GAEV MAGAREVA 06
Iniciado por GAE_Flak, 20 de Marzo de 2006, 12:45:01 AM
GAEV MAGAREVA 06
Caballeros, la RAN ha desplegado al HMAS Hobart (D 63) Crucero Liviano, al HMAS Warramunga (I 44) y a dos LSD para tomar las islas ubicadas en AO12, AO13 y AO14. El apoyo de fuego naval comenzara a las 1000 horas y el desplazamiento de los LVT-4 ser? diez minutos despues. La misi?n de la ARA ser? destruir toda oposici?n en la isla y proteger el desembarco.
10:00 horas.
Corsarios 01 y 02:
Altura de crucero: 6000 FT
Carga: estandar (default) + 100% combustible
Cobertura aire aire.
Corsarios 05, 06, 07, y 08:
Altura de crucero: 4500 FT
Carga: 8 cohetes 5 pulgadas + 1 bombas de 500 kg + 2 bombas de 250 kg + 100% combustible
Proteger el desembarco.
Texan 09, 10, 11 y 12
Carga: 3 bombas de 125 kg + 100% combustible
Seahawk 01:
Notas:
1). Se puede esperar defensa a?rea por parte del enemigo.
BUEN VUELO!!
MAGAREVA 06 - PRIMER OLEADA
[Mar 22, 2006 11:13:10 PM] Mission: net/coop/Magareva/MAGAREVA_06.mis is Playing
10:00:00 Mission BEGIN
10:00:00 UN_NN020(1) seat occupied by GAE_Isaak at 166691.05 90107.98
10:00:00 UN_NN022(1) seat occupied by GAE_Chacal at 166691.05 90097.98
10:00:00 UN_NN020(0) seat occupied by GAE_Flak at 166691.05 90107.98
10:00:00 UN_NN022(0) seat occupied by GAE_Condor at 166691.05 90097.98
10:00:00 UN_NN010(0) seat occupied by GAE_Castor at 166691.05 90125.98
10:00:00 UN_NN100(0) seat occupied by GAE_Balker at 166697.05 90088.98
10:00:00 UN_NN012(0) seat occupied by GAE_Mano at 166697.05 90116.98
10:00:00 UN_NN013(0) seat occupied by GAE_ONI at 166708.05 90111.98
10:00:00 UN_NN101(0) seat occupied by GAE_Buitre at 166708.05 90083.98
10:00:12 248_Static destroyed by 149_Static at 130192.26 31300.12
10:01:13 UN_NN010 in flight at 166681.67 91382.83
10:01:43 UN_NN012 in flight at 166710.17 91584.02
10:01:56 UN_NN013 in flight at 166680.1 91623.516
10:01:57 UN_NN020 in flight at 166636.94 91239.72
10:02:25 UN_NN022 in flight at 166694.9 91186.04
10:02:53 UN_NN100 in flight at 166700.64 90918.57
10:02:55 UN_NN000 landed at 165798.34 152887.2
10:02:55 UN_NN000 damaged on the ground at 165798.34 152887.2
10:03:00 UN_NN101 in flight at 166702.27 91040.37
10:04:14 222_Static destroyed by 266_Static at 133168.56 116666.94
10:09:27 126_Static destroyed by UN_NN011 at 133399.2 116198.86
10:09:30 UN_NN011 damaged on the ground at 133119.36 116511.78
10:09:30 UN_NN011 damaged by 127_Static at 133119.36 116511.78
10:09:35 UN_NN011(0) bailed out at 132842.33 116960.55
10:09:39 UN_NN011 shot down by 127_Static at 132576.05 117317.41
10:09:40 UN_NN011(0) was killed at 132604.5 117279.234
10:11:37 UN_NN010 damaged by 127_Static at 133258.98 116037.805
10:11:40 281_Static destroyed by UN_NN021 at 133398.75 116698.47
10:11:42 279_Static destroyed by UN_NN023 at 133699.48 116399.06
