 12106.774
05:00:00 GAE_Charrua loads wep: 'default'  fuel: 100%
05:27:43 GAE_Charrua lands - 154826.48 12398.188
-------- SUMMARY for GAE_Charrua:
==== Actions for pilot GAE_Baco: ====
05:00:00 GAE_Baco takes seat: gb01010(0) - 154486.38 12080.356
05:00:00 GAE_Baco loads wep: 'default'  fuel: 25%
05:20:08 GAE_Baco damaged by landscape - 164560.38 20208.688
05:20:09 GAE_Baco lands - 164540.42 20198.158
05:20:09 GAE_Baco diches - 164540.42 20198.158
05:26:31 GAE_Baco was shoot down by landscape - 164540.42 20198.154
05:26:34 GAE_Baco has disconected
-------- SUMMARY for GAE_Baco:
Akills: 0 | Gkills: 0  | State: Damaged Landed (emerg)
RESULTADO
GAE
1 Neptune
IAF
EGIPTO
Salimos con el Tte  Balker en un vuelo de reconocimiento de posiciones enemigas cerca de la frontera. Despegamos de Bersheeba y seguimos el plan de vuelo sin poder detectar objetivos en tierra. El fuego antiaereo era bastante denso y solo detectamos 4 contactos navales.
Aterrizamos en Bersheeba sin novedad.
Piloto: Vivo
Avion: Aterrizado
