Rennell Island 5 (19/03/1955)
Iniciado por GAE_Chape, 19 de Marzo de 2013, 08:26:20 PM
Objetivos.
Disminuir o evitar el desembarco de la RAN en la Rennell Island.
Navegacion.
La FT navega con HDG 180 a toda maquina, 2 horas aprox. hasta el giro para 270.
Desde la FT hasta Bellona Island con NDB YG (de radio local) y luego HDG 135º hasta Kangava Bay.
Organizacion entre escuadras, material a discrecion, ya tenemos bombas de 1000 y cohetes.!!
[20.03.2013 3:23:21] Mission: net/dogfight/1/Rennell6.mis is Playing
[3:23:21] Mission BEGIN
[3:23:40] GAE_Chape:F9F2_Panther_R(0) seat occupied by GAE_Chape at 175018.3 159709.44
[3:23:40] GAE_Chape:F9F2_Panther_R loaded weapons 'default' fuel 80%
[3:23:40] F9F2_Panther_R damaged on the ground at 1.6509743E-4 1.2105954E-4
[3:23:42] GAE_Falcon has connected
[3:23:43] GAE_Charrua has connected
[3:23:45] GAE_Chape entered refly menu
[3:23:56] GAE_Ceteu has connected
[3:24:14] Gae_Cuervo has connected
[3:25:08] GAE_Alma has connected
[3:26:53] GAE_Alma:F9F2_Panther_R(0) seat occupied by GAE_Alma at 175018.27 156538.62
[3:26:53] GAE_Alma:F9F2_Panther_R loaded weapons '02x154Gal_Tank' fuel 80%
[3:27:38] GAE_Falcon:F9F2_Panther_R(0) seat occupied by GAE_Falcon at 175006.14 155754.69
[3:27:38] GAE_Falcon:F9F2_Panther_R loaded weapons '02x154Gal_Tank' fuel 80%
[3:27:57] GAE_Ceteu:F9F2_Panther_R(0) seat occupied by GAE_Ceteu at 180007.14 155461.52
[3:27:57] GAE_Ceteu:F9F2_Panther_R loaded weapons '04x500lbs_Bomb' fuel 100%
[3:28:30] GAE_Alma:F9F2_Panther_R in flight at 175029.39 154253.36
[3:28:48] Gae_Cuervo:F9F2_Panther_R(0) seat occupied by Gae_Cuervo at 179995.1 154622.47
[3:28:48] Gae_Cuervo:F9F2_Panther_R loaded weapons '04x500lbs_Bomb' fuel 100%
[3:28:54] GAE_Chape:F9F2_Panther_R(0) seat occupied by GAE_Chape at 175012.28 154484.48
[3:28:54] GAE_Chape:F9F2_Panther_R loaded weapons '02x154Gal_Tank' fuel 80%
[3:28:54] F9F2_Panther_R damaged on the ground at 1.443846E-4 2.5578509E-5
[3:29:24] GAE_Falcon:F9F2_Panther_R in flight at 175013.28 153389.44
[3:29:35] GAE_Ceteu:F9F2_Panther_R in flight at 180005.14 153223.55
[3:30:14] GAE_Chape:F9F2_Panther_R in flight at 174980.44 152449.9
[3:30:16] GAE_Charrua:F9F2_Panther_R(0) seat occupied by GAE_Charrua at 180000.89 153152.23
[3:30:16] GAE_Charrua:F9F2_Panther_R loaded weapons '04x500lbs_Bomb' fuel 100%
[3:30:37] Gae_Cuervo:F9F2_Panther_R(0) seat occupied by Gae_Cuervo at 180007.11 152704.53
[3:32:51] Gae_Cuervo:F9F2_Panther_R in flight at 180020.19 149798.52
[3:34:52] GAE_Charrua:F9F2_Panther_R in flight at 180115.08 147737.78
[3:53:46] F4U-5N damaged on the ground at 83671.23 43425.75
[3:53:50] F4U-5N(0) was heavily wounded at 83672.28 43423.484
[3:53:50] F4U-5N(0) bailed out at 83153.43 43275.98
[3:53:51] F4U-5N damaged on the ground at 83536.125 43372.754
[3:53:54] F4U-5N shot down by landscape at 82673.64 43176.555
[3:53:54] F4U-5N(0) was killed at 82768.94 43162.246
[3:53:56] F4U-5N(0) bailed out at 83042.63 43164.203
[3:54:43] F4U-5N damaged on the ground at 85579.18 43337.246
[3:54:57] F4U-5N(0) was killed at 86857.484 44505.3
[3:54:57] F4U-5N shot down by 25_Static at 86857.484 44505.3
[3:55:32] F4U-5N(0) successfully bailed out at 82016.18 42456.777
[3:56:50] F4U-5N damaged on the ground at 93859.516 53361.55
[3:59:40] BallisticDamage 8_Static Grua_I 0.112038605  damaged by  79_Static  at 82971.77 43763.22
[3:59:48] BallisticDamage 2_Static Hull1 0.027482558  damaged by  5_Static  at 84453.95 43144.96