10:11:42 UN_NN010(0) was killed at 133333.88 115633.77
10:11:42 UN_NN010 shot down by 127_Static at 133333.88 115633.77
10:11:44 275_Static destroyed by UN_NN020 at 133100.84 116298.01
10:11:47 278_Static destroyed by UN_NN022 at 133600.69 116599.24
10:12:30 UN_NN022 damaged by 128_Static at 132633.56 116439.49
10:12:34 276_Static destroyed by UN_NN020 at 133197.34 116398.44
10:12:35 UN_NN022(0) was killed at 133068.34 116418.555
10:12:35 UN_NN022(1) was killed at 133068.34 116418.555
10:12:35 UN_NN022 shot down by 128_Static at 133068.34 116418.555
10:12:39 269_Static destroyed by 272_Static at 133803.44 116597.6
10:13:55 280_Static destroyed by UN_NN012 at 133600.22 116999.96
10:14:01 268_Static destroyed by UN_NN020 at 133499.97 115998.85
10:14:34 IJN_H_703z000 damaged by 272_Static at 140732.73 115651.945
10:14:39 IJN_H_703z000(0) bailed out at 140575.36 116012.5
10:14:41 IJN_H_703z000(1) bailed out at 140501.2 116110.266
10:14:41 IJN_H_703z000(2) bailed out at 140416.98 116201.79
10:14:43 IJN_H_703z000(3) bailed out at 140324.78 116287.484
10:15:03 277_Static destroyed by UN_NN013 at 133700.31 116798.47
10:15:06 267_Static destroyed by 266_Static at 133800.05 116999.65
10:15:07 271_Static destroyed by UN_NN020 at 133599.27 116199.79
10:15:10 IJN_H_703z003(0) bailed out at 140949.33 117224.68
10:15:12 IJN_H_703z000 shot down by 272_Static at 139262.11 118462.53
10:15:12 IJN_H_703z003(1) bailed out at 140970.4 117320.46
10:15:13 IJN_H_703z003(2) bailed out at 141003.64 117414.9
10:15:14 UN_NN013 damaged by 127_Static at 133454.8 115675.05
10:15:14 IJN_H_703z003(3) bailed out at 141050.64 117505.43
10:15:20 UN_NN013(0) bailed out at 133479.88 114952.47
10:15:22 Target 0 Failed
[Mar 22, 2006 11:36:51 PM] Mission: BLUE WON
10:15:22 UN_NN013(0) was killed at 133465.66 114783.16
10:15:22 IJN_H_703z003 shot down by UN_NN100 at 141492.6 117712.76
10:15:22 UN_NN013 shot down by 127_Static at 133464.06 114753.13
10:15:33 UN_NN020(0) bailed out at 133095.02 117647.38
10:15:33 UN_NN020(1) bailed out at 133099.95 117730.99
10:15:42 UN_NN020 damaged by landscape at 133120.12 118281.79
10:15:42 UN_NN020 shot down by 125_Static at 133120.12 118281.79
10:15:44 IJN_H_703z021 damaged on the ground at 133566.61 116663.13
10:15:46 IJN_H_703z020 damaged on the ground at 133574.8 116657.39
10:15:46 IJN_H_703z021(0) was killed at 133566.61 116663.125
10:15:46 IJN_H_703z021 shot down by UN_NN012 at 133566.61 116663.125
10:15:46 IJN_H_703z020 damaged by IJN_H_703z021 at 133574.8 116657.39
10:15:46 IJN_H_703z020(0) was killed at 133574.8 116657.39
10:15:46 IJN_H_703z020 crashed at 133574.8 116657.39
10:16:09 IJN_H_703z000(0) has chute destroyed by 272_Static at 139912.39 116821.24
10:16:17 IJN_H_703z000(0) was killed at 139903.72 116829.97
10:16:17 IJN_H_703z000(2) has chute destroyed by 272_Static at 139789.97 116829.91
