GAEV MAGAREVA 20
Iniciado por GAE_Flak, 20 de Abril de 2006, 08:39:05 PM
GAEV MAGAREVA 20
Misi?n:
Atacar el tr?fico mar?timo enemigo. Fue visto un convoy de mercantes? a 10 km al norte de la isla ubicada en AC06. El grupo de buques se desplazaba de oeste a este a una velocidad aproximada de 10 nudos.
Base:
Aer?dromo AT13.
Armamento recomendado:
01 bombas de 500 kg.
Cantidad de combustible recomendada:
Main Tank - 100% - 237 US Gal - 80min (80% pot)
Aux Tank - 2 x 154 - 308 US Gal - 100min (80% pot)
Meteorolog?a:
1000 hs. 3/8 de CU a 4500 FT.
Prohibiciones:
1) Sobrevolar territorio enemigo (cualquier parte de la isla magareva o circundantes.
BUEN VUELO!!
[Apr 21, 2006 11:51:59 PM] Mission: net/coop/Magareva/MAGAREVA_20.mis is Playing
10:00:00 Mission BEGIN
10:00:00 UN_NN000(0) seat occupied by GAE_Flak at 177540.0 114200.0
10:00:00 UN_NN000 loaded weapons '1x10002x154dt' fuel 100%
10:00:00 UN_NN300(0) seat occupied by GAE_Charrua at 177340.0 114310.0
10:00:00 UN_NN300 loaded weapons '1x5002x154dt' fuel 100%
10:00:00 UN_NN100(0) seat occupied by GAE_Balker at 177440.0 114180.0
10:00:00 UN_NN100 loaded weapons '1x10002x154dt' fuel 100%
10:00:00 UN_NN010(0) seat occupied by GAE_Oni at 177580.0 114200.0
10:00:00 UN_NN010 loaded weapons '1x10002x154dt' fuel 100%
10:00:00 UN_NN110(0) seat occupied by GAE_Mano at 177400.0 114180.0
10:00:00 UN_NN110 loaded weapons '1x10002x154dt' fuel 100%
10:00:00 UN_NN310(0) seat occupied by GAE_Condor at 177380.0 114310.0
10:00:00 UN_NN310 loaded weapons '1x10002x154dt' fuel 100%
10:04:53 UN_NN000 in flight at 178405.47 113955.06
10:04:58 UN_NN310 in flight at 178421.23 113985.81
10:05:35 UN_NN110 in flight at 178324.62 113904.445
10:05:35 UN_NN100 in flight at 178428.67 113996.484
10:06:25 UN_NN300 in flight at 178182.3 114002.48
10:06:29 UN_NN010 in flight at 178309.42 114022.914
10:31:42 5_Chief destroyed by UN_NN000 at 18048.904 54500.0
10:33:00 UN_NN310(0) was killed by hu1-1hu000 at 15214.206 62085.754
10:33:18 UN_NN310 damaged by landscape at 14587.122 63531.457
10:34:51 UN_NN300(0) was killed at 18444.502 56002.48
10:34:51 UN_NN300 shot down by 4_Chief at 18444.502 56002.48
10:35:32 GAE_Condor has disconnected
10:35:52 hu1-1hu000 damaged by UN_NN000 at 21050.074 62679.145
10:35:56 hu1-1hu000(0) bailed out at 21255.205 62293.03
10:35:57 hu1-1hu000(1) bailed out at 21337.396 62192.043
10:36:16 hu1-1hu000 shot down by UN_NN000 at 22068.52 62428.074
10:38:21 hu1-1hu000(1) successfully bailed out at 22322.012 61181.156
10:38:25 hu1-1hu000(0) successfully bailed out at 22130.883 61266.445
10:41:40 UN_NN110 landed at 48086.707 67813.04
10:41:40 UN_NN110 damaged on the ground at 48086.707 67813.04
10:41:48 UN_NN110(0) bailed out at 48086.855 67812.94
10:41:48 UN_NN110(0) successfully bailed out at 48088.95 67812.31
10:41:48 UN_NN110(0) was captured at 48088.95 67812.31
10:42:06 UN_NN110 shot down by UN_NN100 at 48087.61 67812.46
10:43:53 hu1-1hu001(1) was wounded at 43931.33 62467.016
10:44:59 hu1-1hu001 landed at 47441.637 61518.062
10:44:59 hu1-1hu001 damaged on the ground at 47441.637 61518.062
10:45:03 hu1-1hu001(0) bailed out at 47441.637 61518.062
10:45:05 hu1-1hu001(0) successfully bailed out at 47447.8 61523.363
10:45:05 hu1-1hu001(1) bailed out at 47441.637 61518.062
10:45:06 hu1-1hu001(1) successfully bailed out at 47439.777 61527.08
10:45:38 hu1-1hu001 shot down by UN_NN100 at 47441.33 61518.23
10:52:41 UN_NN010 landed at 55015.71 66071.89
10:52:41 UN_NN010 damaged on the ground at 55015.71 66071.89
10:58:11 GAE_Charrua has disconnected
11:08:29 UN_NN000 landed at 178140.7 114137.19
11:08:47 UN_NN100 landed at 178213.48 114081.914
11:08:47 UN_NN100 damaged on the ground at 178213.48 114081.914
11:09:50 Mission END
11:09:50 UN_NN010(0) was captured at 55015.65 66071.86
State: Emergency Landed
Enemy Aircraft Kill: 1
Enemy Ship Kill: 1
State: Captured
State: Captured
State: KIA
State: KIA
http://www.gaev.com.ar/WEB/magareva/MGRV_Resultado.htm
(1) - "Callej?n de Bombas", el TC Balker peina la cubierta con 500 kilos de explosivo.
(2) - El GU Mano es alcanzado por la explosi?n de la bomba del TC Balker.
El cad?ver del GU Condor, muerto por los ca?ones de 20 mm de un
caza enemigo, cae todav?a aferrando el disparador de sus seis ametralladoras.
(1) - El TC Charr?a pasa desfilando ante una fragata enemiga.
(2) - ...e impacta con uno de los palos del blanco.
(1) - El TN Flak derriba al primero de los excelentes pilotos maragrevos.
(2) - Tras retorcerse por todo el cielo, cae el segundo a manos del TC Balker.
Bajo fuego de AAA enemiga, el GU Oni intent? valerosamente rescatar
al GU Mano. Pero la maniobra s?lo sirvi? para hacerle compa??a.
Mi muerte se debe a un tiro sertero de unas de las fragatas mas alejadas, en el momento de la recuperacion , la cual hace explotar en el acto. ;D y mis restos se dan contra el mastil.
Pondre mas tarde fotos al respecto.
Cuando tenes razon te ne razon ;D jeje . si me comi el mastil :P, lo que no logro ver es si mi bomba impacta o no , y otra cosa, no logro ve mi intento de recuperacion, porque lo hice y antes de aparecer en el aire, cuando volaba el avion con mi palancaso para atras sube y ahi seve que me como el mastil.
Apesar de que no volvi, me gusto llevar la navegacion de mi seccion y la mision en si.