[3:59:52] ExplosiveDamage 8_Static Hull2 0.2229705  damaged by  GAE_Ceteu_0  at 82971.77 43763.22
[4:00:05] ExplosiveDamage 79_Static Hull3 0.1218766  damaged by  Gae_Cuervo_0  at 83640.58 43411.5
[4:00:05] ExplosiveDamage 79_Static Hull3 0.03064067  damaged by  Gae_Cuervo_0  at 83640.58 43411.5
[4:00:05] ExplosiveDamage 79_Static Hull3 0.085935384  damaged by  Gae_Cuervo_0  at 83640.58 43411.5
[4:00:05] ExplosiveDamage 79_Static Hull3 0.08361177  damaged by  Gae_Cuervo_0  at 83640.58 43411.5
[4:01:03] ExplosiveDamage 4_Static Hull1 1.390629  damaged by  GAE_Charrua_0  at 82825.81 44991.06
[4:01:03] ExplosiveDamage 4_Static Hull1 2.0145988  damaged by  GAE_Charrua_0  at 82825.81 44991.06
[4:01:03] 4_Static destroyed by GAE_Charrua:F9F2_Panther_R at 82825.81 44991.06
[4:01:05] F4U-5N(0) bailed out at 105347.49 63250.742
[4:01:06] F4U-5N(0) successfully bailed out at 105339.125 63251.406
[4:01:49] F4U-5N crashed at 105347.63 63250.83
[4:06:59] ExplosiveDamage 2_Chief Hull3 0.3193825  damaged by  es01020  at 177463.14 120321.21
[4:06:59] ExplosiveDamage 2_Chief Hull3 0.041588847  damaged by  es01020  at 177463.14 120321.21
[4:06:59] SNJ-3_Texan_Trainer(0) was killed at 177459.8 120438.3
[4:06:59] SNJ-3_Texan_Trainer(1) was killed at 177459.8 120438.3
[4:06:59] SNJ-3_Texan_Trainer shot down by 2_Chief at 177459.8 120438.3
[4:06:59] ExplosiveDamage:NearMiss 2_Chief Hull3 0.024210505  damaged by  es01020  at 177463.14 120321.21
[4:09:23] ExplosiveDamage 2_Chief Hull3 0.21531677  damaged by  es01021  at 177462.78 117916.71
[4:09:23] ExplosiveDamage 2_Chief Hull3 0.0107805915  damaged by  es01021  at 177462.78 117916.71
[4:09:23] SNJ-3_Texan_Trainer(0) was killed at 177459.58 118032.46
[4:09:23] SNJ-3_Texan_Trainer(1) was killed at 177459.58 118032.46
[4:09:23] SNJ-3_Texan_Trainer shot down by 2_Chief at 177459.58 118032.46
[4:09:23] ExplosiveDamage:NearMiss 2_Chief Hull3 0.022629175  damaged by  es01021  at 177462.78 117916.71
[4:12:20] SNJ-3_Texan_Trainer landed at 178138.36 115095.66
[4:12:20] SNJ-3_Texan_Trainer damaged on the ground at 178138.36 115095.66
[4:12:22] SNJ-3_Texan_Trainer(0) bailed out at 178138.36 115095.65
[4:12:23] SNJ-3_Texan_Trainer(0) successfully bailed out at 178141.33 115102.2
[4:12:24] SNJ-3_Texan_Trainer(1) bailed out at 178138.36 115095.65
[4:12:25] SNJ-3_Texan_Trainer(1) successfully bailed out at 178147.39 115095.94
[4:12:50] SNJ-3_Texan_Trainer removed at 178138.42 115095.59
[4:13:59] ExplosiveDamage 2_Chief Hull3 0.0989878  damaged by  es01023  at 177462.1 113315.71
[4:13:59] ExplosiveDamage 2_Chief Hull3 0.039159488  damaged by  es01023  at 177462.1 113315.71
[4:13:59] SNJ-3_Texan_Trainer(0) was killed at 177458.84 113431.89
[4:13:59] SNJ-3_Texan_Trainer(1) was killed at 177458.84 113431.89
[4:13:59] SNJ-3_Texan_Trainer shot down by 2_Chief at 177458.84 113431.89
[4:13:59] ExplosiveDamage:NearMiss 2_Chief Hull3 0.022298714  damaged by  es01023  at 177462.1 113315.71
[4:15:23] F4U-5N shot down by landscape at 83834.586 44156.586
[4:17:55] F9F2_Panther_R removed at 177469.16 109336.21
[4:18:37] GAE_Charrua:F9F2_Panther_R landed at 180004.69 104668.04
[4:18:51] GAE_Charrua entered refly menu
[4:20:02] ExplosiveDamage:NearMiss 2_Chief Hull3 0.017363789  damaged by  es01010  at 177461.19 107273.21
[4:20:02] F9F2_Panther_R(0) was killed at 177455.17 107393.93