10:16:19 UN_NN020(0) successfully bailed out at 133135.1 118082.62
10:16:19 UN_NN020(0) was captured at 133135.1 118082.62
10:16:24 IJN_H_703z000(2) was killed at 139782.05 116837.82
10:16:28 IJN_H_703z000(1) has chute destroyed by 272_Static at 139863.16 116802.83
10:16:30 IJN_H_703z003(0) has chute destroyed by 272_Static at 141220.52 117850.29
10:16:35 IJN_H_703z000(3) has chute destroyed by 266_Static at 139609.4 116958.42
10:16:35 IJN_H_703z000(3) was killed in his chute by 266_Static at 139609.05 116958.78
10:16:35 IJN_H_703z000(1) was killed at 139856.83 116809.17
10:16:37 IJN_H_703z003(0) was killed at 141228.84 117859.36
10:16:54 IJN_H_703z003(2) has chute destroyed by 272_Static at 141422.83 118008.44
10:16:59 IJN_H_703z003(3) successfully bailed out at 141525.05 118085.01
10:16:59 IJN_H_703z003(2) was killed at 141426.42 118012.086
10:17:00 IJN_H_703z003(1) successfully bailed out at 141363.25 118020.04
10:17:03 UN_NN012(0) bailed out at 131728.22 117097.66
10:17:11 IJN_H_703z003(1) was killed in his chute by 266_Static at 141363.25 118020.04
10:17:16 UN_NN012 damaged by landscape at 130907.13 117442.9
10:17:16 UN_NN012 shot down by 128_Static at 130907.13 117442.9
10:18:36 UN_NN012(0) successfully bailed out at 131144.55 117510.86
10:18:36 UN_NN012(0) was captured at 131144.55 117510.86
10:18:59 IJN_H_703z011 damaged by landscape at 138216.22 121067.96
10:19:05 IJN_H_703z011(0) was wounded at 138191.77 121045.66
10:19:05 IJN_H_703z011(0) bailed out at 138191.77 121045.66
10:19:05 IJN_H_703z011(0) successfully bailed out at 138191.9 121047.125
10:20:05 IJN_H_703z011 shot down by UN_NN100 at 138191.64 121045.805
10:21:33 0_Chief destroyed by 125_Static at 136903.66 117000.0
10:22:06 1_Chief destroyed by 125_Static at 136975.34 116980.0
10:23:20 2_Chief destroyed by 125_Static at 136779.77 117020.0
10:24:02 8_Chief destroyed by 127_Static at 136640.72 115980.0
10:26:33 7_Chief destroyed by 128_Static at 136388.67 116040.0
10:28:14 5_Chief destroyed by 127_Static at 135859.25 116000.0
10:28:24 UN_NN101 damaged by landscape at 166714.83 90155.82
10:28:31 UN_NN101 landed at 166695.75 90319.5
10:28:31 UN_NN101 damaged on the ground at 166695.75 90319.5
10:28:53 IJN_H_703z010 damaged by UN_NN100 at 159807.05 98372.125
10:28:57 IJN_H_703z010(0) bailed out at 159425.22 98240.61
10:29:06 IJN_H_703z010 shot down by UN_NN100 at 158676.81 98049.19
10:29:18 IJN_H_703z010(0) has chute destroyed by 131_Static at 158932.3 98007.5
10:29:29 IJN_H_703z010(0) was killed at 158873.58 97956.31
10:29:29 4_Chief destroyed by 128_Static at 135968.03 116960.0
10:29:45 UN_NN021(0) was wounded at 116263.86 82312.016
10:29:45 UN_NN021 damaged on the ground at 116263.86 82312.016
10:29:45 UN_NN021(0) was killed by IJN_H_703z002 at 116263.86 82312.016
