Rise of Flight WWI
Iniciado por GAE_Charrua, 28 de Febrero de 2009, 12:31:15 AM
Porsupuesto lo voy a instalar pero con estos requerimiento me parece que me quedo afuera.. :'( :'( :'(
Recommended Technical Requirements
As expected, RoF will need a system with a strong CPU, video card and RAM. neoqb has the requirements for RoF already on their web site:
    * Processor: Intel Core 2 Duo 2.8 GHz
    * RAM: 3 GB
    * Hard Disk Space: 6 GB
    * Video Card: 512MB (NVIDIA GeForce 9800 Series or AMD ATI Radeon 4850 Series)
    * Internet Access: 512 kb/sec Connection (or better)
    * Operating System: Windows XP or Windows Vista
    Windows XP requirements can be a little bit less then listed above
    Support of 64-bit operating systems is not guaranteed by the developers
Here is the system I tested Rise of Flight on:
    * Processor: Intel Core 2 Duo E8200 (overclocked to 3.21 GHz)
    * RAM: 4 GB DDR2
    * Hard Disk: WD Raptor
    * Video Card: ATI Radeon 3870X2 (overclocked)
    * Operating System: Windows XP Professional, Service Pack 3
    * 22" LG widescreen LCD (1680x1050 native resolution)
The resolution I found that worked best was 1280x800 providing the 16:10 aperture. At this setting I could run the graphic quality settings on high. A couple more technical notes to pass along. This build set both cores "on" by default in the CPU dual core affinity setting. Cool! neoqb development team member "=FB=VikS" commented in the SimHQ RoF Forum recently, "ROF have separated threads architecture, so two/four cores will work. Actually we have exact numbers of trials of core duo vs core quad, and core quad works 30-40% faster than core duo with ROF".
Also, I may be the luckiest person who ever loaded this particular build version, but in flying it for hours I had one freeze when switching between screens. That's it. For an early build of any software, that's impressive. RoF was remarkably stable on my test computer.
http://www.simhq.com/_air12/air_400a.html
Cita de: GAE_Charrua en 28 de Febrero de 2009, 12:31:15 AM
    * RAM: 3 GB
Ah buehhh!!, pero esta gente esta de la nuca!!
Dejate de jod...., pongo unos mangos mas y me compro un de la segunda guerra de verdad!!!!!!!!!!!
Existe esa tecnologia ??? ;D
Cita de: GAE_Angel en 28 de Febrero de 2009, 11:03:54 PM
Qué no tenés una PC así?? ahhh entonces no me junto con vos.....  :P :P :P :P
Lástima que no hay fecha todavía, pero parece que por la nota de Simhq, es una joyita a tener en cuenta.
Charru, eoss requerimiento sôn Mínimos? o recmendados?
Para ser mínimos son descabellados!, para ser recomendados, Y, es logico....
Baco lee el post y fijate estan locos ....
El post es confuso, porque arriba dice recomenden specs, y despues dice que se encesita: .....
Si eso es el minimo, el recomendado, todavia no existe jajaja, estan como Oleg Maddox en ese respecto jejejeje.
Igual mirá, yo al Black shark le tenía un cagazo bárbaro y al final corre en mi vieja y peluda PC lo mas bien.
Obvio que no hermoso como en los videos, pero sacandole "guevadas" como la sombras y la iliminación activa, alivianas una bocha . Seguramente este sim tambien podrá ser "toqueteado" para obtener mejores FPS...