[4:20:02] F9F2_Panther_R shot down by 2_Chief at 177455.17 107393.93
[4:22:21] Gae_Cuervo:F9F2_Panther_R landed at 180002.77 100950.77
[4:22:26] Gae_Cuervo entered refly menu
[4:23:05] GAE_Chape:F9F2_Panther_R(0) was heavily wounded at 69626.9 64283.98
[4:23:05] GAE_Chape:F9F2_Panther_R(0) was killed by SeaFuryMkI at 69626.9 64283.98
[4:23:10] GAE_Ceteu:F9F2_Panther_R landed at 180004.39 100143.98
[4:23:10] GAE_Ceteu:F9F2_Panther_R damaged on the ground at 180004.39 100143.98
[4:23:13] GAE_Chape:F9F2_Panther_R shot down by SeaFuryMkI at 70798.06 64385.02
[4:23:21] GAE_Ceteu entered refly menu
[4:24:03] GAE_Ceteu:F9F2_Panther_R(0) seat occupied by GAE_Ceteu at 180006.45 99344.22
[4:24:03] GAE_Ceteu:F9F2_Panther_R loaded weapons '02x1000lbs_Bomb' fuel 80%
[4:24:22] GAE_Falcon:F9F2_Panther_R damaged by SeaFuryMkI at 68823.16 67844.26
[4:24:22] GAE_Falcon:F9F2_Panther_R(0) was wounded at 68828.445 67839.74
[4:24:23] GAE_Falcon:F9F2_Panther_R(0) was killed at 68828.445 67839.74
[4:24:23] GAE_Falcon:F9F2_Panther_R shot down by SeaFuryMkI at 68828.445 67839.74
[4:24:51] GAE_Falcon entered refly menu
[4:25:13] GAE_Falcon:F9F2_Panther_R(0) seat occupied by GAE_Falcon at 175018.16 98158.31
[4:25:13] GAE_Falcon:F9F2_Panther_R loaded weapons '02x154Gal_Tank' fuel 80%
[4:25:33] SeaFuryMkI damaged by GAE_Alma:F9F2_Panther_R at 77590.44 70076.36
[4:25:37] SeaFuryMkI(0) bailed out at 78100.54 70215.35
[4:25:46] SeaFuryMkI shot down by GAE_Alma:F9F2_Panther_R at 79165.44 70614.28
[4:25:58] SeaFuryMkI(0) was killed by GAE_Alma:F9F2_Panther_R at 81220.28 70991.81
[4:25:58] SeaFuryMkI damaged by GAE_Alma:F9F2_Panther_R at 81231.87 70995.5
[4:26:10] SeaFuryMkI shot down by GAE_Alma:F9F2_Panther_R at 82615.06 71567.42
[4:26:13] Gae_Cuervo:F9F2_Panther_R(0) seat occupied by Gae_Cuervo at 179994.33 97174.7
[4:26:13] Gae_Cuervo:F9F2_Panther_R loaded weapons '02x1000lbs_Bomb' fuel 80%
[4:26:26] GAE_Falcon:F9F2_Panther_R in flight at 174940.69 96279.47
[4:27:18] SeaFuryMkI(0) successfully bailed out at 78857.47 70672.125
[4:27:50] GAE_Ceteu:F9F2_Panther_R in flight at 180001.67 95066.734
[4:28:53] GAE_Charrua:F9F2_Panther_R(0) seat occupied by GAE_Charrua at 180000.39 94524.96
[4:28:53] GAE_Charrua:F9F2_Panther_R loaded weapons '02x1000lbs_Bomb' fuel 80%
[4:29:16] Gae_Cuervo:F9F2_Panther_R(0) seat occupied by Gae_Cuervo at 180006.44 94038.89
[4:29:48] Gae_Cuervo:F9F2_Panther_R(0) seat occupied by Gae_Cuervo at 180006.38 93513.914
[4:30:06] GAE_Falcon:F9F2_Panther_R damaged by landscape at 175017.47 93255.21
[4:30:08] ExplosiveDamage:NearMiss 1_Chief Hull2 0.025565652  damaged by  GAE_Falcon_0  at 175012.42 93179.33
[4:30:08] GAE_Falcon:F9F2_Panther_R(0) was killed at 175018.31 93173.234
[4:30:08] GAE_Falcon:F9F2_Panther_R shot down by landscape at 175018.31 93173.234
[4:30:08] ExplosiveDamage:NearMiss 1_Chief Hull2 0.012595122  damaged by  GAE_Falcon_0  at 175012.42 93179.33
[4:30:21] Gae_Cuervo:F9F2_Panther_R in flight at 180041.77 91763.48
[4:31:17] GAE_Falcon has disconnected
[4:32:09] GAE_Charrua:F9F2_Panther_R in flight at 180069.98 89883.59
[4:38:12] GAE_Alma:F9F2_Panther_R damaged by landscape at 175022.52 85163.73
[4:38:15] GAE_Alma:F9F2_Panther_R landed at 175005.08 85040.445
[4:38:15] GAE_Alma:F9F2_Panther_R damaged on the ground at 175005.08 85040.445
[4:39:22] GAE_Alma entered refly menu
[4:39:24] GAE_Alma:F9F2_Panther_R(0) seat occupied by GAE_Alma at 175018.16 83962.0