10:29:51 UN_NN021(1) bailed out at 116133.2 81793.68
10:30:05 IJN_H_703z002(0) bailed out at 115807.1 80703.5
10:30:06 IJN_H_703z002(1) bailed out at 115774.72 80601.625
10:30:07 IJN_H_703z002(2) bailed out at 115737.94 80499.06
10:30:09 IJN_H_703z002(3) bailed out at 115695.65 80396.266
10:30:21 IJN_H_703z002 shot down by UN_NN021 at 114946.914 79663.11
10:31:08 UN_NN021 damaged by landscape at 112392.42 79401.54
10:31:08 UN_NN021 shot down by landscape at 112391.02 79411.26
10:31:09 6_Chief destroyed by 128_Static at 135588.55 116020.0
10:31:32 IJN_H_703z002(3) successfully bailed out at 115252.31 79833.66
10:31:41 IJN_H_703z002(2) successfully bailed out at 115287.26 79877.87
10:31:43 UN_NN021(1) successfully bailed out at 115803.87 81087.85
10:31:43 UN_NN021(1) was captured at 115803.87 81087.85
10:31:46 IJN_H_703z002(1) successfully bailed out at 115341.78 79989.45
10:31:54 IJN_H_703z002(0) successfully bailed out at 115479.08 80082.52
10:32:09 9_Chief destroyed by 128_Static at 135563.1 115960.0
10:32:49 UN_NN023 damaged on the ground at 111964.4 80897.3
10:32:53 UN_NN023(0) bailed out at 111751.53 80519.55
10:32:55 UN_NN023(1) bailed out at 111705.1 80402.016
10:32:58 UN_NN023 damaged by landscape at 111609.99 80094.49
10:32:58 UN_NN023 shot down by 124_Static at 111608.586 80089.164
10:32:58 UN_NN023(1) has chute destroyed by UN_NN023 at 111599.47 80136.01
10:32:58 UN_NN023(1) was killed at 111596.36 80129.81
10:32:59 UN_NN023(0) was killed at 111579.53 80179.12
10:33:08 3_Chief destroyed by 127_Static at 135451.8 117040.0
10:33:52 IJN_H_703z001 landed at 112228.63 81134.48
10:35:35 IJN_H_703z001 damaged on the ground at 112228.63 81134.48
10:35:41 IJN_H_703z001(0) bailed out at 112228.63 81134.48
10:35:42 IJN_H_703z001(1) bailed out at 112228.63 81134.48
10:35:43 IJN_H_703z001(2) bailed out at 112228.63 81134.48
10:35:44 IJN_H_703z001(3) bailed out at 112228.63 81134.48
10:35:46 IJN_H_703z001(0) successfully bailed out at 112257.08 81157.45
10:35:50 IJN_H_703z001(3) successfully bailed out at 112213.29 81098.21
10:35:53 IJN_H_703z001(1) successfully bailed out at 112227.61 81068.945
10:35:54 IJN_H_703z001(2) successfully bailed out at 112167.9 81106.84
10:36:05 IJN_H_703z001 removed at 112228.63 81134.48
10:37:33 UN_NN100 landed at 166694.31 91305.37
10:37:39 Mission END
State: Captured
Enemy Artillery Kill: 2
Enemy AAA Kill: 2
State: KIA
Enemy AAA Kill: 1
State: KIA
State: Landed at Airfield
Enemy Aircraft Kill: 1
Enemy Aircraft Kill: 3
State: KIA
Enemy AAA Kill: 1
State: Captured
Enemy AAA Kill:    1
State: KIA
Enemy AAA Kill: 1
State: Hit the Silk
MAGAREVA 06 - SEGUNDA OLEADA
[Mar 22, 2006 11:59:33 PM] Mission: net/coop/Magareva/MAGAREVA_06.mis is Playing
10:00:00 UN_NN010(0) seat occupied by GAE_Flak at 166691.05 90125.98
10:00:00 UN_NN012(0) seat occupied by GAE_Castor at 166697.05 90116.98