[4:39:24] GAE_Alma:F9F2_Panther_R loaded weapons '02x154Gal_Tank' fuel 80%
[4:40:27] GAE_Alma:F9F2_Panther_R damaged on the ground at 175018.17 82861.375
[4:40:28] GAE_Alma:F9F2_Panther_R in flight at 175016.98 82582.29
[4:41:08] GAE_Alma:F9F2_Panther_R(0) was killed at 174470.53 78411.07
[4:41:08] GAE_Alma:F9F2_Panther_R shot down by landscape at 174470.53 78411.07
[4:41:16] GAE_Alma entered refly menu
[4:41:17] GAE_Alma:F9F2_Panther_R(0) seat occupied by GAE_Alma at 175018.16 82088.69
[4:41:17] GAE_Alma:F9F2_Panther_R loaded weapons '02x154Gal_Tank' fuel 80%
[4:42:25] GAE_Alma:F9F2_Panther_R damaged on the ground at 175018.5 80895.58
[4:42:27] GAE_Alma:F9F2_Panther_R in flight at 175020.06 80584.055
[4:42:58] GAE_Chape entered refly menu
[4:43:02] GAE_Chape:F9F2_Panther_R(0) seat occupied by GAE_Chape at 175018.5 80340.94
[4:43:02] GAE_Chape:F9F2_Panther_R loaded weapons '02x154Gal_Tank' fuel 80%
[4:43:02] F9F2_Panther_R damaged on the ground at 1.4745789E-4 1.0580394E-4
[4:44:08] GAE_Alma:F9F2_Panther_R damaged by landscape at 175009.62 79226.89
[4:44:15] GAE_Alma:F9F2_Panther_R shot down by landscape at 175053.1 78932.75
[4:44:15] GAE_Alma entered refly menu
[4:44:16] GAE_Alma:F9F2_Panther_R(0) seat occupied by GAE_Alma at 175006.48 79100.055
[4:44:16] GAE_Alma:F9F2_Panther_R loaded weapons '02x154Gal_Tank' fuel 80%
[4:45:23] GAE_Chape:F9F2_Panther_R in flight at 175027.1 77072.92
[4:45:58] GAE_Alma:F9F2_Panther_R in flight at 175035.7 76341.44
[4:52:08] BallisticDamage 8_Static Chimenea_I 0.10434798  damaged by  79_Static  at 82971.77 43763.22
[4:52:08] BallisticDamage 8_Static LCVP2 0.5412136  damaged by  79_Static  at 82971.77 43763.22
[4:52:08] BallisticDamage 8_Static LCVP2 0.5438482  damaged by  79_Static  at 82971.77 43763.22
[4:52:11] GAE_Ceteu:F9F2_Panther_R(0) was wounded at 81826.19 44367.586
[4:52:27] BallisticDamage 79_Static Stack1 0.027368078  damaged by  8_Static  at 83640.58 43411.5
[4:52:28] BallisticDamage 79_Static Gun2 0.01565941  damaged by  8_Static  at 83640.58 43411.5
[4:52:33] BallisticDamage 2_Static Head12 0.2638558  damaged by  13_Static  at 84453.95 43144.96
[4:52:44] ExplosiveDamage 78_Static Hull2 1.0162266  damaged by  GAE_Charrua_0  at 86702.08 42613.94
[4:52:44] ExplosiveDamage 78_Static Hull2 1.1819792  damaged by  GAE_Charrua_0  at 86702.08 42613.94
[4:55:28] PBN-1(6) was killed by GAE_Charrua:F9F2_Panther_R at 92433.125 42137.28
[4:56:26] PBN-1(5) was killed at 92395.63 43984.582
[4:56:26] PBN-1(3) was wounded at 92395.63 43984.582
[4:56:26] PBN-1(3) was killed at 92395.63 43984.582
[4:56:26] PBN-1(0) was killed at 92395.63 43984.582
[4:56:26] PBN-1(1) was killed at 92395.63 43984.582
[4:56:26] PBN-1(2) was killed at 92395.63 43984.582
[4:56:26] PBN-1(4) was killed at 92395.63 43984.582
[4:56:26] PBN-1 shot down by GAE_Charrua:F9F2_Panther_R at 92395.63 43984.582
[5:00:47] SeaFuryMkI damaged by 0_Chief at 182006.67 60188.535
[5:00:48] SeaFuryMkI(0) was killed at 181856.1 60101.086
[5:00:48] SeaFuryMkI shot down by 0_Chief at 181856.1 60101.086
[5:03:46] ExplosiveDamage:NearMiss 0_Chief Hull2 0.027252134  damaged by  GAE_Ceteu_0  at 180000.14 59564.22
[5:03:46] ExplosiveDamage:NearMiss 0_Chief Hull3 0.026816094  damaged by  GAE_Ceteu_0  at 180000.14 59564.22
[5:03:47] GAE_Ceteu:F9F2_Panther_R(0) was killed at 179997.72 59616.414
[5:03:47] GAE_Ceteu:F9F2_Panther_R shot down by 16_Static at 179997.72 59616.414
[5:03:47] ExplosiveDamage:NearMiss 0_Chief Hull2 0.013352292  damaged by  GAE_Ceteu_0  at 180000.14 59564.22
[5:03:47] ExplosiveDamage:NearMiss 0_Chief Hull3 0.013540628  damaged by  GAE_Ceteu_0  at 180000.14 59564.22
[5:04:23] GAE_Chape:F9F2_Panther_R(0) was wounded at 44514.367 64916.562
[5:04:40] GAE_Ceteu entered refly menu
[5:05:07] GAE_Ceteu:F4U-5(0) seat occupied by GAE_Ceteu at 180005.14 58321.484
[5:05:07] GAE_Ceteu:F4U-5 loaded weapons 'default' fuel 50%
[5:05:27] F-80C(0) was killed at 35438.98 85912.35
[5:05:27] F-80C crashed at 35438.98 85912.35
[5:05:49] GAE_Ceteu:F4U-5 in flight at 180006.58 57230.043
[5:05:59] BallisticDamage 2_Chief MastC 4.984137  damaged by  3_Chief  at 177454.33 61318.145
[5:06:01] SeaFuryMkI damaged by 0_Chief at 181880.67 58682.734
[5:06:01] F-80C(0) was killed at 34666.805 88228.52
[5:06:01] F-80C crashed at 34666.805 88228.52
[5:06:04] SeaFuryMkI damaged by landscape at 182255.72 61180.2
[5:06:04] SeaFuryMkI(0) was wounded at 182257.89 61180.04
[5:06:04] SeaFuryMkI(0) was killed at 182257.89 61180.04
[5:06:04] SeaFuryMkI shot down by 0_Chief at 182257.89 61180.04
[5:06:05] SeaFuryMkI(0) bailed out at 181928.3 58150.7
[5:06:12] F-80C(0) was killed at 34954.19 89044.82
[5:06:12] F-80C crashed at 34954.19 89044.82
[5:06:23] SeaFuryMkI shot down by 0_Chief at 182527.39 56102.027
[5:06:26] SeaFuryMkI damaged by F4U-5N at 177619.03 62861.05
[5:06:29] F-80C damaged by landscape at 34284.746 88843.12
[5:06:30] GAE_Chape:F9F2_Panther_R damaged by landscape at 60172.684 72320.38
[5:06:30] GAE_Chape:F9F2_Panther_R(0) was killed at 60172.684 72320.38
[5:06:30] GAE_Chape:F9F2_Panther_R shot down by SpitfireMkXVIeCLP25 at 60172.684 72320.38
[5:06:30] F-80C(0) bailed out at 34290.6 88864.73
[5:06:30] F-80C(0) was killed at 34302.312 88907.95
[5:06:30] SeaFuryMkI(0) bailed out at 177269.2 63133.164
[5:06:34] SeaFuryMkI shot down by F4U-5N at 176985.72 63430.527
[5:06:51] F-80C shot down by landscape at 34290.55 88864.53
[5:08:47] GAE_Charrua:F9F2_Panther_R landed at 180001.86 54516.51
[5:08:56] GAE_Charrua entered refly menu
[5:09:00] SeaFuryMkI(0) successfully bailed out at 182385.81 56961.62
[5:10:01] GAE_Charrua:SNJ-3_Texan_Trainer(0) seat occupied by GAE_Charrua at 177456.98 57356.508
[5:10:01] GAE_Charrua:SNJ-3_Texan_Trainer loaded weapons 'default' fuel 80%
[5:10:08] GAE_Charrua:SNJ-3_Texan_Trainer(0) seat occupied by GAE_Charrua at 177456.81 57230.367
[5:10:47] Gae_Cuervo:F9F2_Panther_R landed at 180000.62 52561.652
[5:10:52] Gae_Cuervo entered refly menu
[5:11:16] SeaFuryMkI(0) successfully bailed out at 175949.14 64385.367
[5:11:29] Gae_Cuervo has disconnected
[5:12:11] SpitfireMkXVIeCLP25 landed at 174331.06 41802.113
[5:12:11] SpitfireMkXVIeCLP25 damaged on the ground at 174331.06 41802.113
[5:12:16] SpitfireMkXVIeCLP25(0) bailed out at 174331.06 41802.113
[5:12:16] SpitfireMkXVIeCLP25(0) successfully bailed out at 174330.28 41800.85
[5:13:07] SpitfireMkXVIeCLP25 shot down by 5_Chief at 174331.1 41802.2
[5:14:26] GAE_Charrua entered refly menu
[5:16:13] F4U-5N damaged by landscape at 177383.27 51152.242
[5:16:15] F4U-5N(0) bailed out at 177384.03 51139.375
[5:16:18] F4U-5N(0) was killed at 177383.98 51125.938
[5:16:34] F4U-5N crashed at 177384.31 51123.156
[5:16:50] GAE_Ceteu:F4U-5 landed at 179997.97 46526.312
[5:16:50] GAE_Ceteu:F4U-5 damaged on the ground at 179997.97 46526.312
[5:17:05] GAE_Ceteu has disconnected