10:00:00 UN_NN013(0) seat occupied by GAE_Buitre at 166708.05 90111.98
10:00:00 UN_NN020(0) seat occupied by GAE_Bufalo at 166691.05 90107.98
10:00:00 UN_NN101(0) seat occupied by GAE_ONI at 166708.05 90083.98
10:00:00 UN_NN011(0) seat occupied by GAE_Condor at 166705.05 90125.98
10:00:00 UN_NN021(0) seat occupied by GAE_Chacal at 166702.05 90102.98
10:00:00 UN_NN100(0) seat occupied by GAE_Mano at 166697.05 90088.98
10:00:10 248_Static destroyed by 149_Static at 130192.26 31300.12
10:00:53 UN_NN010 in flight at 166692.47 91415.75
10:01:13 UN_NN011 in flight at 166690.7 91573.195
10:01:38 UN_NN012 in flight at 166658.56 91958.55
10:01:43 UN_NN013 in flight at 166672.4 91903.24
10:02:29 269_Static destroyed by 266_Static at 133803.44 116597.6
10:02:31 UN_NN020 in flight at 166681.33 91359.91
10:02:37 UN_NN021 in flight at 166721.75 91107.766
10:02:53 UN_NN000 landed at 165798.36 152887.58
10:02:53 UN_NN000 damaged on the ground at 165798.36 152887.58
10:03:30 UN_NN100 in flight at 166709.36 91504.984
10:03:37 UN_NN101 in flight at 166708.62 91281.15
10:03:37 267_Static destroyed by 266_Static at 133800.05 116999.65
10:04:07 271_Static destroyed by 272_Static at 133599.27 116199.79
10:06:30 UN_NN021(1) seat occupied by GAE_Chacal at 155839.03 100019.484
10:06:31 UN_NN021(0) seat occupied by GAE_Chacal at 155781.36 100072.695
10:06:31 UN_NN021(1) seat occupied by GAE_Chacal at 155758.1 100094.84
10:06:33 UN_NN021(0) seat occupied by GAE_Chacal at 155699.6 100152.36
10:08:03 268_Static destroyed by 272_Static at 133499.97 115998.85
10:09:30 127_Static destroyed by UN_NN012 at 132999.7 116199.04
10:11:37 275_Static destroyed by UN_NN013 at 133100.84 116298.01
10:11:48 126_Static destroyed by UN_NN011 at 133399.2 116198.86
10:11:55 220_Static destroyed by UN_NN010 at 133168.5 116637.02
10:11:55 221_Static destroyed by UN_NN010 at 133171.77 116651.44
10:11:55 225_Static destroyed by UN_NN010 at 133186.08 116610.02
10:11:55 222_Static destroyed by UN_NN010 at 133168.56 116666.94
10:11:55 223_Static destroyed by UN_NN010 at 133167.06 116680.39
10:11:55 224_Static destroyed by UN_NN010 at 133198.6 116699.66
10:11:55 228_Static destroyed by UN_NN010 at 133178.31 116559.29
10:12:27 279_Static destroyed by UN_NN013 at 133699.48 116399.06
10:12:43 276_Static destroyed by UN_NN012 at 133197.34 116398.44
10:13:29 125_Static destroyed by UN_NN011 at 133402.55 116900.6
10:14:29 280_Static destroyed by UN_NN010 at 133600.22 116999.96
10:14:41 128_Static destroyed by UN_NN011 at 133123.31 116537.54
10:14:45 IJN_H_703z003(0) bailed out at 141086.3 115376.086
10:14:47 IJN_H_703z003(1) bailed out at 141133.72 115491.164
10:14:48 IJN_H_703z003(2) bailed out at 141193.72 115593.56
10:14:50 IJN_H_703z003(3) bailed out at 141265.58 115683.56
10:15:03 IJN_H_703z003 shot down by UN_NN101 at 142184.34 115822.164