[5:20:25] GAE_Charrua:SNJ-3_Texan_Trainer(0) seat occupied by GAE_Charrua at 180004.86 42977.133
[5:20:25] GAE_Charrua:SNJ-3_Texan_Trainer loaded weapons 'default' fuel 80%
[5:23:03] SpitfireMkXVIeCLP25 damaged by 0_Chief at 181049.94 40771.227
[5:23:08] SpitfireMkXVIeCLP25(0) bailed out at 180750.53 40195.05
[5:23:21] SpitfireMkXVIeCLP25 shot down by 0_Chief at 179814.53 38846.773
[5:23:38] GAE_Charrua:SNJ-3_Texan_Trainer(0) seat occupied by GAE_Charrua at 180004.84 39755.152
[5:23:40] GAE_Charrua:SNJ-3_Texan_Trainer(0) seat occupied by GAE_Charrua at 180004.83 39718.754
[5:23:45] BallisticDamage 0_Chief Hull1 0.032943774  damaged by  6_Chief  at 180000.16 39589.05
[5:23:51] GAE_Alma:F9F2_Panther_R damaged by 0_Chief at 179106.44 40362.555
[5:24:02] GAE_Alma:F9F2_Panther_R(0) bailed out at 178663.75 42064.95
[5:24:02] GAE_Alma:F9F2_Panther_R(0) was killed at 178663.75 42064.95
[5:24:10] GAE_Alma:F9F2_Panther_R shot down by 0_Chief at 178381.75 43292.586
[5:25:23] GAE_Charrua has disconnected
[5:25:27] SpitfireMkXVIeCLP25(0) successfully bailed out at 179986.28 39201.523
[5:25:35] GAE_Alma:F9F2_Panther_R(0) successfully bailed out at 178406.56 42422.805
[5:26:37] SpitfireMkXVIeCLP25 damaged by 0_Chief at 176823.62 39226.066
[5:26:37] SpitfireMkXVIeCLP25(0) was wounded at 176823.62 39226.066
[5:26:42] SpitfireMkXVIeCLP25(0) bailed out at 177130.38 39266.613
[5:26:53] SpitfireMkXVIeCLP25 shot down by 0_Chief at 177682.25 39338.8
[5:27:24] Mission END
GAE_Falcon
1er Vuelo
F9F2_Panther_R - 2 tanques x 154 Gal - fuel 80%
Despego del V2 como parte de la sección de caza liderada por el TF Alma y el TN Chape con el objetivo de cubrir el ataque a las fuerzas de desembarco en la isla Renell. Tras una larga PAC nos topamos con aviones enemigos. En un primer momento pierdo a mis compañeros que entran en combate. Chape, seriamente comprometido, intenta volver a la FT, lo diviso y busco acompañarlo pero está a mucha distancia. De lejos veo cómo dos Sea Fury lo atacan y derriban. Al llegar al sitio donde cayó se une a la partida un tercer Sea Fury y en pocos segundos dan cuenta de mí.
Avión: DESTRUIDO
2do vuelo
Vuelvo a salir del V2 para unirme al TF Alma que combatía en soledad. Al despegar, el motor de mi avión se sobrecalienta demasiado y empiezo a perder potencia. Alma decide emprender el regreso y me ordena apontar para cambiar de avión. Con mi aeronave seriamente comprometida, perdiendo potencia a cada momento, suelto tanques y enfilo hacia el portaviones logrando apontar dificultosamente al límite de la pérdida, pero al enganchar en el cable, mi avión golpea contra la cubierta y explota.
Avión: DESTRUIDO
F9F2_Panther_R  '04x500lbs_Bomb' fuel 100%
Como numeral 3 salimos con rumbo a la isla, con los cazas en avanzada  tenemos el espacio aereo libre.
Con las islas en visual y casi dentro de ellas tengo un recalentamiento de turbina que me deja sin potencia, tras que se complico me quedo sin comunicaciones solamente morse, Ceteu y Cuervo toman la delantera y aviso que voy hacer el ataque igual, cuando llego a la zona es un espectaculo digno de ver de las alturas, las trazadoras en el aire se proyectan como grandes chorros de agua letales que serpentean por el cielo.
Tratando de tomar velocidad y planificar un escape limpio, entro golpeo y salgo con rumbo directo de la flota, mis bombas se esparcen por todo el barco y lo mando al fondo.