10:15:06 IJN_H_703z010 damaged by UN_NN100 at 141168.62 117345.93
10:15:14 IJN_H_703z010(0) bailed out at 141341.58 118677.76
10:15:18 GAE_Castor has disconnected
10:15:27 UN_NN011 damaged by landscape at 134912.4 119385.91
10:15:27 UN_NN011(0) was killed at 134920.31 119385.03
10:15:27 UN_NN011 shot down by 128_Static at 134920.31 119385.03
10:15:31 IJN_H_703z010 shot down by UN_NN100 at 142887.95 120296.69
10:15:35 IJN_H_703z003(1) has chute destroyed by 272_Static at 141574.83 116129.64
10:15:35 IJN_H_703z003(1) was killed in his chute by 272_Static at 141575.67 116130.516
10:15:44 278_Static destroyed by UN_NN010 at 133600.69 116599.24
10:15:47 IJN_H_703z003(2) has chute destroyed by 272_Static at 141685.72 116185.34
10:15:51 IJN_H_703z003(3) has chute destroyed by 272_Static at 141770.16 116208.66
10:15:54 IJN_H_703z003(2) was killed at 141697.36 116197.11
10:15:59 IJN_H_703z003(3) was killed at 141780.62 116219.15
10:16:06 IJN_H_703z021 damaged on the ground at 133566.61 116663.13
10:16:06 IJN_H_703z021(0) was killed by UN_NN013 at 133566.61 116663.13
10:16:13 IJN_H_703z003(0) was killed in his chute by 272_Static at 141534.16 116127.59
10:16:13 IJN_H_703z003(0) has chute destroyed by 272_Static at 141534.78 116128.23
10:16:23 UN_NN021(1) seat occupied by GAE_Chacal at 131408.31 117351.87
10:16:24 UN_NN021(0) seat occupied by GAE_Chacal at 131407.88 117246.78
10:16:26 UN_NN021(1) seat occupied by GAE_Chacal at 131417.03 117112.22
10:16:28 UN_NN021(0) seat occupied by GAE_Chacal at 131470.67 116833.9
10:16:30 IJN_H_703z020 damaged on the ground at 132921.38 115748.055
10:16:30 IJN_H_703z020 damaged by UN_NN010 at 132921.38 115748.055
10:16:30 IJN_H_703z020(0) was wounded at 132921.38 115748.055
10:16:30 UN_NN010(0) was killed at 132919.45 115745.21
10:16:30 UN_NN010 shot down by IJN_H_703z020 at 132919.45 115745.21
10:16:30 IJN_H_703z020(0) was killed at 132921.38 115748.055
10:16:30 IJN_H_703z020 crashed at 132921.38 115748.055
10:16:35 IJN_H_703z010(0) has chute destroyed by 266_Static at 142086.53 119969.234
10:16:38 IJN_H_703z021 removed at 133566.61 116663.13
10:16:43 IJN_H_703z010(0) was killed at 142096.89 119979.79
10:17:01 281_Static destroyed by UN_NN020 at 133398.75 116698.47
10:17:51 UN_NN101(0) was killed by IJN_H_703z011 at 142446.95 123402.33
10:18:00 UN_NN101 damaged by landscape at 142346.66 122286.01
10:18:00 UN_NN101 shot down by IJN_H_703z011 at 142346.66 122286.01
10:18:37 GAE_ONI has disconnected
10:18:41 UN_NN021(1) seat occupied by GAE_Chacal at 133691.19 116760.27
10:18:44 277_Static destroyed by UN_NN021 at 133700.31 116798.47
10:18:44 UN_NN021(0) seat occupied by GAE_Chacal at 133596.86 116592.2
10:18:45 UN_NN021(1) seat occupied by GAE_Chacal at 133552.34 116519.96
10:18:48 UN_NN021(0) seat occupied by GAE_Chacal at 133371.3 116280.555