Después de un lento regreso y mirando por todo el cielo, ya que también estaba sin cobertura de cazas, llego a la flota indico mi emergencia y me dan prioridad, en la corrida final del anavisaje , al desplegar los flaps se dañan, mi cabeza va a mil tratando de resolver un escape que si se presentaba iba a ser muy difícil de lograr,  a pocos metros aplico los frenos de aire, y logro posar el Panther y enganchar , frena y de inmediato salgo del avion para que lo muevan de cubierta.
Corro a dar mi parte de misión y prepararme para otra salida.
ANK 1
Avion ok apontado
F9F2_Panther_R '02x1000lbs_Bomb' fuel 80%
Nuevamente salgo como numeral 3 ponemos rumbo al lugar de desembarco, Ceteu divide los objetivos y nos lanzamos entro junto a Ceteu hace su ataque , voy por un barco de desembarco, que esta próximo a la costa, tiro y mis bombas impactan pero no es suficiente para mandarlo al fondo.
Ceteu se retira dañado , sigo con mis dramas de comunicación, por radio escuchaba a Cuervo que daba nota de un contacto, ya lo había identificado y estaba intentándolo derribar (un Catalina) después de varias pasadas termina cayendo, nos volvemos a la flota , cuando llegamos vemos que hay varias aeronaves dando vuelta, intercepto a una y la identifico como hostil, la intercepto varias veces y cuando estoy por rematar me quedo sin municiones, con mis problemas de comunicaciones se me hace casi imposible decirle a Cuervo que estoy con esa aeronave, al quedar sin municiones le hago una pasada rasante para intimidarlo ya que el avion esta destruido y que salte del mismo, cuando paso por debajo del avion veo pasar trazadoras muy cerca de mi aeronave , después me entero que son las de Cuervo, el piloto del avion termina saltando cuando le sestan un impacto de AAA y termina de sentenciar el avion.
Me dirijo al apontaje y lo hago sin inconveniente.
ANK (daños a un barco)
AAK 1 Un catalina - (daños a una 2ª aeronave)
Avion ok Apontado
Despego como numeral 2 de la escuadra de ataque liderada por el teniente Ceteu. Luego de orbitar la flota y ponernos en formación, ponemos rumbo hacia el objetivo.
  Al llegar a la bahía indicada nos encontramos con múltiples objetivos navales. Ataco con todas mis bombas al acorazado mas cercado que tenga, y a pesar de acertarle todas las bombas, solo logro dañarlo.
Vuelvo con rumbo al portaaviones y aponto sin novedad.
AGK: 0 (ExplosiveDamage 79_Static   damaged by  Gae_Cuervo_0)
  Al llegar a la bahía indicada nos encontramos con múltiples objetivos navales. Me asignan un objetivo cerca de la costa. Entro al misma pero mis bombas le pasan por un costado y no tienen efecto alguno. Al volverme identifico un avión de origen desconocido, para cuando obtengo confirmación de destruirlo, el mismo ya es destruido por Charrua.
Pongo rumbo al portaaviones donde aponto sin novedad.
Avion: ok
F9F2_Panther_R/'02x154Gal_Tank'/Jugo80%
La 2º escuadra de Caza y Ataque a la que pertenezco, tenia asignada para hoy la tarea de proteger el avance de la 1º eacuadra de Ataque. Para ello 3 F9F2 decolaron desde el ARA 25 de Mayo, avanzando al sector denominado Kangava Bay, donde la RAN desembarcaba fuerzas para tomar el control de la Isla. Nosotros liderados por el Teniente Alma yo como su wingman y escoltados por el GU Falcon, navegamos utilizando la señal proveniente desde una radio de la isla Bellona. Con la tierra grande a la vista nos situamos en el sector Este y orbitamos hasta la llegada de una Escuadra de Corsarios que habia salido previamente a la 1º de Ataque y mas tarde observamos sin novedad la entrada desde el norte de la bahia de los nuestros.
Seguimos orbitando la isla por un periodo posterior al escape del Ataque y decidimos agrandar la CAP para tener mayor dominio del sector. Para ello nos dirijimos hasta la Isla chica (Bellona). Alli nos esperaban 4 Machi que nos enfrentaron. Soy el primero en localizarlos, tras el aviso me ordenan poner mi proa a ellos. Tras algun tiempo de combate soy alcanzado y quedo sin alerones tintento poner rumbo a la FT pero no puedo escapar soy derribado.
Piloto=Kia
Avion=Destruido
_______________________________________________________________________
Nuevamente desde la FT hacia Bellona para reunirme con Alma al Norte de Rennell, luego de encontrarnos intentamos dominar el sector pero soy nuevamente derribado.
Piloto=Kia
Avion=Destruido
F9F2_Panther_R/'02x154Gal_Tank'/80% Fuel
Salgo como lider de la 2da escuadra de caza. Debido a la escaces de pilotos salimos todos juntos, con Chape como wingman y Falcon como nro 3. Nos dirigimos hacia las islas siguiendo el beacon y nos adelantamos a la escuadra de Ataque para asegurar la zona. Ya sobre el objetivo mantenemos una cap sobrevolando la zona mientras ataque realiza su mision. Ya concretado el ataque sobre los buques y con la escuadra de ataque retornando nos dirigimos hacia el norte donde encontramos un grupo de reactores. Entablamos combate siendo derribados Falcon y Chape. Por mi parte soy seriamente averiado logrando derribar a 2 contactos enemigos. Emprendo luego el retorno a la flota donde descubro que el sistema hidraulico del tren de aterrizaje no funciona. Intento el apontaje de panza logrando ponerlo sobre el porta pero quedando el avion inutilizado.
AAK= 2
Piloto= Ok
Avion=Destruido(para repuestos)
Salgo nuevamente, esta vez solo, despues se uniria Chape. LLego hasta las islas pero no encuentro contactos. A los pocos minutos me informa la escuadra de ataque, quienes se encontrabas apontando, que sobre la flota se detectan contactos enemigos. Vuelvo sobre mis pasos e intercepto a los contactos. Me trenzo en combate y logro averiar a uno, pero cuando me acerco para rematarlo la triple a de los portas termina derribandome... Logro eyectarme pero pierdo la aeronave.
AAK= 0
Piloto=Eyectado
Avion=Destruido
Combatiendo sobre la flota poco antes de ser derribado por antiaerea propia
1º Vuelo:
F9F-2 Panther R - Bombas 4x500 lbs. - Fuel 100%
-Tiene cara de cansado, Teniente... No se lo tome a mal pero debería descansar más.
El cabo que me ayuda con los correajes en la carlinga a dado en el clavo, tengo un cansancio infernal, sumado a una sensación de desasosiego que anuncia un día olvidable.
En fin, que no queda otra, enciendo la turbina y ruedo a catapulta, decolando como ya es clásico liderando Ataque, con A2 Cuervo y Charrúa, A3.
Navegamos sin problemas hasta Rennell, y decido el ataque sobre Kangava Bay desde el noroeste, siguiendo el eje de la isla. Con Charru que viene atrasado por problemas de turbina, le dejo libertad de acción y entro con Cuervo.
La costa no ayuda con el skip bombing, debido a su altura, pero lo peor es un acorazado que abre fuego con todas sus piezas de AAA.
Me plancho al agua violentamente, casi me estrello pero logro interponer la silueta de mi blanco de tal manera que quedo oculto del acorazado por el mismo, el cual es arrasado por los disparos, causando mortandad entre su tripulación que debe morir a montones sin saber porqué...!!
Asombrado por el volumen de los disparos, me mantengo planchado, lo que hace que lance muy bajo y mis bombas no se activan antes de llegar al blanco, así que sólo queda salir escapando haciendo mil cabriolas para que no me toquen. Cuervo me avisa que acierta pero no hunde, y Charru, que viene como puede, entra, acierta y hunde...!!!
Nos retiramos a la flota, entro perfecto a la final, pero al tocar cubierta, reboto un poco  y se me rompe una pata del tren, la derecha. Me bajo, no muy convencido de volver en un segundo vuelo.
ANK: 0
Avión: Averías leves Apontado
2º Vuelo:
F9F-2 Panther R - Bombas 4x500 lbs. - Fuel 80%
Nueva salida al mismo blanco, que resulta un calco de la anterior.
Decidido a hacer blanco, me mantengo un poco más alto. Grave error, que el acorazado no perdona. A punto de lanzar, me acierta la AAA, rompiéndome la mitad de los comandos e hiriéndome en brazo y pierna derechos. El avión levanta la nariz violentamente por lo que mi ataque sale para el Diablo, las bombas deben haber caído en Australia o Nueva Zelanda...
Con la vista cada vez más roja por la pérdida de sangre, llego sobre la FT, pido prioridad y me voy a final directa, la cual entro a velocidad alta a no tener flaps. Pero la sensación ominosa se vuelve a apoderar de mí, un presentimiento fatal que se cumple luego de una final impecable, porque cuando el avión roza apenas la cubierta, explota en mil pedazos.
ANK: 0
Piloto : KIA
3º Vuelo
F4U-5 Corsario - Default - Fuel 50%
Como las defensas de la FT abren fuego, corro a un Corsario y despego apresurado, aunque aún receloso y más agotado que nunca.
La FT abate a un incursor frente a mis narices, así que me vuelvo al V1 e inicio circuito de apontaje, que me sale perfecto, salvo el pequeño detalle que no bajo el tren. El aviso del Control llega por un canal que no escucho, así que me llevo la sorpresa del siglo al ver que luego de una suave aproximación, se doblan las palas de la hélice.
Harto, me bajo y me voy a la isla, bajo por las escaleras buscando mi camarote y mi litera donde me acuesto a dormir