10:19:47 226_Static destroyed by 266_Static at 133196.2 116592.67
10:21:19 UN_NN021(1) seat occupied by GAE_Chacal at 133108.06 116444.38
10:21:19 229_Static destroyed by UN_NN021 at 133178.52 116545.54
10:21:21 UN_NN021(0) seat occupied by GAE_Chacal at 132978.03 116244.24
10:21:23 UN_NN021(1) seat occupied by GAE_Chacal at 132900.45 116170.805
10:21:25 UN_NN021(0) seat occupied by GAE_Chacal at 132832.97 116111.01
10:21:53 227_Static destroyed by 266_Static at 133184.02 116577.13
10:22:32 270_Static destroyed by 266_Static at 133299.03 115798.21
10:23:23 UN_NN013 damaged by landscape at 129652.68 114623.93
10:23:28 UN_NN013 landed at 129547.13 114577.31
10:23:28 UN_NN013 damaged on the ground at 129547.13 114577.31
10:26:24 UN_NN021(1) seat occupied by GAE_Chacal at 133003.25 117016.33
10:26:26 UN_NN021(0) seat occupied by GAE_Chacal at 132860.36 116946.64
10:29:11 UN_NN021(1) seat occupied by GAE_Chacal at 136837.73 108855.664
10:29:15 UN_NN021(0) seat occupied by GAE_Chacal at 137113.25 108692.12
10:30:55 UN_NN021(1) seat occupied by GAE_Chacal at 144936.58 104195.71
10:30:55 UN_NN021(0) seat occupied by GAE_Chacal at 145009.58 104154.92
10:31:12 UN_NN100 landed at 160868.4 98296.734
10:33:19 UN_NN021(1) seat occupied by GAE_Chacal at 156115.58 97710.1
10:33:19 UN_NN021(0) seat occupied by GAE_Chacal at 156193.05 97656.18
10:33:45 IJN_H_703z000 landed at 112228.62 81134.484
10:33:52 UN_NN100 damaged on the ground at 160848.94 98283.18
10:34:56 UN_NN021(1) seat occupied by GAE_Chacal at 163941.86 94089.77
10:34:57 UN_NN021(0) seat occupied by GAE_Chacal at 164028.58 94052.125
10:36:43 IJN_H_703z001 landed at 112248.92 81169.49
10:38:35 UN_NN021 landed at 166708.33 90591.4
10:39:20 UN_NN021 damaged on the ground at 166683.14 90637.305
10:39:23 UN_NN021 damaged by 0_Static at 166683.34 90635.86
10:39:24 UN_NN021(0) was killed at 166683.58 90635.41
10:39:24 UN_NN021(1) was killed at 166683.58 90635.41
10:39:24 UN_NN021 shot down by 0_Static at 166683.58 90635.41
10:39:46 IJN_H_703z002 landed at 112269.09 81204.22
10:40:38 UN_NN020 landed at 166707.58 90656.016
10:42:54 Mission END
10:42:56 UN_NN013(0) was captured at 129547.26 114577.55
State: KIA
Enemy Static Aircraft Kill: 7
Enemy AAA Kill: 2
State: KIA
Enemy Tank Kill: 3
State: Captured
Enemy AAA Kill: 2
Enemy Static Aircraft Kill: 1
Enemy AAA Kill: 1
Enemy AAA Kill: 1
State: Left the Game
Enemy Tank Kill: 1
Enemy AAA Kill: 1
State: KIA
Los jugadores capturados durante ambas misiones quedaron liberados al conquistarse la isla.
El track+audio de comunicaciones aca: http://rapidshare.de/files/16191470/mision06.rar.html
Y les dejo fotos de la mision.
Debrief Misi?n 6
Despego en el Corsair N?5 a cargo de la secci?n de ataque, junto a Oni y Mano (+ 1 IA). Nos juntamos y ponemos rumbo a las islas objetivo.
Llegados a la zona se observan buques australianos atacando posiciones defensivas, en nuestra aproximaci?n a la base se hacen eco de nuestra presencia y empiezan las AAA hacer fuego contra nosotros, como las mismas se centran en mi principalmente, mando al IA a atacarlas y les ordeno a Mano y ONI que aprovechen, el IA destruye alg?n blanco pero es alcanzado. Yo sigo una ruta circular para mantener ocupada la AAA y recibo alg?n que otro impacto de bajo calibre, cuando termino la primer vuelta, reci?n escucho que la 2 secci?n ataca con dispar resultado, en ese momento recibo impactos nuevamente que dejan humeando la aeronave y perdiendo combustible, altero el rumbo como para una pasada directa para dejar las bombas y cohetes y as? abandonar la zona, pero un nuevo impacto de una AAA pesada (37 mm) me arranca un ala y fin para mi.  >:(
Debrief 2da oleada.
De nuevo el mismo objetivo, reorganizamos las tripulaciones y salgo como lider de la 2da secci?n (07) junto con Buitre (08), de lider iba Flak (05) con Condor de punto (06).
Mismo vuelo que el anterior hasta que la AAA hace aparici?n, se organizan los objetivos y con mejor fortuna son destruidos progresivamente, particularmente, destruyo con cohetes un 37mm y con ca?ones una 0.50?. Alg?n impacto menor no distraia la operaci?n, en un giro para buscar los 37mm restantes, veo una luz muy fuerte del mas all? y me teletransporta al m?s all?.
Traducido: Se me colgo la PC  :( >:(
Flak, en la 1? oleada tengo dos AAK + 1 AAA, los verifique con el track.
Cita de: GAE_Mano en 23 de Marzo de 2006, 01:14:14 PM
Esos 2 AAK, no son los 2 La que estaban por despegar?, no se tomar?an como AGK?
GU Mano, revisemos las sus acciones en el log de la primer oleada:
El GU Mano ocupa el corsario identificado en el log como UN_NN012
El GU Mano despega
El GU Mano destruye una posici?n AAA
El GU Mano destruye un La11 en pista identificado como IJN_H_703z021 que para mejor comprensi?n a partir de ahora ser? identificado como La11 (2).
El corsario UN_NN012 se da?a contra tierra.
El corsario UN_NN012 fue derribado por un AAA de 37mm.
El piloto GU Mano efect?a un escape exitoso.
El piloto GU Mano fue capturado.
Hechos que desencadenaron la destrucci?n del La11 IJN_H_703z020 ? La11 (1).
Ambos La11 son da?ados en la pista aparentemente por el accionar del GU Mano
El GU Mano destruye el La11 (2).
El La11 (1) es da?ado por el La11 (2)
El La11 (1) es destruido.
Que es tesitura de esta Jefatura de Operaciones contabilizar solamente los ?kills? directos.
Si se contabilizaran los ?kills? indirectos al derribar un avi?n y este destruyera objetos en tierra, estos se contar?an tambi?n.
Que un avi?n despegando o en pista no se considera AAK, si no AGK.
Salvo m?s elevado criterio esta Jefatura mantendr? los datos como se han consignado hasta ahora.
Primera oleada:
Aviones de escolta:
F4U - N? 1 - TC Balker: 3 AAK (Aterrizado).
F4U - N? 2 - TF Buitre: 1 AAK (Aterrizaje forzoso).
Relato:
Despegamos a las 10 dos F4U como escoltas de un grupo de ataque compuesto por T-6 y Corsarios. Mientras se desarrollaba el ataque de los Corsarios, el TF Buitre detecta 4 contactos que identifico como bombarderos enemigos. Entramos en combate. Dos La 11 les dan cobertura. En el desarrollo de las acciones se derriban 2 bombarderos enemigos y un La 11, mientras que el TF Buitre recibe da?os que lo obligan a regresar a las base. Emprendo la persecuci?n de un La 11 en retirada, que decide ametrallar la base australiana de Hedo. Si hubiera mantenido su rumbo nunca lo habr?a alcanzado. Dsiparo a aprox. 300 metros y cae sin control. El piloto es muerto por la AAA australiana de Hedo.
El TF Buitre sufre da?os en el aterrizaje, pero los dos pilotos regresamos sin heridas.
GAE_Bufalo
Esta Jefatura considera v?lido el criterio expuesto por Operaciones.-
